North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Drivetrain (Cooper S) (https://www.northamericanmotoring.com/forums/drivetrain-cooper-s-16/)
-   -   Drivetrain 15% Pulley... can't tell the difference (https://www.northamericanmotoring.com/forums/drivetrain-cooper-s/38893-15-pulley-cant-tell-the-difference.html)
strider209 Mar 7, 2005 12:01 PM
I've put on about 250 miles since my Alta 15% was installed and haven't really noticed a difference. I had the pulley done at about 800 miles and now am at about 1050. She's not "broken in" yet so I haven't done any WOT driving. I think there's a little more torque but it doesn't seem like there was much change from before the pulley. Am I expecting too much? Do I need to "break in" the car before I notice anything?
greatgro Mar 7, 2005 12:16 PM
Yes and yes. With the 15%, you really do need to break it in first. You'll notice the extra power the most when you floor it and higher RPMs. (both of which you're not supposed to do until broken in). Sure any pulley helps at all RPMs but the 15% is really noticeable above 4500 RPMs and abouve 5k ROMs for sure. Finish up those break-in miles and then let er rip!:grin:
jlm Mar 7, 2005 12:25 PM
you really don't build boost unless it is at WOT and then at >3000 rpm it happens. It will all be new, since you haven't even seen the effects of the stock pulley if you have been babying it. find some open road and get ready for a surprise.
strider209 Mar 7, 2005 12:38 PM
Thanks for the responses so far. Any recommendations on what to do next? She'll be used strictly for street use. Looking at improving performance/handling. I was thinking of a rear sway bar. Suggestions?
Mini-Driver Mar 7, 2005 12:50 PM
MTH your car it will help the ECU handle the extra 4-5 PSI you getting from the Pulley upgrade. IMHO it helps smooth the engine out in the high rev's then put a 22MM RSPEED rear swaybar on your car. Man you wont believe it!!!!!!
d6-mcs Mar 7, 2005 12:55 PM
there is not "break in" period on the pulley....there isnt.....you should get a boost gauge so you can see what PSI your running....if it isnt higher then 10psi then you have a problem.....the 15% isnt a huge different because is only a 1 to 3 psi up from stock 10psi...were on the 19% is a 7psi up from stock.....the 15% is more of a track pulley were the 19% is a drive around and have fun pulley...while ripping the tires loose though 2nd.... sorry....
BATES
dave Mar 7, 2005 12:58 PM
No one has claimed there is.
There is a break in period for the car though since he's only at 1050 miles. greatgro's point was that he should observe MINI's break in period and that once that was over (and he could go over 4500 rpm), then that's where the pulley would be noticed.
greatgro Mar 7, 2005 01:00 PM
Right no one said there was a break-in for the pulley! He's still breaking the CAR in!!:lol: He just hit 1000miles. :grin:
andy@ross-tech.com Mar 7, 2005 01:05 PM
:confused:
http://www.ross-tech.net/andy/mini/01519pulleyboost.png
Mini-Driver Mar 7, 2005 01:31 PM
Originally Posted by andy@ross-tech.com
Dude,
I just love those Graph's you have, 15% pulley is very KOOL. I have one on my car with the MTH software and for me it's GREAT!!!!:thumbsup:
SumWon Mar 7, 2005 01:37 PM
Love it! I am gonna make this my background until I get my 15% at the Dragon this year! Keep up the good work Andy.
Ryephile Mar 7, 2005 04:38 PM
....I haven't done any WOT driving....
bingo! Step on the gas, the power is there :thumbsup:
minibrute Mar 7, 2005 05:01 PM
You'll never know the diference
Since you had the reduccion pulley installed before completing the motor brake in then you don't have the ability to compare the stock pulley vs. the 15% reduccion pulley anyway. You didn't miss anything, the 15% pulley is awsome.
:thumbsup:
kenchan Mar 7, 2005 06:18 PM
15% was not a eye popping difference, but it made the car feel lighter and livelier which is exactly what I was looking for. :smile:
WindMeUp Mar 7, 2005 06:27 PM
:thumbsup:
I agree... I have a 19%, but still, with any aftermarket pulley, you're definitely not missing anything :thumbsup:
