Aftermarket cam for daily driver? Worth it?
I've pretty much done all of the easy common mods to my 03' JCW.......I'm thinking about possibly adding an aftermarket "performance" cam. I've never really seen any dyno numbers showing where different cams add power in the RPM range, and where they lose power. For a daily driver, is a cam worth it? These cars don't have much power under 3,000rpms anyway......would a cam kill the power end torque even more? Will it kill MPG? Is a tune required for a cam swap?
Just looking for some info......thanks! |
While a lot of aftermarket parts on all different cars will kill reliability and are generally crap. A Cam in an R53 won't hurt the daily driverness of the car. Yes it's true there have been some batches of bad cams, But that speaks true for OEM as well. Good Cam and a tune will yield some power with no loss in drive ability just a slightly higher idle that comes with the tune for the cam. Maybe I'm wrong but I'm yet to see or hear about someone selling a cam to the general population that has giant lope like some of the V8 cams out there and have no bottom end grunt. I'm sure any one of the cam dealers out there can make you that cam if you want.
Originally Posted by R534life
(Post 4475597)
There are R53 cams out there designed for track cars that only make power at high rpms....a cam like that would be horrible in a daily driver. And some of the street cams I've seen make low end power, but overall only gain 10-12hp....and that's just not worth the trouble. I was hoping to hear from some guys that are running an aftermarket cam in their R53. Nobody? |
Originally Posted by IQRaceworks
(Post 4475626)
Not sure if that kind of blanket statement is true. Lots of different cam manufacturers offer many different grinds of cams for street, race etc, etc. All with different lift, duration, lobe separation, etc etc....
I've driven cars that only make power way up in the rpms.......they are great on the track, but no fun on the street. For the street, you want a nice flat torque curve that gives lots of grunt all over the rpm range........you don't want power only at high rpms. At least I wouldn't. Especially from a dead stop....while your motor is taking it's time to spin up the rpms and gain power, the only lady in the Toyota Corolla next to you has already blown by you. :lol:
1 Attachment(s)
:lol:
LOL https://i.imgflip.com/33d0ch.jpg . I can't answer your question because I'm still an R53 noob, but it's also a topic I'm interested in and I have the same questions as you. It'd be great to have dynographs from the same car but with different cams installed as that'd really give a solid idea of what to expect. The closest to that I've seen is this one: Attachment 192914 Found on a BVH thread but cam talk also, here: https://www.minitorque.com/forum/f24...ml#post2229282 . |
I've driven a lot of mini's with various cams. Newman, Grand Am race cam, Dominator, Shrick etc etc. From a driving it on the street stand point my butt dyno isn't tuned enough to feel the difference in any of them from low end grunt with the exception of the shrick which felt a bit down everywhere on the others. The Grand Am cam had a noticeably high idle. That was all. None of these are like dropping a Giant cam in a LS that feels Dead under 3k and surges while driving down the interstate. The fact that you have a blower and it cam pump 12 to 16 psi in at 2k rpm really makes up for that.
(Post 4475713)
So......for a guy who daily drives his mini and doesn't track it.....is swapping cams a good idea? How much power do you actually gain? Out of all those cams you listed...which one did you like the most? |
I've had Minis with different cams and the best mod for the $$ is the pulley. Then the cam and head.
:popcorn:
I must admit that I like the lumpy sound of a big cam... ...but I'm unsure how an aggressive profile would be for a daily driver? And, if getting a mild cam for an everyday car, would the time/investment/reliability even be worth it? |
Originally Posted by Oldboy Speedwell
(Post 4475754)
:popcorn:
I must admit that I like the lumpy sound of a big cam... https://www.youtube.com/watch?v=pfRdQpgojoY https://www.youtube.com/watch?v=7J4CX1DIDkU ...but I'm unsure how an aggressive profile would be for a daily driver? And, if getting a mild cam for an everyday car, would the time/investment/reliability even be worth it? I've read that some guys get check engine lights after a cam install...and even after a custom tune, that cant get it to clear. How common is that? |
(Post 4475762)
That's my main concern. I don't want to kill it's daily driver manners in exchange for 10hp way up in the rpms. I would be better off putting a 25hp shot of nitrous on it. My car spends 90% of its life on the highway driving to and from work. Sure, I would love some more power for passing cars, stuff like that.....but not if it's going to kill MPG....and give me other issues.
I've read that some guys get check engine lights after a cam install...and even after a custom tune, that cant get it to clear. How common is that? Most mild cams for the Mini, while making a small amount of HP, will for the most part simply move the power band in the rpm range. While the more aggressive cams can also add noticeable HP throughout their power band. As for tunes, the more aggressive the cam, the more necessary and difficult the tune, and many of the milder cams, while benefiting from a tune, it won't be a necessity. Many of the stories of problems with cams and tunes are on '05 - '06 models because of software changes from BMW/Mini, so you'll probably be fine there, but unfortunately it will probably still be a carp-shoot, if you're not tuning. My suggestion would be as always, for what I think you're looking for, the Thmpr Adjusted Cam Gear, for the stock Cam, a small increase in HP, and more importantly torque (there is actually a noticeable difference with the butt dyno), from 2700 to redline, easy install, no tune, and about ½ the cost of a Cam. Here are my results with Virtual Dyno after only swapping to the ACG, all the conditions were as close as I could get them, this is with a STOCK cam and with the Sprintex. OEM Gear ACG (bottom graph is boost only, wanted to show, that's not where the power came from) https://i116.photobucket.com/albums/...Comparison.jpg |
Thanks for the info. After looking at your dyno graph, I think I'm just going to keep things they way they are. It's not worth the time or money to do a cam (or just an adjustable cam gear) for 2-10hp and 7ft/lbs of torque gain. I would think that just the fluctuation of outdoor air temps would affect power more than that. Maybe I am better off with a small wet shot of nitrous.....say 25hp.
Now, if I had to pull the motor to rebuilt it....sure, I might do it just because I already had it all apart. I'm shocked that more power and torque gains are not achievable with a cam swap on these little motors. I guess I'm just used to the GM LS motor that are seeing 80+ hp gains from nothing but a cam swap. If I could only find a way to shoehorn an LS into my mini....... :nod: |
(Post 4475726)
(Post 4475851)
RMW's dominator. Good powerband all the way through. I own a LS6 and I feel like the stock cam is to lumpy on that thing. I like a nice smooth idle and a big power band so if that helps your decision based on someone who thinks a stock GM cam is to big.
(Post 4475754)
:popcorn:
I must admit that I like the lumpy sound of a big cam... https://www.youtube.com/watch?v=pfRdQpgojoY https://www.youtube.com/watch?v=7J4CX1DIDkU ...but I'm unsure how an aggressive profile would be for a daily driver? And, if getting a mild cam for an everyday car, would the time/investment/reliability even be worth it? If Desire runs like that I would take her to the back of the barn and end her miseries with a 30 aught 6. :eek: |
Some of this is funny.
NOTHING is free. There isn't many (IF any) cams on the market that will provide "more usable" power across the entire power band without a loss somewhere. It just doesn't work that way. More low rpm power, the high rpm will suffer. More high end power, the low RPM power will suffer. Just a matter of physics, remember that high school class ? An after market cam will NOT make up the power of additional PSI. Additional PSI will NOT make up for an improperly designed cam shaft. They ARE different animals and provide their amount of power differently. BUT, chosen well, they also "can" (and should) compliment each other. While I've looked into the hot rod Mini cams a bit myself, I haven't been happy with not able to get actual specs. I can "ask" questions until I'm blue in the face, but until I can actually compare the numbers that make up a given cam, I'm not spending any money...on an "unknown"..! Mike |
Originally Posted by OCR
(Post 4476707)
(Post 4476938)
Not entirely true. Some Cams are built for emissions and going aftermarket can gain you power everywhere. There are loads of LS3 cams that make power at every RPM over a factory cam cause the factory cam was designed for MPGs and emissions.
Going from an emissions based phase to a power based phase. |
I don't recommend an adjustable cam gear as we always see them walk.
The right cam can work well and still be daily driven. The more "cam" you have the less daily use it will be as it will idle rough and can loose low end. As you think race cars don't just idle and they run at higher rpms all the time. That is why we have only offer two cams. Our mild is designed for street cars including daily drivers as 95% of all customer drive their cars daily. It gives good noticable gains without having the high rpm all the or low end loss, and not ruining the idle or making it hard to start. On the other hand we have a race cam, which is meant for racing or track use hense why we call it the race cam and not a street cam. It will need tuning to make it idle and really pull with the rpm rather than at low rpm. And with that said we always recommend upgrading injectors with the cam as you'll need the extra fuel to make the cam work correctly. If you want a good street cam go with our mild cam and enjoy. https://www.waymotorworks.com/way-mi...t-r52-r53.html |
Originally Posted by WayMotorWorks
(Post 4477067)
The right cam can work well and still be daily driven. The more "cam" you have the less daily use it will be as it will idle rough and can loose low end. As you think race cars don't just idle and they run at higher rpms all the time. That is why we have only offer two cams. Our mild is designed for street cars including daily drivers as 95% of all customer drive their cars daily. It gives good noticable gains without having the high rpm all the or low end loss, and not ruining the idle or making it hard to start. On the other hand we have a race cam, which is meant for racing or track use hense why we call it the race cam and not a street cam. It will need tuning to make it idle and really pull with the rpm rather than at low rpm. And with that said we always recommend upgrading injectors with the cam as you'll need the extra fuel to make the cam work correctly. If you want a good street cam go with our mild cam and enjoy. https://www.waymotorworks.com/way-mi...t-r52-r53.html Oh....and have any of your customers got a check engine light after installing the street cam? |
There's a hard to read dyno chart on WMW link showing torque gains from 2500 and up, and peak power from 150 to 172 HP.
For a shop that does this on a regular basis....I'm surprised way motorworks doesn't have any before and after Dyno graphs he can post up.........
Originally Posted by Andy_S
(Post 4477264)
(Post 4477305)
We did dynos long time ago before we offered our cams to get what we wanted out of it, but that dyno shop changed hands and the original dynos were lost. I've tried to source them from my failed laptop without luck. |
(Post 4475454)
Just looking for some info......thanks! Any camshaft you install it will take a day or two to adjust to the engine power curve. Then you are golden. When I go from the family car to the MINI, I have to remember that it is powerless under 2K and adjust. As soon as I get on board with the engine, the car is a blast to drive. ( I have a Performance Cam 11.35 mm Intake ). There are now cams out to pretty much put you where you want to be. Just keep it small. |
