Drivetrain 3rd Gen Hood Louvers Installed
Old 12-03-2018, 10:54 AM
Chendricksen's Avatar
Chendricksen
Chendricksen is offline
Has anyone installed hood louvers on their F56S? Was thinking about it and wanted to get some ideas on potential fit, etc...
Old 12-03-2018, 12:48 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Mini_Vinnie is offline
Moderator
Vents?
Old 12-03-2018, 12:51 PM
Chendricksen
Yes, Vents. I was going to install some on the sides of my hood to allow for better airflow.
Old 12-03-2018, 05:34 PM
Mini_Vinnie
Moderator
Ah, gotcha.
If you are using the stock air box it isn’t worth it. That is a sealed system so you wont get any more air into it with our without the vents
Old 12-04-2018, 12:01 AM
SoCalF56's Avatar
SoCalF56
SoCalF56 is offline
If you google "mini f56 duell ag hood" you can get some ideas. The actual duell AG hood is several thousand $'s i believe and quite hard to get your hands on. Might be worthwhile being the guinea pig on one of the Chinese replicas of it for ~$800.
This would have to be carefully planned out so that its providing good airflow for the intake, but at the same time not dumping water in on it. I can imagine vents would help decrease under hood temps, which could also help out with intake air temps.
One of these hoods paired with a Mini Works functional hood scoop could potentially warrant some much lower under bonnet temps. Im tempted to try
Old 01-20-2019, 09:07 AM
CCsupra1997's Avatar
CCsupra1997
CCsupra1997 is offline
Where can i get a chinese replica? I want to cut the hood louvers too but I am trying to figure where to route the windshield hoses? Anyone have ideas??
Old 01-21-2019, 05:51 AM
I like mini clubman's's Avatar
I like mini clubman's is offline
I'm currently in the design and test fitting prototype phase with the R5X hood. If you look at my thread "good God I bought another clubman" you can follow its development. It's going to have three vents, a center and two over the wheel wells. This will greatly reduce under hood pressure (lift) and give exceptional cooling. Combined with an open hood scoop it will work even better.
send me a picture of the underside of your hood. The design I'm doing will require NO CUTTING of any structural hood members. There will be some trimming of excess flanges but the hood structure will stay intacked. This is the only way to do this, do not cut structures or you will compromise collision safety.
Old 01-21-2019, 06:38 AM
The center vent is close to final configuration. The side vent has had a major change from what I've posted. It is slightly smaller in width and tapered to follow the hood lines. It's also getting straight vents instead of curved ones. The placement of the vents also avoids any sensitive areas under the hood that could be hurt by water.
Old 02-15-2019, 09:36 PM
Clutch Wotan's Avatar
Clutch Wotan
Clutch Wotan is offline
Facebook Post
pjsjr13 (02-16-2019)
Old 03-11-2019, 11:09 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
You have great metal skills. Congrats on the cool design.
Old 03-11-2019, 11:16 AM
Just did the base coat on the vents. I'm going with mini Jet Black.
not so much metal working as CAD. I did the design and had them lazer cut at a shop. Took about ten tries to get it right LOL
Old 03-11-2019, 12:00 PM
Thats cool, the laser cut makes it so much easier.
Old 03-11-2019, 12:46 PM
Mini_Vinnie
Moderator
the thought of cutting into my hood makes my break out into a sweat
Old 03-12-2019, 10:59 AM
WhatV8's Avatar
WhatV8
WhatV8 is offline
If you folks are serious about this, then there is some good reading here:
http://racelouvers.com/
The guy seems to have spent some time doing the research and separating out the 'real' info vs the 'thoughts'. No connection to the guy, just ran across his stuff in another forum and thought I would share.
Old 03-12-2019, 11:43 AM
lol yes it did the same to me, so I bought a used non S hood and cut it up and added a real hood scoop.
everyone who sells hood vents has a sales pitch how theirs is better. Dont buy into any of it. Unless the vent/ heat extractor is designed for a specific car they are probably not going to get the exalted effect. I did my own homework based on several criteria. Looks, heat extraction, underhood components and hood structure all lead the way for my design. I think I've hit all four very well with looks being subjective.
Old 03-12-2019, 11:46 AM
Old 03-12-2019, 12:05 PM
IQRaceworks's Avatar
IQRaceworks
IQRaceworks is offline
That big square intake looks a little "ricer" if you ask me.....but to each their own I guess.
Old 03-12-2019, 12:21 PM
I'm 55 and going to be driving a ricer LOL.....cool! There is actually a method to my madness. That scoop houses the engine oil cooler and the vent behind it is actually the heat escape. There will be a pan under the hood to direct the heat out. I thought it kinda stupid to put a 220 degree radiator in front of the engine so I made a stupid hood scoop to put it in. The scoop also has passages for engine air cooling. I didnt start this project to be a total bolt on guy I also like to make things and this is my hobby. I still have the old S hood to go back to if I'm not happy or it's too over the top (ricer). The car will have a stage three tune and a 42mm turbo is installed along with all the other upgrades to make it better. I've got less than $150, including the hood, into it at this point so not a huge investment.
Old 03-12-2019, 12:24 PM
Front holes are for the engine bay the big one is for the oil cooler.
bratling (08-02-2020)
Old 03-12-2019, 12:52 PM
njaremka's Avatar
njaremka
njaremka is online now
Alliance Member
Received 1,712 Likes on 1,381 Posts
Speed holes
J_L (04-21-2019)
Old 08-21-2020, 07:39 AM
minideucecoop's Avatar
minideucecoop
minideucecoop is offline
Why is the carbon fiber eventuri intake a couple of thousand bucks, but an entire carbon fiber hood with vents is $700?
Old 08-22-2020, 01:56 PM
robby71's Avatar
robby71
robby71 is offline
Wild Snapper
01-20-2016 02:52 PM
Conrad_Thomaier
01-28-2014 01:48 PM
chadtoolio
08-16-2009 05:57 PM
Bang110
03-07-2009 02:21 PM
MSFITOY
08-28-2006 02:26 PM
Quick Reply: Drivetrain 3rd Gen Hood Louvers Installed
