R53 Racing Dynamics Header
Has anyone installed this header onto their R53? If so, what are the reviews? https://www.ecstuning.com/b-racing-d...300850500~rdy/ |
It says a high flow cat but the pipes from the cylinders do not appear to be longer that normally works out to less restriction.
RD stuff is just a name. I would recommend an actual long primary header.
While the primary tubes look similarly short to the original, the collector arrangement looks to be a little better designed.
I would not buy this one for improvement, but I'd buy this over an OEM assembly if the original was leaking, or bad in any way. Mike |
