Drivetrain JB+ issues
Old 05-08-2018, 07:42 PM
asysavanh's Avatar
asysavanh
asysavanh is offline
JB+ issues
Anybody have issues with the jb+ adapting? I installed it as the directions stated but still don’t see an increase in power or boost. Driven about 140 miles in two days. WOT and cruising speeds. It is the newer carb version.
i re installed it with the dial turned to 50% to see if that does anything. Wondering if anyone else has had issues.
My next step is to disconnect the battery for a few hours and then reinstalling the JB+ after a couple days of driving.
2012 MCS R56 N18. It is a true 2012 model btw.
Old 05-08-2018, 08:05 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
When I had one, which was the earlier version it was noticeable almost immediately. Did you buy it new?
I don't think the disconnect battery will do anything for you.
Old 05-08-2018, 08:44 PM
asysavanh's Avatar
asysavanh
Nope I bought it from a reputable person. Bought it used. I’m going to try and few things here and there before I give up and go For a legit tune
Old 05-10-2018, 10:58 AM
asysavanh's Avatar
asysavanh
Issue solved
Old 05-10-2018, 11:23 AM
trouble1943's Avatar
trouble1943
trouble1943 is offline
Originally Posted by asysavanh
Issue solved
How?
Old 05-10-2018, 11:40 AM
S-2013's Avatar
S-2013
S-2013 is offline
I just installed the JB+ last week and it came preset at 100%. The instructions noted that if using 93 or better to leave it at this setting. Feel it most after 3k rpm's.
Old 05-10-2018, 05:40 PM
S-2013's Avatar
S-2013
S-2013 is offline
What resolved the issue with your JB+?
Old 05-10-2018, 09:07 PM
asysavanh's Avatar
asysavanh
Took my dv adaptor off.
had a stuttering issue. Gone after I switched to e85 mix. Turned it down to 75% holding at 14-15lbs.
Old 06-16-2018, 07:25 PM
2012_R60's Avatar
2012_R60
2012_R60 is offline
asysavanh what mix are you using? I’m having similar issues even at 50% unfortunately I’m in Houston and the temps in the middle of the day are over 100degrees. Does anyone have any experience with jb+ and high temps. Does higher octane do the trick or is meth the only solution?
Old 06-16-2018, 07:46 PM
S-2013's Avatar
S-2013
S-2013 is offline
I have the current version in Austin and keep it set at 100% with no heat related issues using 93.
Old 06-16-2018, 08:43 PM
2012_R60's Avatar
2012_R60
2012_R60 is offline
S-2013 do you know what boost levels you’re hitting? If I set it at 100% I get over 20psi and go into limp mode. Also I bought it used from another NAM memeber so I might have to older version. I also use 93 octane gas.
Old 06-18-2018, 05:37 AM
S-2013's Avatar
S-2013
S-2013 is offline
I can check using my P3 OBDII gauge but read it doesn’t read boost accurately using any piggyback tuners.
Old 06-22-2018, 09:35 PM
2012_R60's Avatar
2012_R60
2012_R60 is offline
Finally figured out what was wrong. It was the spark plugs. They were in dire need of replacing and went with the NGK ones recommended on Burger’s site. Now I’m set at 100% with 93 gas and hitting 18-19lbs without issues!
Old 06-23-2018, 04:21 AM
S-2013's Avatar
S-2013
S-2013 is offline
What NGK plugs do they recommend, if you don't mind saying?
Old 06-23-2018, 05:26 AM
scotty_r56s's Avatar
scotty_r56s
scotty_r56s is offline
Originally Posted by s-2013
what ngk plugs do they recommend, if you don't mind saying?
NGK (1422) ILKR8E6 spark plugs.
Old 06-23-2018, 08:26 AM
2012_R60's Avatar
2012_R60
2012_R60 is offline
i went with the 95770 as suggested by burger below. I’ve read that the 1422 also work great, but are a step colder than the 95770.
http://www.burgertuning.com/mini_coo...t_adapter.html
Old 08-21-2018, 01:35 PM
tcyracing's Avatar
tcyracing
tcyracing is offline
buy last month JBplus 100% dial and it worked perfect
JCW N18 2013
I have also installed
spark plugs NGK (1422) ILKR8E6
Downpipe Milltek
CatBack Ipe Exhaust
Intercooler Wagner
It is very similar in a focus rs 2017 stock
trailrated
12-13-2021 09:10 AM
miniglenn
01-31-2008 04:10 PM
Quick Reply: Drivetrain JB+ issues
