Drivetrain Intercooler Moving Around?
Old Feb 19, 2014 | 11:55 PM
johntotah94's Avatar
johntotah94
I have a Helix intercooler and the only way it is mounted, I believe, is through the boost tubes right? I have the intercooler installed with an Alta Boost Tube. Since the boost tube is upgraded, the tube is not attached to the car like how it was on the muffler on the stock tube with the Torx bolt. I was under the car and I moved the alta tube back and forth and the intercooler was going along with it. Makes sense knowing that the only support is with the tubes. Did I do the install wrong? Just noticed this today. Lol
Old Feb 20, 2014 | 03:48 AM
madmaxxed's Avatar
madmaxxed
I noticed that you are running a solid torque arm which is causing lots of vibration. That could play a role in your problem. I'm running a helix with NM boost tubes and everything is nice and snug, no movement at all.
Sent from my iPad using NAMotoring
Old Feb 20, 2014 | 07:49 AM
Helix13mini's Avatar
Helix13mini
If your intercooler is installed correctly, it sits on the radiator support and is sandwiched by the bumper cover. It does not hang off the boost tubes. This is a myth that was started by a competing intercooler seller.
Old Feb 20, 2014 | 12:30 PM
johntotah94
I must have installed it wrong then. I basically took my old IC off and put the helix one on. And if I go under the car and move the boost tubes, the IC goes along with it. Has lots of play. I wonder what I did wrong..
Helix13mini
Jul 27, 2016 06:29 PM
Vaderm34
Sep 27, 2015 09:25 PM
daonlyillwiz
Sep 24, 2015 02:07 PM
5JCW6
Factory JCW Talk (2009+)
Sep 11, 2015 09:25 PM
Sep 1, 2015 04:39 PM
