Drivetrain M7 Speed Crank Pulley
Old May 21, 2015 | 05:11 AM
  #26
TheBigChill's Avatar
TheBigChill
I'm not speaking exclusively, or even primarily of American V8's. That's merely one tiny portion of the conversation. The main focus here is modern, factory balanced 4 cylinders. Eagle and Scat produce cranks, mains, rods, etc, for all engine types. They found the thought of replacing a factory damped crank pulley with an un-damped pulley absurd and potentially destructive.
This is different than an OEM supplying a solid pulley from the factory.
BUT, since you're using Porsche as an example, and specifically the GT3, you'll be super excited to read the following: http://performancedevelopments.com/p...enginefailure/
Performance Developments is a high-end Porsche engine builder, though, that document was actually authored by RKAutowerks, another noted BMW and Porsche tuner / builder.
I hope you found the section titled "Crankshaft Torsion and Dampers:
Torsion — The hidden problem with the crank system — and why it needs a damper
" especially enlightening.
ebowling
90
Aug 4, 2019 09:15 AM
Toolman
Jan 20, 2016 06:50 AM
mackedmini
Aug 20, 2015 02:35 AM
keck.j
Aug 18, 2015 08:18 PM
Lt. Dan
Aug 10, 2015 12:46 PM
