Drivetrain Manic Motorsport brings us N18 owners OBD II Tuning! Solution is finally here!
Old Aug 18, 2015 | 12:28 PM
  #2001
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by DavidSR56
For those who are Stage 2, have you ever run an E85 mixture?
I run a Stage 3 and will soon habe my own Big Valve Head this week and I run 3 gallons of E85 and 11 gallons of 91, I also run 100% 500cc meth. The E85 is noticeable, convient and cheap, also I have a the newer Bosch fuel pump, found in the late 12' and up N18 motors. My AFR is 11.2-11.5 at 24psi and 16 degrees of timing. In many cases my IAT's are 100F lower than not having meth
Notice my YouTube video show 91f outside and IAT are 94F but one I hit 20psi, I drop almost 20F under ambient..Crazy!!
Old Aug 18, 2015 | 02:06 PM
  #2002
malibujoey's Avatar
malibujoey
Old Aug 18, 2015 | 02:14 PM
  #2003
Grizld700's Avatar
Grizld700
Thats the p3
Old Aug 18, 2015 | 10:43 PM
  #2004
Gearheadaddy's Avatar
Gearheadaddy
Octane
Agbullitt25, I for one appreciated your post on octane. Thank you.
Old Aug 20, 2015 | 11:11 PM
  #2005
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by malibujoey
What gage give you that internal temp? Thanks! Cool video!
Thank you,
The gauge is a P3 and it matches the orange Mini interior perfectly. I love hitting high boost and seeing my IAT's below ambient temps.
Mario
Old Aug 21, 2015 | 08:52 AM
  #2006
Indimanic's Avatar
Indimanic
At what boost level do you start injecting the meth?
Are you worried the E85 is harsh on HPFP and main delivery FP? I guess not a huge deal to change out. I was concerned myself but started running the E85 also.
Old Aug 21, 2015 | 09:00 AM
  #2007
Indimanic's Avatar
Indimanic
Seems like some folks like to get nasty especially when one questions their position.
I think one needs to always look at the source(s)
Here, again an article from Sunoco. They might know a little more that the weekend hobbyist mostly found here.
Gas and fuel are interchangeable terms. See the title of the article please...and the quote contained within the article.
I would tend to trust this source.
http://www.racegas.com/article/10
To quote Sunoco,. which I use in my race car
"You might be surprised to learn that some of the highest octane fuels may also be some of the fastest burning fuels!"
Seems like some thoughts given here are debatable but mine would be not to give up their day job unless they works in the automotive repair biz, then one really needs to reconsider......
Old Aug 22, 2015 | 12:02 PM
  #2008
Gearheadaddy
A Top Fuel Dragster runs Nitromethane...faster burning higher octane fuel but I really don't think that we can use Fuel and Gas as an "interchangeable" term here in this case. In generalities I guess we can use "gas" and "fuel" as interchangable terms but you sir have quoted an article that clearly states "RACE GAS" ... NOT PUMP GAS.
Old Aug 22, 2015 | 01:05 PM
  #2009
malibujoey's Avatar
malibujoey
Old Aug 22, 2015 | 01:56 PM
  #2010
Systemlord's Avatar
Systemlord
I believe when the member was told that higher octane (91-93) gasoline burns slower, he immediately starting focusing on faster burning racing fuels which doesn't have anything to do with higher octane (91-93) pump gasoline which was what we were talking about originally. It was a bit off topic and misleading that may have lead to other member's being confused, it's good that a few member's set the record strait though.
Old Aug 23, 2015 | 01:29 PM
  #2011
malibujoey's Avatar
malibujoey
Old Aug 24, 2015 | 01:42 AM
  #2012
Indimanic's Avatar
Indimanic
Here's a great article on fuel/gas/race gas and snake oil
http://www.2strokeheads.com/tech-octane-detonation.htm
it's important to understand for those who are running high boost tunes
As for E85; I noticed with just a 15% mix my fuel trims were way high as would be expected and since it burns way hotter I wonder about it's application in our engines either on the street or track. It takes just a few seconds to burn up a piston cylinder wall and/or exhaust valve. Modifying is a very slippery slope and one must recognize all the important deleterious consequences of not covering all the bases. If one is getting a serious tune, the fact is the motor needs a more serious fuel.
Manic is concerned about the fuel here in CA and has to limit certain parameters in the tune unless one can get the correct "fluid" in the tank.
Old Aug 24, 2015 | 02:30 AM
  #2013
cerenkov's Avatar
cerenkov
...since it burns way hotter....
Maybe I'm misreading this but ethanol burns at a lower temperature than gasoline. If you are leaning out the engine then it will be hotter but that will only happen if the trims are max'd out.
Old Aug 24, 2015 | 02:33 AM
  #2014
Systemlord's Avatar
Systemlord
Does the higher octane fuel burn at a slower rate than lower octane fuel? IMO.. MAYBE, SOMETIMES, YES, and NO.. See above.. the rate of burn is dependant on many variables but to state that just because the octane is higher, then the burn is slower, is 100% incorrect.
Don't believe me?? Why should you? there are countless articles contradicting what I just said.. Well.. see an interview from the Sunoco Engineer below (I will highlight the best parts LOL)
Nobody said higher octane pump gas (91-93) burns slower because it has a higher octane rating, there are other factors at play. Way to many variables to be 100% about anything in that link, that link is all over the place! The author doesn't seem to be sure of anything and to boot quotes an article from 1998, 16 years ago and we're back to Sunoco again saying that their GT PLUS 104 octane unleaded race gas is only 15-20 percent traditional gasoline and about 85 percent additives! I'm sorry I mean 120 different chemicals. The talk of high octane gasoline started out about higher octane pump gasoline and has now spun off topic and spiraling out of control IMO.
I believe it might be time to create another thread on gasoline/fuels because this thread is about Manic Tuning and I don't think it's fair to flood it with gasoline versus racing fuels. That's just my opinion though.
The only thing I liked about 1998 were the gasoline prices!
Old Aug 24, 2015 | 07:52 PM
  #2015
Indimanic's Avatar
Indimanic
ethanol can burn cooler and produce more power, in reality, we end up burning as much ethanol as possible to get max power. This results in higher cylinder temps than gas
I watched temps on 2 identical engine from the cylinder heads and the E85 burned some 160 degrees hotter. Understanding fuel is vital to having certain Manic tunes dot heir thing properly. Consumers need to know this. If they did, perhaps they would not be buying new engines as often. People need to look at the totality of what they are trying to accomplish. FMIC, DP's, ignition systems, and fuel. To say not knowing what one must put in their tank is careless and dangerous. B
Old Sep 17, 2015 | 08:47 AM
  #2016
CMS3086's Avatar
CMS3086
Got a revo SPS,
Any idea is it same with Manic SPS...
and use revo SPS to switch Manic Between Map A and Map B.
Old Sep 17, 2015 | 03:16 PM
  #2017
minivinnie92's Avatar
minivinnie92
No you cannot I have tried
Old Sep 17, 2015 | 03:57 PM
  #2018
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by CMS3086
Got a revo SPS, Any idea is it same with Manic SPS... and use revo SPS to switch Manic Between Map A and Map B.
Physically the same but that dongle is used and programmed for multiple car manufacturers.
mQubed Motorsport, Manic Tuning Dealer
Old Sep 18, 2015 | 09:15 PM
  #2019
Ovrclck's Avatar
Ovrclck
Old Oct 13, 2015 | 08:50 PM
  #2020
wzabrouski's Avatar
wzabrouski
Before I ran meth, I ran 3 gal of e85 and topped it off with 93. 3 gal is the max you should run.
Old Oct 27, 2015 | 08:22 PM
  #2021
Ovrclck's Avatar
Ovrclck
Question, is it normal to have a rich exhaust smell when running manic? I thought it was my catless setup. Added catted dp and still very gassy smell. Doesn't matter if idle or not. I'm having to run stock map because of it. Any ideas?
Old Oct 28, 2015 | 02:18 AM
  #2022
cerenkov's Avatar
cerenkov
I have a high flow cat with no exhaust smell. I rode in a catless setup last week and it was barely noticeable.
You may have an exhaust leak. Check/replace the v-band clamp.
Old Oct 28, 2015 | 03:07 PM
  #2023
Ovrclck's Avatar
Ovrclck
I already went to an exhaust shop and didn't find any leaks. If there was a leak, it definitely would be noticeable on stock map, right?
Old Oct 28, 2015 | 05:13 PM
  #2024
cerenkov's Avatar
cerenkov
A leak would be on all maps.
From my logs, the Manic maps are richer at WOT compared to the stock map. During partial throttle driving, my AFR gauges bounces around 14.7, which is what you'd expect.
Do you have a way to monitor AFR?
Old Oct 28, 2015 | 06:17 PM
  #2025
MarioKart's Avatar
MarioKart
Vendor
A leak would be on all maps. From my logs, the Manic maps are richer at WOT compared to the stock map. During partial throttle driving, my AFR gauges bounces around 14.7, which is what you'd expect. Do you have a way to monitor AFR?
True, my AFR at 6500 is 11.3 on 24psi, stock at 16psi was 12.5 and 12.9 with a JB+ I haven't spent time adjusting my AFR and timing for my new big valve head/full port. Even at 10 AFR I don't have smell issues and I'm complete catless. I need to get my car adjusted, my AFR and timing are in the super safe zone, I have to force my self to stop driving my M4 mQubed Motorsport, Manic Tuning Dealer
Attached Thumbnails Manic Motorsport brings us N18 owners OBD II Tuning! Solution is finally here!-image-2539410813.jpg
