Drivetrain HELP! Lost Boost Pressure!
Old Mar 29, 2005 | 01:39 PM
DrkSilvrMini's Avatar
DrkSilvrMini
Ok so on the way home i floor it because something didnt feel right. Well sure enough im only gettin 5psi at full throttle. The only mod done to the motor is an Alta CAI. I cant figure out what it is. Belt didnt sound like it was sliping. My only guess is the bypass valve. Is there something stupid that it could be that i could fix so it would save me a trip to the dealer?
Old Mar 29, 2005 | 07:35 PM
CoryB
Try doing Ryephix #1 and tying the bypass valve closed. That will tell you if it's gone bad and not closing completely.
If that's the problem, take it to the dealer and make them replace it.
Old Mar 29, 2005 | 08:16 PM
DrkSilvrMini
Ill have to try that tomorrow after work.
Old Mar 30, 2005 | 10:26 AM
DrkSilvrMini
Ok so i called the dealer today and they say they have never heard of that problem? I still havent tryed zip tying the by-pass valve yet because i am still at work. But does anybody have any other suggestions?
Old Mar 30, 2005 | 10:47 AM
jlm's Avatar
jlm
how are you measuring boost? maybe your MAP sensor is loose or buggy.
Old Mar 30, 2005 | 11:03 AM
DrkSilvrMini
I have an autometer boost gauge in the car.........and its not throwing any codes at all. Its barely hitting 5 psi and the car deffenately feels real slow.
Old Mar 30, 2005 | 11:12 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Is your engine making a wheezy sound like a broken set of bagpipes?
Old Mar 30, 2005 | 11:23 AM
DrkSilvrMini
No.....theres no wheezy noise? BUt i can tell you the SC isnt near as loud as it use to be ( I Have Alta CAI on it).
Old Mar 30, 2005 | 11:25 AM
berky's Avatar
berky
defective wastegate
i just had a similar problem. The wastegate stuck open, it was defective. when that happens the computer shuts down any boost for emissions. the car ran, but very sluggishly and i could only accelerate slowly. it was covered under warrantee.
Old Mar 30, 2005 | 11:35 AM
DrkSilvrMini
Im takin you mean the By-pass Valve. That was my same thought too.
Old Mar 30, 2005 | 01:45 PM
CoryB
Hence my suggestion to tie it closed and see what happens.
Oh, and you'll find that most MINI dealers "have never heard of" many problems that are commonly discussed. I think they have special training for them to learn to say that phrase and sound sincere.
Old Mar 30, 2005 | 02:39 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Here are the common issues I've seen:
- Check the Alta hose on the throttle body
- Check the green gasket at the inlet to the supercharger - right between the superchager and the black ABS plastic piece that is attached to the throttle body
- Check the bypass valve, you can snap it shut by hand if it is stuck open
- Check the intercooler boots on both sides - T30 torx bits - pull them off and make sure the bottom isn't blown off (you can't usually see it)
Hope that helps!
Randy
Old Mar 30, 2005 | 06:31 PM
DrkSilvrMini
Well thanks everyone for the suggestions, and thanks randy for chimeing in. BUt i took the car to the dealer today since it is under warranty. I told them i wanted the car back ASAP, so they told me it will be worked on tomorrow. I told them to call me once they figured out what it was. So as soon as I know i will post and let you all know what it was.
Thanks again
Matt
Old Mar 31, 2005 | 06:18 AM
andy@ross-tech.com
Why did you ask us for advice if you weren't going to try even the simplest suggestion?
Old Mar 31, 2005 | 06:27 AM
DrkSilvrMini
Well i wasnt sure if it was still under warranty, and then i found out it was. I was goin to try to fix it but i dont really have much time because i have to go out of town for work in the next couple of days......so i figured i would give it to them and hope they get it done fast. But if anybody feels i wasted there time on giving me suggestions then sorry. But like i said, givin the situation im pressed for time, so i took it to them.
Old Mar 31, 2005 | 06:36 AM
ripley's Avatar
ripley
please let us know what the problem is and how the dealer responds.
Old Mar 31, 2005 | 06:37 AM
DrkSilvrMini
will do waiting on a phone today about it.
Old Apr 1, 2005 | 02:05 PM
DrkSilvrMini
Car is done, it was a bad bypass valve.
Old Apr 1, 2005 | 03:58 PM
badassmini's Avatar
badassmini
Did the dealer have any issues w/ the Alta Intake on the car when they did the warantee work on the bypass valve?
Old Apr 3, 2005 | 03:27 PM
DrkSilvrMini
No.....as far as I know they had no problems and didnt even bring up the fact that the Alta CAI was even on the car.
Helix13mini
Jul 27, 2016 06:29 PM
Sep 16, 2015 02:10 PM
Sep 16, 2015 02:09 PM
Sep 14, 2015 12:48 PM
Sep 2, 2015 11:15 AM
