Turbo Talk (go big or go home?)
So I’m finally at that point where I think a new turbo may be in my future.
I currently have a 2013 R56S modded as follows: Manic Stage 2 on map C (I fuel it with 10 gallons of 93 and 4 gallons of E85, so E31ish) K&N Apollo with bulkhead cut out (Basically a DoS at less than half the cost) NGK (1422) ILKR8E6 Wagner Competition FMIC (eBay clone) NM hard charge and discharge pipes AEM WMI injection (50/50 mix, 250cc nozzle in charge pipe) mQubed Catless Downpipe BSH lower engine mount Removed secondary cat and muffler. I am replacing the AEM with a 4 nozzle direct port injection in the intake runners with an additional nozzle in the charge pipe. Ireland Engineering “Street/Track” adjustable camber plates, rear control arms, sway bar, adjustable droplinks (E30 M3, I’m an M car now, right?) and stainless brake lines KWv2 Coilovers JCW BBK Madness LCA bushings Now that we have that out of the way, I’m looking for opinions on turbo options. I’m torn between the MINI JCW turbo (53039880146) and JMTC S42. I’m sure either one will require a reflash or new tune, however I think that the JCW would be plug and play with Manic stage 2. The S42 would require an RPM Power Tune because Manic stage 3 is NLA. The car is one of my daily’s, but it is in transition to be more of a track toy. Lots of HPDE events and eventually time attack are in her future. I don’t autoX and have no plans to start. I’ve gotten good feedback on the JMTC S42, but for some reason I am really leaning toward the JCW. What say you, internet? |
Manic does Stage 3 tunes again, FYI. I got one literally a month ago.
I have Mario's 43/56 Turbo. I love it. Basically zero lag (feels like stock turbo when spooling) and it will hold 22.5 psi through the whole rev range on my Stage 3 tune. Your stock MCS turbo tops out at around 20 psi (will make more but not efficiently) and the JCW turbo will top out around 21 psi. The increased boost plus my meth injection puts me somewhere in the 270 whp range by my best guess. Keep in mind you will likely need to swap out the clutch as well if you go for Stage 3. I have a friend that went for the S42 and RPM Stage 3 and is on the stock clutch, he's basically just waiting for it to explode and doesn't get on it too hard. |
Yeah, map C has me hitting 21.5 PSI. I really don't think I need to push more PSI, but I'd like to have more pull at the top. I feel like she starts to run out of breath at the top in 5th and 6th.
I'm still on the stock clutch with 94000 miles. I guess that is another option, OS Giken STR and a Wavetrac LSD. |
That's what I was talking about with efficiency. A bigger turbo will move more air up at the top of the rev range than the stock one, so your power band won't die off up at the top.
I have the JMTC 40mm turbo that is essentially a JCW turbo. Although I have been told that JMTC turbos run a little larger than the spec, I cannot confirm or deny that. What I can say is that I have also spent some time in another mini very similar to mine with the same tune that I put a 42mm in. They are both a big improvement over the stock turbo. Mine seems to spool just a touch sooner, the 42 pulled hard all the way to the redline. All in all they feel pretty similar, but the 42 has a bit more on top. I think you would be happy with either one. the 40mm is supposed to be “plug and play” but tuning for it makes a huge difference. I drove it for a few months with the factory tune and it was fine, but really came alive with the stage 3 tune |
@MrGrumpy I appreciate the feedback.
From what I am seeing, the JCW (PN: 5303 988 0146) is a 41mm. Any experience going from stage 2 to 3? Another reason I'm on the fence because it's a lot of money for a potentially marginal performance gain. |
Yeah, it’s hard to say. I’ve mostly seen the JCW listed at 40mm, but also 40.5, 41, and 41.5 lol. Who knows? But it’s supposed to be the JCW equivalent. The factory turbo on Gen 2 is 37mm. I don’t have any experience going from stage 2 to 3 myself. I went from the stock map to stage 3. So it was a huge difference. The friend went from stage 2 Manic to stage 3 RPM with the turbo upgrade, and it was definitely a noticeable difference, but the boost curve is different between the two tunes as well, so it’s tough to judge it. The boost is a lot more progressive with RPM |
When u said BIG, I was thinking about gtx28 Or so*♂️ |
Originally Posted by Ludopo
(Post 4453300)
When u said BIG, I was thinking about gtx28 Or so����*♂️ I'm interested in where reliability, usable power and size intersect. |
Originally Posted by scotty_r56s
(Post 4453302)
LOL, hence the question mark.
I'm interested in where reliability, usable power and size intersect. i have a GTX2867 gen2, using it as a daily, and it’s really comfortable. have been running one year on stock Internals with a custom tune, when I switched to forged internals, pistons were like new ( no wear on them, because of knocking or whatever) and that power... DAMN ! |
(Post 4453302)
I'm interested in where reliability, usable power and size intersect. I also built my car for mountain roads and cornering, so not having to wait for boost was important for me as well. Mario said a lot of autocross guys liked the 43mm, and I also heard some people having issues with turbo lag on the 47mm with the Manic tune. It was basically a no brainer for me. |
Thank you for the replies.
I guess I should clarify what I mean when I say "reliability". I'm looking for a turbo that can run flatout for multiple 20-30 minute sessions on a road course during a race weekend. Specifically, Road Atlanta, Carolina Motorsports Park, Roebling Road and Barber Motorsports Park. Currently, the stock S turbo with Manic stage 2 and WMI works for me until I get a long straight like between turn 7 and 10a at Road Atlanta. When pushed that hard, it feels like it is left wanting at top end. As much as I want to go with JMTC, I don't know that it would hold up to that kind of abuse. Realistically, I probably need to drop Manic and get dyno tuned locally. ¯\_(ツ)_/¯ After all, it is a 1.6l. A very small, angry motor. |
@thebombardier You went from stage 2 to stage 3, right?
Any thoughts on that? Was it noticeable? Would you do it again? |
(Post 4453307)
I guess I should clarify what I mean when I say "reliability". I'm looking for a turbo that can run flatout for multiple 20-30 minute sessions on a road course during a race weekend. Specifically, Road Atlanta, Carolina Motorsports Park, Roebling Road and Barber Motorsports Park. Currently, the stock S turbo with Manic stage 2 and WMI works for me until I get a long straight like between turn 7 and 10a at Road Atlanta. When pushed that hard, it feels like it is left wanting at top end. As much as I want to go with JMTC, I don't know that it would hold up to that kind of abuse. Realistically, I probably need to drop Manic and get dyno tuned locally. ¯\_(ツ)_/¯ After all, it is a 1.6l. A very small, angry motor. Good luck getting a dyno tune, I don't know anyone besides Manic and RPM that has actually cracked the N18 ECU. I did go from Stage 2 to Stage 3 but it was a little weird for me. I swapped the turbo while stage 2 and was still playing with the wastegate adjustment after I got retuned to stage 3, so it wasn't an instant change. Overall I do notice a big difference though. Gears 1 and 2 are essentially worthless at WOT now, I honestly need an LSD. It definitely pulls harder in all gears but not quite as much as I was expecting, the biggest difference is that it will pull just as hard at 2-3k RPM or 6-7k RPM. There are zero dead spots. |
Cool. Thanks.
Re: tuning, I feel like I've been waiting for that RMW standalone forever lol |
(Post 4453307)
(Post 4453322)
Cool. Thanks.
Re: tuning, I feel like I've been waiting for that RMW standalone forever lol Allegedly RPM is working on a remote tuning module for the N18. Dunno if that means they will be able to do remote dyno tuning or not but at the very least you can do a flash tune at home without having to mail your ECU out. |
When we say big turbos in MINI land we talk about K03 or ~K04 the size, because MINIs stock turbo is so small compared to the turbo industry. ;) Stock turbo do have dual scroll so they tend to have good pickup and less lag.
Mr Grumpy has a great assessment. :) With a tune, things come alive. JMTC has some good stuff and fits under the engine bay, lots of aftermarket off the shelf much bigger turbos you are going to have to mod the engine bay or tuck everything. I have seen some huge turbos on MINI that people had to cut the U brace or move everything around. Ludopo build here which is pretty cool with his turbo and fit pretty good: https://www.northamericanmotoring.co...artinique.html |
Originally Posted by thebombardier
(Post 4453324)
Don't hold your breath. Jan seems to only like investing time and money in R53s.
Allegedly RPM is working on a remote tuning module for the N18. Dunno if that means they will be able to do remote dyno tuning or not but at the very least you can do a flash tune at home without having to mail your ECU out. Dimsport has had the N18 write through the OBDII for awhile now We do however sell an upgraded borg warner which is 40hp ABOVE the JCW turbo and with factory reliability. We have not seen that type of reliability with the other turbos. |
Originally Posted by Revolution Motor Works
(Post 4453421)
You would be 100% incorrect, I'm the only one actually developing proper fixes for fueling, flex fuel and engine control. It will be done correctly, (not adding port injection) This is a costly and needed approach to making safe hp on a high hp Mini. I will never cut corners on this, as you can see on our 1st gen I have built complete full fuel systems to support 1200 hp..... We will never push a tune on people that exceed the map sensors ability to calculate correct spark/fueling , I've been waiting for the correct approach to doing it. The time has come now to finish up the latest greatest parts for Gen 2 and Gen 3 engines. I can't count the number of blown motors by these "tunes" and it's shameful. I will not be a part of it.
(Post 4453423)
Jan, thank you for weighing in on this. I'd like to hear more about your turbo.
BorgWarner's K03-2074 turbocharger is engineered to be a reliable and high-performance bolt on upgrade turbo for the 2006+ Mini JCW (adds 40+hp) Mini John Cooper Works upgrade from BorgWarner AirWerks features
Using a high-flow twin scroll turbine housing combined with BW's extended tip compressor wheel design - this turbocharger delivers early spool and outstanding boost response with torque and power gains across the powerband. Full-Race recommends the addition of an aftermarket exhaust system to compliment this turbo, although that is not required for the installation. |
You already know my opinions on this matter from our convo's on instagram messenger. For the money you wont be disappointed with a JMTC S42. Theyre a 46/58 compressor but the turbine remains smaller than the GTD47 for that "quick spool" I have been able to hit full 23.5 psi by 3300-3400rpm. You'll want to keep it around 21.5psi while your on your stock internals as your motor will make around 255-260whp and upwards of 300tq to the wheels....so thats right about where the limits of the stock internals are. I do have a buddy running 23-24psi like I was and his motor is still going but he had the benefits of WMI to keep knock down and cool the cylinders. Still....you never know what might happen when youre on the edge of the limits. with 255whp and 300tq you're gonna have enough power to blow the tires off the car down low but the torque steer will still be manageable.
(Post 4453317)
JMTC builds their turbos from OEM housings and internals, afaik they are just putting new impellers on the turbine and exhaust sides. I wouldn't be concerned about reliability with them.
Mike, I definitely appreciate your real world experience with this set up. That S42 looks so tempting.
Is anyone running the airwerks turbo? There for sale for like 650. Ive been lookin at the jcw and jmtc jcw turbo. But for the price i figure id ask if neone has actual expierence with this specific turbo as i do not understand the differences between this and a jcw turbo. Thanks
https://www.ecstuning.com/Search/Sit...5303_988_0146/
This turbo? For that price you have I dont know if its true borg warner, Is it used or new the price you are finding? |
