Drivetrain Poor Dyno results
Old Apr 2, 2005 | 09:05 PM
  #26
macncheese's Avatar
macncheese
Originally Posted by SpiderX
Randy or Ryan could answer this but I think the Unichip has some parameters for A/F ratios. The guys at KNowledgs thought the car needed more fuel.
When i go to Birmingham next week i will take pictures and ask a bunch of questions from these posts.
Without the UNICHIP installed, you could check your fuel trims with an OBDII scanner to verify that you're out of injector.
Cheese
Old Apr 3, 2005 | 05:09 AM
  #27
SpiderX's Avatar
SpiderX
I guess I don't understand but I thought/think the Unichip controls the fuel flow. You can adjust for rich/lean. Is this not a matter of optimizing ?
Clueless in Atlanta.
The car does run pretty good but you can tell as your going through the rpms that changes are happening.
Old Apr 3, 2005 | 09:56 AM
  #28
Ryephile's Avatar
Ryephile
Cheese
The fuel trims can indicate the fuel added or subtracted required to bring part-throttle (closed loop) driving back to the mapping based on the narrow-band O2's RMS deviation from stoich, however fuel trims are not used during open loop (full throttle) driving with narrow-band O2's. Using a wideband O2, you can interpolate you're "out of injector" based on the injector signals versus the ability to keep the A/F where you want.
Old Apr 3, 2005 | 12:16 PM
  #29
macncheese's Avatar
macncheese
Spidy,
There are some generally accepted guidelines for optimum a/f ratio but the point of custom tune would be to throw that out the window and tune for your vehicle. Major modifications that alter your engine's efficiencies can change what your target A/F ratio is. Good luck!
Old Apr 3, 2005 | 07:40 PM
  #30
SpiderX's Avatar
SpiderX
Spidy,
At this point I am going to drive the car to Birmingham and tell them to make power and try not to blow it up....I have to get home and I don't want to take the bus.
Old Apr 4, 2005 | 06:03 PM
  #31
jlm's Avatar
jlm
it has been pointed out to me that DSC need not be turned off to make a dyno run...it will turn itself off when no rotation of the rear wheels is detected and the fronts are pulling a load.
this is different from breaking the front wheels loose at the drag strip, which with DSC left on, will throttle back the moto, planting your nose in the dash.
Old Apr 4, 2005 | 06:22 PM
  #32
Strom's Avatar
Strom
It doesn't throw some sort of error code and go into a limp mode? Interesting. How does it tell the difference between the dyno and the dragstrip?
Old Apr 4, 2005 | 07:00 PM
  #33
SpiderX's Avatar
SpiderX
Ok.....I'm at 190.2
I think I should be at least 200.
This may be a case of addition by subtraction........ We'll see after Thursday.
Old Apr 4, 2005 | 07:26 PM
  #34
Ryephile's Avatar
Ryephile
If the rear tires don't turn for a "very" long time, the DSC turns off because it's confused. At the drag strip, the rear tires turn as you move forward, I hope.
Old Apr 4, 2005 | 08:19 PM
  #35
Strom's Avatar
Strom
I GUESS you're right.
wildwestrider
11
Jan 29, 2016 05:06 PM
zdw2082
Oct 5, 2015 09:59 AM
eMINI of the State
Oct 2, 2015 03:12 PM
potterstein
Oct 1, 2015 07:10 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
