Drivetrain Stock LSD and aftermarket LSD problems?
I'm with you on the stiffen the rear. I've always viewed softening the front / stiffening the rear as interchangeable given all the suspension geometry issues you mention. It is indeed a science, unless you don't have the telemetry, then its an art. Its really a CG discussion and I can't tell the difference between the two when changing shock settings.
Here's the thinking / DE experience on the diff. Its basically the 100% work for a tire discussion. A tire can do 100% work of; turn the car / stop the car / accelerate the car. At corner exit with a LSD both tires are trying to turn and accelerate the car. With an open diff the loaded tire gets its acceleration work load taken away leaving more work for turning. Thus the tire with the most grip is basically devoted to turning the car. But the total work that both tires can do is reduced. This helps the car turn, but it suffers from lack of acceleration. I have seen this many times with a buddy of mine at the track that runs an open diff. So, as mentioned above after adding the diff I have learned to brake and apex a tad later to be able to get to the gas sooner. And the car is set stiffer at the rear and softer at the front so the car rotates - like you better be going to throttle at turn-in or your going around. The old loose is fast.
Alan
Alan
I think your corner exit understeer with a diff is the quaife. I did not experience that at all going with the Giken but have felt that after driving vince's quaife equipped car.
Street/AutoX Torque Biasing will work until you lift a drive wheel off the ground and then game over.
Track=Clutch type LSD
The nice thing about the OSgiken, I have it in my S2000 and GT2, is it is a very progressive lockup on acceleration.
Rear Wheel drive also benefits from a locking LSD under braking to keep the back end from being twitchy.
Peter
Peter
uhhh Either I'm not explaining things very well (definitely possible), or you are stuck in sales mode.
LSDs do one thing, which is provide power to the wheel with the least amount of grip. There are basically two ways of doing this.
LSDs can be designed to have a wide range of coupling characteristics.
If you add a LSD to your car you drastically change the coupling characteristic of your front wheels. You will need to adapt your suspension set-up / driving style to accommodate this fact.
LSDs with different coupling characteristics will require different suspension setups / driving styles.
Alan
Peter
Peter
I have unweighted both front wheels at times. You ever been to LRP?Alan
Alan
Alan
Kimolaoha
Jul 5, 2023 01:04 PM
ltjpunk7
Sep 6, 2015 07:32 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
