Drivetrain Manic Motorsport brings us N18 owners OBD II Tuning! Solution is finally here!
Old Aug 14, 2014 | 07:12 PM
  #576
ThumperMCS's Avatar
ThumperMCS
lol....can't wait till people start popping N18 motors....blown piston threads are coming, just a sneaking suspicion
At 22 psi, its not if....it's when...trust me
Old Aug 14, 2014 | 07:15 PM
  #577
wzabrouski's Avatar
wzabrouski
Originally Posted by ThumperMCS
lol....can't wait till people start popping N18 motors....blown piston threads are coming, just a sneaking suspicion At 22 psi, its not if....it's when...trust me
Don't worry I don't plan on ever touching 22psi.
Old Aug 14, 2014 | 07:26 PM
  #578
wzabrouski's Avatar
wzabrouski
Originally Posted by MarioKart
Those sound like my boost levels on my GP with FBO. What model is your Mini, turbo and bolt on's.
R60, stock turbo, intake, downpipe, exhaust, intercooler, meth, etc.
Old Aug 14, 2014 | 09:04 PM
  #579
EuroTechsAZ's Avatar
EuroTechsAZ
Did they tell Nick you were a JCW? I've only seen the 22psi target boost map on JCW or hybrid turbos maps. Most our stage 2 cars on MCS turbos have boost targets of 1.4 even with meth or race gas.
Old Aug 14, 2014 | 09:18 PM
  #580
doug@frankenturbo's Avatar
doug@frankenturbo
Originally Posted by cerenkov
I'm curious as to where on the compressor map you are at 22 psi. Assuming that you have the stock turbo, I'd imagine that you'd be putting out a bunch of heat. Can the engine handle 22 psi, reliably?
EDIT: Here's a compressor map that I got from Frankenturbos website. So at 22psi, your pressure ratio is 2.5, now I wonder what your flow rate is? Assuming a VE of 90% then I'm getting 26 lb/min at 6000 rpm. That puts you pretty far out there on the map.
For clarification: That graph is represented in absolute pressure. So 1.0 = ambient. Add to that value 1.5 of pressure and you get 2.5bar, or the 22psi being talked about.
But remember these compressor maps are created under ideal circumstances. The testing equipment would have a 100% flow efficiency, while a turbocharged motor does not.
Lastly, and most importantly, when people cite a given boost level it's almost always referring to a mid-rev range spike. Not to the pressures recorded at anywhere near red line. The stock K03 is good for perhaps 14psi at 6500. 22psi is for the lower end of the scale only.
Old Aug 15, 2014 | 12:21 AM
  #581
johntotah94's Avatar
johntotah94
Originally Posted by MikewithaMini
I apologize if this has been answered some where in 24 pages of this thread. Good thing there's no interest! Haha.
So...I have an '08 S nearing 100K and runs great. I have a JCW dealer installed tuning kit and a Helix intercooler and the usual piping cleanup done, stock S turbo. What tune level would be spec'd and what might the expectation be of performance improvements? Can anyone quesstimate an "is it worth it quotient"? Thanks.
If you get a catless down pipe you will be in Stage 2 territory.
Stage 2 is basically down pipe and intercooler with a tune. With Stage 2 your looking at between 230-250hp crank. Without the down pipe you are looking at a Stage 1 tune for manic. Manic is for 2006-2014 Mini Coopers (N14/N18). You will not regret the tune if you decide to get it. Whole different car. Much worth the money.
Old Aug 15, 2014 | 05:10 AM
  #582
wzabrouski's Avatar
wzabrouski
Not that I am aware it. I actually filled out all the paperwork showing my mods, myself.
Old Aug 15, 2014 | 11:29 AM
  #583
EuroTechsAZ
I went and double checked the files we used and looks like there was a stage 2 MCS with 1.5 boost target pressure on meth. Enjoy!! Most our cars daily drive on the 1.4 map and it is a lot of fun. We will be dyno testing all the cars this winter so will have solid whp numbers on most combos.
as for boost loss at higher rpm... On the JCW cars we tested there is no spike , Nick gets rid of the overboost spike most cars have or experience when using other tuning options. the Dyno sheet I posted in the sticky shows N18 JCW pulling 22psi and stays very close to ~21 psi all the way to redline.
Old Aug 15, 2014 | 11:55 PM
  #584
johntotah94
Just got my K04 E45R. Hope to get it installed soon, get retuned, and post some numbers for you guys.
Old Aug 16, 2014 | 01:08 AM
  #585
MarioKart's Avatar
MarioKart
Vendor
Nice, you will like the K04 much more over the K03
Old Aug 16, 2014 | 02:01 AM
  #586
Club77's Avatar
Club77
Can this NGK ILKR8E6 Laser Iridium spark plug use on N18 engine, isit a cooler plug compare to the stock plug? Thank you
Old Aug 16, 2014 | 06:26 AM
  #587
jkapinos's Avatar
jkapinos
The stock plug is a BERU 12ZR-6SPP2-1 R6
Old Aug 16, 2014 | 03:36 PM
  #588
MarioKart's Avatar
MarioKart
Vendor
This is what I use, bought them at the Mitsubishi dealer. So far so good with 23psi and 10.5 timing.
Old Aug 16, 2014 | 03:59 PM
  #589
doug@frankenturbo
Simultaneously?
Old Aug 16, 2014 | 05:24 PM
  #590
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by doug@frankenturbo
Simultaneously?
Yes. Depending on the conditions 19.5psi to 8-10.5 degree
I have a screen shot of my Torque App a few post up
Old Aug 16, 2014 | 05:29 PM
  #591
doug@frankenturbo
At what engine speed are you recording 19.5psi and ignition timing like that?
Old Aug 16, 2014 | 05:32 PM
  #592
MarioKart's Avatar
MarioKart
Vendor
at what engine speed are you recording 19.5psi and ignition timing like that?
6200
Old Aug 16, 2014 | 05:34 PM
  #593
cerenkov's Avatar
cerenkov
Doug don't forget that Mario has a GP2
Old Aug 16, 2014 | 05:35 PM
  #594
doug@frankenturbo
6200
Is this with a stock K03-106 turbo on California 91oct? Or on the E85 blend you list in your signature?
Old Aug 16, 2014 | 05:37 PM
  #595
doug@frankenturbo
I missed that in the signature. What airflows do you see at that point in the rev range?
Old Aug 16, 2014 | 06:22 PM
  #596
MarioKart's Avatar
MarioKart
Vendor
Temps?
Old Aug 16, 2014 | 06:26 PM
  #597
doug@frankenturbo
Temps?
Hehe. Sorry, I wasn't being specific. Thanks for your patience with me but I was referring to airmass. That's the single statistic that informs my company's existence: how much does it flow?
Old Aug 17, 2014 | 01:24 PM
  #598
wzabrouski's Avatar
wzabrouski
Anyone with an automatic have an issue getting their tune flashed? Or has anyone had any issues getting flashed?
Old Aug 17, 2014 | 06:03 PM
  #599
R53Warrior's Avatar
R53Warrior
I'm really looking forward to seeing these numbers. K04 and tune are my mid-term plans
Old Aug 19, 2014 | 06:46 PM
  #600
cerenkov's Avatar
cerenkov
Did you have problems getting yours flashed? I have heard that a small percentage of cars for whatever reason do have issues and the case has to be opened.
