Drivetrain Big brake kit for f54 Cooper S with 17" wheels
Old Sep 13, 2017 | 06:28 PM
Tcgorm's Avatar
Tcgorm
Am I correct to assume that I will need to upgrade to 18" wheels/tires to fit JCW or other aftermarket brakes?
Or could this be done by just getting spacers to further offset the 17" wheels to clear the larger calipers. Or are the replacement rotors too large? Please help me understand this issue, as the standard brakes on the Clubman S don't seem to be that powerful and I didn't want to dish out another $5k+ for the JCW version, when I can get essentially the same with bigger brakes and a Dinan Elite box
Old Sep 13, 2017 | 06:51 PM
vetsvette's Avatar
vetsvette
Moderator
You can run 17, 18 or 19" wheels with the BBK. It's the offset/profile that will either clear the Calipers or not. If you don't want to shell out the money for the heavy OEM style wheels there are other manufacturers like NM Engineering that can supply you with a much lighter and IMO better looking wheel that will clear the calipers.
Old Sep 13, 2017 | 08:35 PM
Hoopty's Avatar
Hoopty
or spacers......
or you can run spacers. I'm running 20mm all around with my BBK. ECS Tuning has some very nice quality spacers and lugs.
Good luck
Hoopty
Old Sep 15, 2017 | 02:33 PM
Tcgorm's Avatar
Tcgorm
Do I need a larger master cylinder with the BBK? Anything else?
Old Sep 15, 2017 | 04:42 PM
vetsvette's Avatar
vetsvette
Moderator
No. I would recommend braided stainless brake lines though.
Old Sep 25, 2017 | 07:10 AM
Tcgorm's Avatar
Tcgorm
I have looked at several tuner sites and can't find any brake line upgrade kits for the F54 Clubman S.
Does anyone here have a suggestion about where to look for stainless braided brake lines for the Clubbie?
Old Sep 25, 2017 | 11:55 AM
vetsvette's Avatar
vetsvette
Moderator
Have you checked NM Engineering? That's where I got mine for the F56.
Old Sep 28, 2017 | 06:17 AM
subzero05's Avatar
subzero05
might check out goodridge, they have a wide variety of lines
