Drivetrain Tuning options
Old 03-08-2018, 10:10 AM
socalva's Avatar
socalva
socalva is offline
Tuning options
I used the search function but it seems somerecommendations are no longer in business (Mynes). What are the current remote tuning options other than RMW? It looks like ByteTronics is the only other player but remote tune requires an wideband O2 sensor install. Anyone have recommendations for local tuners in the SoCal area?
Old 03-09-2018, 07:31 AM
astroblackr53's Avatar
astroblackr53
astroblackr53 is offline
Mynes is more/less Bytetronics. For reliability your best bets are RMW or Bytetronics, both are similar if you are looking for a software tune.
If you are wanting/able to tackle the tuning yourself than your option is Bytetronics, I use this and have had solid success for my needs.
Old 03-11-2018, 11:38 AM
Revolution Motor Works's Avatar
Revolution Motor Works is online now
Vendor
I'm in Anaheim and dyno tuning is in Wilmington for custom dyno tunes
Old 03-11-2018, 01:19 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Whine not Walnuts is offline
I have a RMW tune, all done in my garage. Yes it takes longer by the time you send the files back and forth and there may be some glitches but Jan at RMW stayed on the issue and I am very satisfied.
Old 03-13-2018, 11:44 AM
koreycon's Avatar
koreycon
koreycon is offline
what the guy up top said...Installing my RMW tune this weekend, super stoked!
Revolution Motor Works (03-13-2018)
Old 03-13-2018, 12:30 PM
Whine not Walnuts
I suggest you disconnet the power steering pump fuse first. It is under the engine fuse box, have to remove the ecu in order to flip the fuse box over. Be sure to disconnect the negative battery terminal first. Its the 100 amp fuse, watch the you do not lose the small screws. By doing this the battery voltage will not drop while you are loading programs.
Old 03-13-2018, 12:31 PM
Whine not Walnuts
just like a little kid in a candy jar . . . . . .
Old 03-13-2018, 12:36 PM
koreycon's Avatar
koreycon
koreycon is offline
Thanks!
SpeedRacer0212
04-03-2012 02:00 AM
Singha
R60 :: Countryman Talk (2010-2015)
08-25-2011 11:44 PM
DanQ
Cooper (non S)
48
03-02-2009 08:21 PM
Schwinn
09-12-2008 12:03 PM
MedicMan55
08-20-2006 03:19 PM
Quick Reply: Drivetrain Tuning options
