Drivetrain differences between an 02-04 MCS exahust and 05+ MCS exhaust
Old Mar 5, 2006 | 06:42 PM
ashirji's Avatar
ashirji
I can purchase an aftermarket exhaust that came off an 03 MCS, for my 05 MCS I understand that there may be some differences between them. Can anyone let me know if the 03 exahust will fit my 05, and if so, is there any cutting or welding involved? I have a Cabrio if it makes a difference.
Thanks!
Old Mar 5, 2006 | 09:15 PM
1nf3rn0's Avatar
1nf3rn0
1. The hangers between 04 and 05 are different, so they will need to be bent.
2. The cabrio needs a seperate exhaust design due to different structural changes underneath the car.
Old Mar 6, 2006 | 12:01 AM
etalj's Avatar
etalj
i've fitted a oneballed 03 exhaust to my 05 MCS, and it fits fine, the tips sit a little bit lower than they did with the 05 exhaust...
Old Mar 6, 2006 | 04:37 AM
ashirji's Avatar
ashirji
So the exhaust won't fit a cab? It is a Dinan exahust if that makes a difference.
Old Mar 6, 2006 | 05:02 AM
dominicminicoopers's Avatar
dominicminicoopers
The undercarriage of the Cabrio has an extra support bar. There's an extra bend in the 05 exhaust that allows the tubing to clear the bar.
Old Mar 6, 2006 | 05:24 AM
garretwp's Avatar
garretwp
If you want that exhaust to fit, you will need to do some welding and cutting to have it fit right under the car. Youll need to make the hangers adjusted to the 05 hanger design and will need to create the bend tubing to work under the support bar. Your best bet is to sell the exhaust and get the right one. Unless your down for some modifications. best of luck!
Garrett
Old Mar 6, 2006 | 05:33 AM
mdsbrain's Avatar
mdsbrain
I don't have experience with the cabrio, but with a late 04 - 06s the 2 center rear hangers need to be bent 90degrees towards the battery box.
sevin
May 2, 2026 06:11 AM
Colt45Magnus
Aug 13, 2015 11:18 AM
Aug 12, 2015 01:24 PM
massmini03
Aug 12, 2015 11:19 AM
dyeLucky
Aug 7, 2015 07:10 AM
