Drivetrain Stage 3 clutch in street R53?
Old 03-30-2017, 05:21 AM
sevin's Avatar
sevin
sevin is offline
Originally Posted by WayMotorWorks
Yes like they said the Valeo will work for you fine. The aftermarket "stages" of clutches are really race clutches and never last as long as the original and due to the higher clamping force and materials they are made from they will be stiffer and harder to drive every day.
As for the Quaife and other parts we keep that all on the shelf and ready to ship as we install them in the shop all the time.
Don't bother ordering coolant online. You can pick up much cheaper coolant at your local parts store that works fine. I even run the green in my cars.
And with the Quaife, do I need to use shims and preload the diff bearings? Any place I can get an install procedure on that?
  #27
Old 03-30-2017, 05:53 AM
Mini_Chan's Avatar
Mini_Chan
Mini_Chan is offline
You do need to order new bearings for the quaife. I found a youtube video for the quaife install.
  #28
Old 03-30-2017, 06:51 AM
sevin's Avatar
sevin
sevin is offline
https://www.youtube.com/watch?v=KPXZIOB9QiM
https://www.youtube.com/watch?v=DXS_ega7qmg
I've seen those videos and that's partially why I'm asking. A bunch of people complain in the comments about how they did not adjust bearing preload or shim the diff. I just want to make sure I know what I'm doing when I get in there.
  #29
Old 03-30-2017, 07:07 AM
Mini_Chan's Avatar
Mini_Chan
in his comments the guy said "Never needs re shim, maybe other gear boxes are like this but not the getrag"
  #30
Old 03-30-2017, 11:25 AM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is online now
Vendor
With the Quaife no shims needed, just install and go
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
  #31
Old 03-30-2017, 03:10 PM
sevin's Avatar
sevin
sevin is offline
Alright cool. What sealant do you use for the transmission case? Do you torque the ring gear bolts or just impact them?
  #32
Old 04-03-2017, 10:33 AM
sevin's Avatar
sevin
sevin is offline
Anything on the sealant? I need to order everything tonight.
  #33
Old 04-17-2017, 07:56 AM
slo_crx1's Avatar
slo_crx1
slo_crx1 is offline
So how much power does the Valeo SMF kit actually hold? I need a clutch for my r53 as well, however I have a turbo conversion and have the potential for just under 300hp and peak torque at 4100rpm (currently only running 19psi, rough estimates now are between 250-270hp). My stock clutch is finally slipping so I need to find something decent to hold the power, but not something that will break the bank account.
  #34
Old 04-17-2017, 08:13 AM
sevin's Avatar
sevin
sevin is offline
I've read it will hold 270whp but I just don't trust that. I'd say you should pick up a higher spec clutch to be safe. If you're doing a turbo conversion, I doubt you care much about a little stiffer engagement anyway.
  #35
Old 04-17-2017, 09:57 AM
slo_crx1's Avatar
slo_crx1
slo_crx1 is offline
Ehh, I'll definitely need something bigger then, I'm close to that number now with the turbo at 19psi. I could care less about pedal engagement, nothing about the car is anywhere near stock as it is, so a bit stiffer on the pedal won't bother me.
Was just hoping to find something a bit more reasonably priced, any decent clutch and solid flywheel conversion is almost $1,000.
  #36
Old 04-17-2017, 12:37 PM
sevin's Avatar
sevin
sevin is offline
Yeah, you don't want to be doing it twice so I wouldn't recommend going with the Valeo first.
  #37
Old 11-01-2019, 10:29 AM
sevin's Avatar
sevin
sevin is offline
I just re-discovered this thread. My new Valeo is already slipping again, less than a year and ~8k miles since putting it on. Same symptoms as before. The old clutch actually had plenty of life left as well. Seems like they actually can't hold power, contrary to what I've heard you guys say. Could there be any other cause?
  #38
Old 12-23-2019, 05:39 PM
jk6672's Avatar
jk6672
jk6672 is offline
did you install it or have it done?
  #39
Old 12-23-2019, 05:40 PM
sevin's Avatar
sevin
sevin is offline
I installed it. I had another shop diagnose it and they said they thought something was wrong with the clutch, though they never found out what. Now running a stock Luk kit again. Hopefully it stays good.
  #40
Old 01-21-2020, 03:40 PM
Akumazeto's Avatar
Akumazeto
Akumazeto is offline
I’ve been running 270 whp on the Vallejo for years no issues. It loves the TVS 900
  #41
Old 01-21-2020, 04:14 PM
MrBlah's Avatar
MrBlah
MrBlah is offline
6th Gear - AX Champion
valeo do not work in my track car, slips going into 4th and 5th on the track after about 15 minutes of hard use
but it works fine in my street r53 that has more power
  #42
Old 01-21-2020, 05:20 PM
BlwnAway's Avatar
BlwnAway
BlwnAway is offline
Remember, while HP is a concern for clutch slippage, if you're on the edge of what it will hold...
Torque is your enemy, so higher gears after multiple hard shifts, and increasing heat, makes complete sense.
  #43
Old 01-21-2020, 07:51 PM
sevin's Avatar
sevin
sevin is offline
yeah i guess i got a bad kit
