Drivetrain Reprogramming ecm???
Old 04-19-2018, 12:55 PM
Tudorfritz's Avatar
Tudorfritz
Tudorfritz is offline
I’m looking to get my engine control computer reprogrammed on my ‘04 r50. Can anyone recommend a place that can do that?
Old 04-19-2018, 03:16 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Whine not Walnuts is offline
Going to move to the Gen1 Mod Section, should get some better views there.
Old 04-24-2018, 07:39 AM
fridayxiii's Avatar
fridayxiii
fridayxiii is offline
Jan @ RMW is one of the most trusted MINI tuners out there, especially for Gen 1 cars. I don't know what kinda gains you'd get from a NA MINI motor or what mods you've installed, but if you want a tune, Jan is The Man.
Old 04-24-2018, 08:53 AM
pnwR53S's Avatar
pnwR53S
pnwR53S is offline
6th Gear - NAM Hall of Fame
I am intrigued by what kind of race the car is built for. No brake lights, no plexiglass windows, and the cage design. Demolition derby? Dirt track? But why Hoossiers? For demolition derby Mini would be a very bad choice.
Old 04-24-2018, 10:03 AM
Tudorfritz's Avatar
Tudorfritz
thanks I’ll look them up.
Old 04-24-2018, 10:08 AM
Tudorfritz's Avatar
Tudorfritz
I’m going to race it on a 1/4 mile asphalt oval in the 4 cylinder class. Most people run Saturns in that class, I think the Mini should work better then the Saturn. The rules state all glass and lights must be removed and anything flammable from the inside.
Old 04-24-2018, 10:15 AM
pnwR53S's Avatar
pnwR53S
pnwR53S is offline
Cool! Thanks for the answer.
Old 04-27-2018, 08:05 AM
downshift1's Avatar
downshift1
downshift1 is offline
Why not just run a standalone ecu? You really don't need any of the functions of the factory unit and it would save you a decent amount of weight in wiring.
Old 04-27-2018, 03:06 PM
Thinker2112's Avatar
Thinker2112
Thinker2112 is offline
I am very interested in what you did to the engine and transmission.
Old 04-27-2018, 03:24 PM
Tudorfritz's Avatar
Tudorfritz
not exactly sure what you mean by stand alone ecu? The rules state the engine and computer must be stock and un touched. Only thing you can do is cold air intake and remove converter and muffler. So I know pretty much everyone reprograms there ecu because there is really no way to tell if it’s been messed with.
Old 04-27-2018, 03:30 PM
Tudorfritz's Avatar
Tudorfritz
right now all I did was cut the converter and muffler off and have a straight pipe running out to the side of the car. I also got a cheap universal cold air intake off eBay. The rules state the motor has to be stock or oem parts. The only real thing they check once in a while is compression, total weight, left side weight. So if there are a few things I could do to tweek the motor I’m all for it.
Old 04-27-2018, 03:39 PM
downshift1's Avatar
downshift1
A stand alone would be be against your class rules then as it would be an aftermarket unit.
Old 05-07-2018, 07:58 AM
Thinker2112
You can shave a few more pounds (probably) if you can get your hands on a set of Hole-ies for wheels. The stock MINI 7 hole 15x5.5 wheels are 12 pounds each.
Old 05-14-2018, 12:05 PM
Tudorfritz's Avatar
Tudorfritz
rules say you have to run wheel studs and 1” lug nuts. Those lug nuts would never fit in the lug hole of a aluminum wheel.
Old 05-18-2018, 08:32 AM
Thinker2112
You might be able to get more power if you get your hands on some JCW or S fuel injectors, you will still need to get a tune for them and as stated before, Jan at RMW is the guy you want to talk to.
I suppose on the wheel front, you could swap over to studs and lug nuts and drill out the Holies.
MacBones
08-10-2008 06:36 AM
Brihyanna
MINI5280
02-26-2007 05:08 AM
JPMM
09-08-2006 01:01 PM
joesantoyo78757
07-28-2004 11:34 AM
Russiaville
12-06-2003 06:21 PM
Quick Reply: Drivetrain Reprogramming ecm???
