Drivetrain Standard motor 380CC injectors
Pretty much, MANY people have done the same as you and never anything more, you should be fine.
If you're worried about it either limit your high rpm driving (above 6400) to short bursts, not sustained like track situations or find somewhere to have the AFR checked.
I'll try to find it, but I found a post from a member who was running the common mods: Intake, 15%, exhaust (stock injectors). He happened to run an AEM wideband and found that he was running 11.2 - 11.5 AFR @6200 RPM, which in my past experience is perfect for safe power. To make things even more interesting, the point of his thread was that he had just installed 380cc injectors, and was posting his impressions. He noted that with those same mods + 380cc injectors, his AFR moved to 10.5. This is fine, as it's not so rich it's hurting anything (except power), but it's not ideal.
My next purchase is going to be a Wideband, so I can corroborate these AFR findings, and put to rest people's claims of being lean.
I seem to be finding the same information that you guys are. Lost of people seem to be pushing the 380cc, 440cc, and eve 550cc injectors. I wonder how much of that is just marketing, how much is "I'm cool because I have huge injectors", and how much is just people doing it because that's what they read on the internet.
Not saying it's "safe", or that it's not right at the limit of the stock-S 330cc injectors.....but there are guys over at MT that I've seen have all kinds of mods (cam, head, 17% pulley, header, exhaust)....and have made lots of power with the stock S injectors. Not saying a bigger injector and a custom tune wouldn't be safer, and give you more room for error......but it sounds like you can make a lot of power (250hp+) with the stock S injectors and still be just fine on a stock tune.
A wideband AFR gauge is the best way to determine where you're at. I've had them on all of my other forced-induction cars, and have just been lazy with this one. Considering the amount of money we spend on modifications for these pricey little buggers, spending $160 on this gauge should be a no-brainer.
I am running the Innovate MTX-L they can be had all day for 150 and you can log with this unit.
http://www.ebay.com/itm/Innovate-MTX-L-Digital-Wideband-WBO2-Air-Fuel-Ratio-AFR-Gauge-Kit-3844-/281238957231?pt=Motors_Car_Truck_Parts_Accessories&hash=item417b25ecaf&vxp=mtr
No affiliation - I bought mine at Real Street performance as they are local to me but also a seller on eBay.
None of them are really expensive. Both AEM and Innovate are ~160 for everything you need, except the labor of welding a bung into your exhaust. Also, pretty much all of them can datalog, granted you have the software to do so. Zeitronix is the most expensive, but also the most tech out there ($275). I'd just grab an LC-1 or UEGO for $150, and call it a day.
The 440's & 550's are definitely for BVH + cars, while you can certainly use them on lesser modded cars, with a BHV you are circulating considerably more air & you really should have the fuel to match, but yes even with aBVH you can use the 380's you'll just want to have it tuned properly and heed any warnings from your tuner.
With my setup, my 550's run about 85% at their peak, so in the range of 465cc (I know that's not exact, but you get the idea) but that's also w/ 20ish psi of boost.
^ And that's with a Sprintex, pulley, ported manifold, and high-flow head. Beyond PSI alone, you're moving much more CFM compared to a car running a stock head, Eaton M45, and comparable boost. On a car like that, IDC's would be considerably lower.
Yup, I originally did my BVH with the stock JCW exhaust and tuned for the OEM JCW's (380's) were fine with a7k red line, out was the addition of the Header that put me right on the edge, but that was also with the JCW pulley & M45.
I was out today to see a friend, and he just got his RMW 550cc Injector kit, these injectors are short and require an adapter, but here is a photo of the units:
I think its a Chrysler part. Look at the emblem at the top.
probably i can see it ill photoshop the nmbers thta have been painted over o see what they really are. BRB
They are out of PT Cruiser Turbo's those are like dirt common!
http://www.ebay.com/itm/like/190994819462?lpid=82&item=190994819462&vectorid=229466
cant make out a few numbers to well in Pshop. but googled the other numbers and i come up with other 46lb/h injectors that appear to have the same number that is covered up. and that would be 4891574AB (but there appears to be another number almost like an 11 in front of the 4891574AB and the B looks like a D which are other injectors)
