Drivetrain clutch going? Will warranty cover?
Old Oct 25, 2004 | 09:04 AM
chigh's Avatar
chigh
I have a clutch problem developing. When depressing the pedal I am feeling some resistance at about 2-3" above the floor, as if something is impeding it. Once down, the clutch engages normally. I am almost out of warranty at 49,400 miles.
Had a 19% pulley install from RDR at about 40,000 mi. Should I expect a denial under warranty because of the pulley? My thought is that it is unrelated as there has been no extra wear on the clutch.
Car goes in Wedneday.
Old Oct 25, 2004 | 09:24 AM
moonman9j9's Avatar
moonman9j9
I don't think they'll even notice the pulley...
Old Oct 25, 2004 | 09:57 AM
10851CS's Avatar
10851CS
Had the front bearing in my transmission go out and they had to replace the whole trany as the front bearing does not come by itself
I have the following mods:
ALTA PULLEY
ALTA INTAKE
THROTTLE BODY
PLUGS
WIRES
COIL PACK
SSR COMPS
MILLTECK SPORT CATBACK
H-SPORT LOWERING SPRINGS
P/S FAN COVER
H-SPORT REAR SWAY BAR
H-SPORT CONTROL ARMS
UNICHIP ECU
WHALEN SHIFT ****
WEBB’s STAGE ONE BRAKES
AUTO UP WINDOWS
VOICE OPERATED GPS SYSTEM
and nothing was said it was done under warranty.
Earl
Old Oct 25, 2004 | 11:20 AM
chigh's Avatar
chigh
That's reassuring, thanks.
Old Oct 25, 2004 | 10:06 PM
Ryephile's Avatar
Ryephile
The clutch is a wear item, and isn't ever covered under warranty expressly. If your dealership replaces any wear item, it's either under the 3/36k Complimentary Service, or a Good Faith budgeted item.
Old Oct 27, 2004 | 02:45 PM
chigh's Avatar
chigh
not warranty
Right you are. They estimate $1500 to replace clutch.
Old Oct 27, 2004 | 02:58 PM
MiniPilo's Avatar
MiniPilo
http://www.piloracing.com/shop/products.php?cat=8
elightbo
11
Sep 2, 2015 08:00 AM
willybudista
Aug 15, 2015 06:13 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
