Drivetrain Go Fast Bits DV+ Review
  #101
Old 10-20-2014, 04:49 PM
BattleTuning's Avatar
BattleTuning
BattleTuning is offline
Originally Posted by ptguy0618
Any update on the manual version? Or should I just get the way motor works one?
Funny that you would ask. Got an email from GFB this morning and they've made a few different brackets for us to try. So we will be getting those soon and we can test on one of our test vehicles. Should know more in the coming weeks.
  #102
Old 10-20-2014, 05:11 PM
ptguy0618's Avatar
ptguy0618
ptguy0618 is offline
excellent, I may hold off and wait for this one!
  #103
Old 11-28-2014, 09:48 AM
TerminalVelocity's Avatar
TerminalVelocity
TerminalVelocity is offline
Subscribed for news of a manual Tranny DV+
  #104
Old 11-29-2014, 01:24 PM
NewCooperFanatic's Avatar
NewCooperFanatic
NewCooperFanatic is offline
Ra2fanatic has been testing different brackets on my car. It's a bit of a process with all the pictures and back and forth sending of parts from Australia.
I'm sure one of us will update when a solution is found.
  #105
Old 11-29-2014, 10:48 PM
TerminalVelocity
What exactly needs to be changed for the manual N18 cars? I've read the entire thread and perhaps I missed it but unless the portion of the DV that bolts to the car is a lot thicker the whole system (GFB and OEM) looks the same as the OEM dv. What is a bracket needed for?
  #106
Old 12-03-2014, 02:18 PM
BattleTuning
Compared to the N14, the N18 version is a 2 piece system. The N18 manuals transmission housing is much larger than automatics.
The selection arm swings across (red arrow) and in 5th and 6th gear, would run into the DV.
Blue arrows would be where the 2 hoses connect and there is just no room for them either. The white piece was a CNC'd prototype GFB sent us for mounting and testing and it made no difference in this case. The bracket must be modified that would allow connection between the hoses and not deviate too far from it's harness connection.
GFB was finally able to attain a 6MT in Australia, so they're working on it internally on their end now. More to come later.
  #107
Old 12-07-2014, 12:46 PM
Indimanic's Avatar
Indimanic
Indimanic is offline
Just installed this on my 09 JCW N14. Worked great for 10 miles then no boost.
1/2 power light but no codes??? Took apart to inspect and cannot find anything unusual.
Checked all the obvious stuff; turbo, wastegate, vacuum, boost/pressure test in induction
everything checks out but no boost??? Any thoughts out there?
  #108
Old 12-07-2014, 01:19 PM
BattleTuning
GFB AU has found a solution. We should have N18 6MT version by early new year (at least that is what I've been told).
No definitive answer just yet about existing DV+ automatic versions as to whether they can be switched to 6MT versions or if they will be completely separate products from each other.
  #109
Old 12-07-2014, 02:30 PM
bmwr606's Avatar
bmwr606
bmwr606 is offline
Originally Posted by battletuning
gfb au has found a solution. We should have n18 6mt version by early new year (at least that is what i've been told).
No definitive answer just yet about existing dv+ automatic versions as to whether they can be switched to 6mt versions or if they will be completely separate products from each other.
hurry!
  #110
Old 12-07-2014, 03:47 PM
CPap's Avatar
CPap
CPap is offline
Originally Posted by Indimanic
Just installed this on my 09 JCW N14. Worked great for 10 miles then no boost. 1/2 power light but no codes??? Took apart to inspect and cannot find anything unusual. Checked all the obvious stuff; turbo, wastegate, vacuum, boost/pressure test in induction everything checks out but no boost??? Any thoughts out there?
I am having the same exact issue on my n18. It happens intermittently then goes away after some driving. Sometimes I get the half power mode, other times not and you see the loss or slow build up of boost. I pulled it out and am running the OEM diverter. All is well again. I inspected the GFB and saw nothing out of the ordinary. Not sure what's up with it. The only thing I can think is the brass piston is getting stuck but who knows.
  #111
Old 12-07-2014, 04:07 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
Did you oil the piston?
  #112
Old 12-07-2014, 04:17 PM
CPap's Avatar
CPap
CPap is offline
Yes. I did the first time I installed. Took it out to oil again about a month or so ago thinking it was the issue but no dice.
  #113
Old 12-07-2014, 05:38 PM
TerminalVelocity
This is concerning! Having to pull the DV to keep it oiled isn't something I'd look forward to considering how fun they are to get at in the first place. Hopefully a cause is found. Perhaps you really can't build a better mousetrap.
  #114
Old 12-07-2014, 06:48 PM
CPap's Avatar
CPap
CPap is offline
I don't believe it needs to be oiled regularly. I was just checking it at the time and re-oiled as precaution.
  #115
Old 12-23-2014, 11:19 AM
CPap's Avatar
CPap
CPap is offline
I would like to retract this ^ The issue appeared again after a while on the stock diverter. It turns out I may have a bad wastegate actuator. Going to pull it out this weekend. My appoligies to anyone who may have been swayed away from buying the product. It is a solid unit and will be installing it again.
  #116
Old 12-25-2014, 03:37 PM
TerminalVelocity
So are the N18 manual transmission GFB DV+ for sale yet? I'm reading comments elsewhere that they are but I'm not sure if they know there was an issue with these fitting manual tranny cars.
  #117
Old 01-17-2015, 02:32 PM
TerminalVelocity
Anyone?
  #118
Old 01-19-2015, 02:56 PM
BattleTuning
The 6MT version of the DV+ for N18 owners is not available still. Having finally gotten word from GFB directly the 6MT version will be slightly different than the automatic versions, so those that have an auto and intend to sell down the line are stuck with selling to only automatic and manual guys, the same.
This is due to the space restrictions found in the manuals. GFB AU is still waiting on prototype components, hence the current holdup on it's release. They've been waiting on these parts since Dec so I'll continue to update when I find out more details.
As soon as I get more details and a future beta piece, I will share more details to all.
Cheers,
BT
  #119
Old 01-19-2015, 06:41 PM
TerminalVelocity
Thanks BT! Exactly what I wanted to hear. Well not exactly. Was hoping to hear it was in production lol, but this is good news. Thanks again!
  #120
Old 06-11-2015, 12:22 PM
meental's Avatar
meental
meental is offline
anything new on the manual front? i have emailed GFB with not reply. wanting to upgrade my 13' JCW before i have issues with the stock one.
  #121
Old 07-07-2015, 11:14 PM
mini_aaron's Avatar
mini_aaron
mini_aaron is offline
No news yet for N18 6MT owners? I can't wait to have one into my car..!
  #122
Old 07-08-2015, 12:09 AM
meental's Avatar
meental
meental is offline
I reached out to GFB and apparently they can't get their hands on a n18 manual car in Australia. :( I'm about to just buy one and figure out my own mount.
  #123
Old 07-08-2015, 09:06 AM
ra2fanatic's Avatar
ra2fanatic
ra2fanatic is offline
You will sadly be disappointed when you can't figure out the mounting point. I'm surprised a solution hasn't been announced. Crazy.
  #124
Old 07-08-2015, 09:18 AM
rckrzy1's Avatar
rckrzy1
rckrzy1 is offline
Originally Posted by johntotah94
Didn't know the transmission affected the type of DV. I have a manual. So there is some more waiting to do lol.
shift linkage for a manual will hit the solenoid with the current auto bracket so I think they are making a new bracket for manual folks.
I noticed my boost stays alot higher during shifts, so a nice mod.
  #125
Old 08-08-2015, 07:18 AM
Mikli's Avatar
Mikli
Mikli is offline
Just want to pass a good message for the excellent customer service by GFB. I purchased a new DV+ Unit but during my install I noticed that one of the unit was missing some small parts. It was likely the U.S. dealer's fault but GFB in Aus step up and DHL the missing part to me directly. It was shipped within hours after my first email. I was hoping to maybe get a reply the next day but GFB answered me quickly. I'm very happy with their finish of their DV+ T9353. I can't wait to finish the last part of the install on Tuesday when the parts should arrive.
Quick Reply: Drivetrain Go Fast Bits DV+ Review
