Dyno'ed DER MINI!!!
went down to intec racing down here in renton,wa...on a little dyno day...pretty cool got to see some D-1 drift cars...dyno'ed DER MINI for $25 bucks for to runs...hoping to get 180hp at the wheels...but just under...i ran it on 3rd gear...on a DYNORUN machine...came out with:
1st run: 168.7hp and 154.8 TQ 2nd run: 162.4hp and 148.8 TQ for some reason i didnt get exactly 180hp but happy...for some reason also they didnt put a fan on the intercooler..just the radiator... i am running the 19% pulley from Mini-Madness...Mini-madness header...Mini-Madness intake...Borla Sport exhaust...and NGK iriduim plugs...not to bad i think...but for some reason feels way faster then that....i think now i need to get a ECU upgrade and a intercooler upgrade...and ill be set... LATER BATES |
1st run: 168.7hp and 154.8 TQ 2nd run: 162.4hp and 148.8 TQ |
It can't be compared like that.. try it on another dyno and then you would understand.
Having a fan on the Intercooler makes a big difference. I found my best run, with the hood shut and running a very large fan across the hood to cool the intercooler and one lower running across the radiator. With the hood open you are not really replicating any real driving, since 1) no one drives with their hood open 2) you aren't taking advantage of the scoop and forcing air through the intercooler. With the hood open it is just running over the top of the intercooler. It is cooling the engine bay pretty well, but the key is to cool the intercooler more so than just general cooling of the engine bay.
As a way of comparison here is a list of dyno runs that was run last month here in So cal on a Dyno Jet. Now I know a different dyno and different days makes for different outcomes but at least it might give you an idea what others are running. BTW the only real similarity with your run was a cheesy fan aimed at the front grill which sounds like the system they used with you.Here are the numbers which were posted by Minihune under the heading " horsepower myths debunked " elsewhere on this site.
Randy M7 Tuning " Some of it was "hard to read" so here's a rough recap- HP/torque -- Stock or upgraded 281 HP “ElDiablito” “SPI Twin charged and much more” 255.2 HP/233.7 ft-lbs. SPI Twin charged, stock heads/throttle body 210 HP MCS “works” (210 JCW kit,Schrick cam, 17% pulley, porting and polishing of EVERYTHING) 196.2 HP 15%pulley,throttlebody, ported head/intake,Miltek header/exhaust Madness cold air intake, MTH, wires/coil/plugs, schrick cam 189 HP 15% pulley, intake, Miltek exhaust, throttlebody, MTH, cam? 183 HP M7 MCS- (lots of upgrades) 175.4 HP ‘04 MCS JCW stock 172 HP 15% pulley, Unichip, Throttlebody, K&N filter, Magnaflow 170.2 HP ‘04 MCS JCW 168.2 HP Hedman headers, JCW, 15% pulley K&N intake 168 HP ‘04 MCS Ported head, cold air intake 160.9 HP ‘05 MCS “stock” (very high numbers!) 160.7 HP Alta intake, Magnaflow 158.8 HP ‘04 MCS “JCW intake only”, Zoomer's cat back exhaust 154 HP 15% pulley, Dinan intake 151 HP ‘04 MCS stock 106.8 HP MC stock ------------------ JCW kit MINIs were from about 168.2 to 175 HP at least. A stock '05 MCS dynoed almost 161 HP! An MCS with 15% pulley and Dinan intake dynoed in the same range as an '04 stock MCS (within 3 HP). Conclusion? There is great variation in measured HP from one MINI to another. "Hey MINIUSA, Can we have a little consistency here please?" :sad: :cry: " |
how can you not compare that..so i have 170hp...but not only that but you have to have torque...i wanted some options and such not a dam dictionary....from what it looks like i am about average on that list...but that on this website....
BATES |
also how are some people running as much or more then with the same mods or less....i guess taht fan on the intercooler would make a difference....but it was 25 bucks...give me some options on what to do next...maybe a ECU to get everything working right together????
BATES |
and yes that is at the wheels....
BATES |
BATES what intercooler set up are you looking at? Did you ever fix all the ones you bent when "polishing" it? Maybe that has something to do with the low numbers? |
i think a better intake will make in improvement, but not a huge one. me and ryephile did some dyno runs in my 04 MCS, Alta, Borla Street and made 165whp. my torque was only 146 tho. it was also extremely cold that night, as in single digit cold, so i might not be too accurate
BATES Randy M7 Tuning |
thanks...i like the MM intake that i have striaght and to the point and i have seen the dyno that george did in person when he install that intake...i dont think is so much the intake but the ecu or intercooler temps....how hard is it then to get the intercooler pipes polised up....
BATES |
inside the pipes....
BATES |
also as for the dyno..has anyone hit over 200hp without the twin charge system...and what were they running....
BATES |
you get upset with randy for posting those dyno numbers and then go and ask a question like that? :lol: :roll:
look above you will notice 210 HP MCS “works” (210 JCW kit,Schrick cam, 17% pulley, porting and polishing of EVERYTHING) |
yes
Anyone have any idea who owns this particular Mini? |
BATES |
Anyone have any idea who owns this particular Mini? Randy M7 Tuning |
BATES :cool: |
Is this on your 626 btw?
Originally Posted by sevin626
I pegged 235.5 hp with nitrous...
:cool: -shenmue |
Several weeks ago at AMVIVII I had Randy install a 15%, Alta cold air intake, Densos, and a Miltec. We were at Dynojet and My 2004 MCS stock dynoed 159.5WHP and 180WHP after the mods.
| All times are GMT -7. The time now is 01:04 AM. |
