Drivetrain New ECS Carbon Fiber intake
#51
For those that are worried that this wouldn't work because you have the Craven Koala Intake Manifold Spacer, all you really need is a longer silicone hose to make up for the gap between the MAF and the upper CF intake pipe. Took about 40-45 mins or so, but should easily be done in 30 if you've done it enough times.
#53
rafanatic - thanks for the nice honest review.
Looks great.
Pm me your info , so we can get you that washer you dropped.
Another helpful tip step #15 : On closing the ECS CF clam-shell lid ( upper and lower half ) , line up the slotted gasket( on the top intake side) as close as possible, test a couple times open and close making sure hooking those back 3 tabs each time then close the top lid. You can then wiggle the top lid ( while closed) a hair to get that third hole to line up easier. Then start one screw at a time with the washers.
On the step number #6 , is you have the engine bay warm or the factory main inlet tube warm ( 13712753070 ) from being in garage or somethings, the tube has more flex its easier to insert pinch method, insert , then let go. If it outside and cold , its a little more work, as the tube does not flex as much.
#54
Cantcode86 - Thanks
#55
Looks great.
Looks great.
Overall, great quality product and finish comparable to those you see from high-end japanese tuners like Gruppe-M or 3D-Design, at probably half the price.
ECSTuning (01-03-2019)
#57
#58
Missing Screw and Wwasher
Mine arrived a few days ago but is missing one of the screws and washers. ECS, is this something that I can get locally? If so, what are the specs on that screw? I plan to install it tomorrow. I have the JCW strut brace so I will post a photo of it when finished.
#60
Installed today
The install went really quick and easy. I also only received 2 of the 3 screws. The two included screws were impossible to screw into the threads, but luckily I had three spare machine screws that fit perfectly.
Just finished the install tonight. No test drive till tomorrow morning.
ECSTuning (12-20-2018)
#62
#63
Lid Screws are M6x1.0 Allen Button Screw 10mm Length SS : 1 mm Pitch
Lid Washers are black M6 Nylon Flat Washer : 6.4mm ID, 12.0mm OD
Check in the bag , might have dropped into the box. Also inspect the box, might be at the bottom in a sealed plastic bag.
Thanks and those picture look great.
#65
#66
#67
First drive
I took a drive this morning and I did perceive an improvement in acceleration. My 2013 fJCW r55 just had a panel filter, not a cone filter. There was little to no audible difference that I could detect. It's hard to explain exactly what changed, but there was definitely a sense that the car was breathing with less restriction.
#68
jkapinos - yep it fits with the JCW Strut Tower Brace. It was marked in the item description.
#72
Please add to cart and then on checkout select the type of shipment you prefer. It should show you the cost. Free Ship is for contiguous US only.
http://www.ecstuning.com/Search/SiteSearch/ES2719002/
Note: This has not been test fitted to a Euro MINI or RHD, I know most items in the engine bay are similar, but I also know that some JCW models have a MAF blank tube ( 13710429383 ) and Cooper S No MAF at all, which is almost the same size length wise. On the US version the MAF connects to the upper tube via the silicone hose connection. So keep that in mind. Check out our install PDF and compare to your MINI , its linked on here.
#13 MAF Blank
No MAF at all. Some Euro Cooper S . Has Longer tube extension where the MAF would be.
If you have any other issues for payment on checkout please contact our customer service. customerservice@ecstuning.com and they can help more.
#13 MAF Blank
#74
Thanks for the info. Let us know how it goes.
#75
I just installed the ECS CF Intake on my R60S ALL4. Very easy install minus the lower intake tube as ra2fanatic pointed out.
I was working inside a garage after the car was warm and couldn't get it to work. I did the same...removed the stock tube and took a heat gun to it. Slipped in like butter after that. There was no way of getting the new CF lower tube to slip over the stock tube without removing and heating up.
Really nice looking intake. Will do some road tests later.
