Drivetrain Koni SA install, there's a lot of popping!!!
Old Apr 10, 2004 | 12:17 AM
OasisT's Avatar
OasisT
The title says it all. After my Koni SA's were installed, by a professional shop, and an alignment was done, there is now some loud popping when going over slower bumps and some turns. The popping/snapping mainly comes from the drivers front side strut, and ocassionally from the passengers rear side.
I assume this is not normal and they probably didn't set the lock washers properly or something. I have no luck with suspension, when I had my jeep lifted, I had to re-tighten the shocks every week or so because they kept coming loose.
Or, is it just settling in?
Its obviously the weekend so I cannot take it back until Monday morning. Any ideas???
Old Apr 10, 2004 | 05:33 AM
ThumbsUp's Avatar
ThumbsUp
Having just done the Koni install, I can make a guess as to the source of the popping. I'd guess that the upper spring seat is not indexed to the top of the spring or the rubber that sits between the spring and the seat was left out. The spring seat has an indentation that should match up to the top coil of the spring. Since checking this requires the strut to be removed and then requires a spring compressor to disassemble and check, I'd take it back to the shop.
_________________
Life is too short to drive boring cars!
Visit Greg's Toys
Old Apr 11, 2004 | 02:35 AM
pocketrocketowner's Avatar
pocketrocketowner
I'm guessing the mechanic installed the small retainer washer that holds the bump stop on upside down, the bump stop is thus rattling up and down......take it back......
Old Apr 11, 2004 | 06:53 AM
kenchan's Avatar
kenchan
Yah, or, they may have forgot to put in that washer entirely...
Are those coils progressive rate or linear rate?
I gotta feeling that there is some play between the top spring hat
and the mount.
_________________
03MCS IB/Bk: 123, Aerokit, 17"R90, Milltek, Pilo Intake, H-Sport, 6CDMP3, etc.
Old Apr 11, 2004 | 10:29 PM
OasisT's Avatar
OasisT
Thanks for the input guys. I'll take it back tomorrow. I had a quick look at both sides, everything seems very secure and installed properly from what I can tell but I don't weigh 2500 lbs like the car does so I guess me tugging on it is not much help. I'll post results as I find them out tomorrow to Tuesday.
Old Apr 12, 2004 | 10:25 AM
BlueMCS's Avatar
BlueMCS
Additionally, he could have left out the top washer that goes under the strut bolt. If left out the nut will seat but there will be play in the shock shaft.
Bottom line: I have checked this and the other suggestions on my car with Koni's and H-Sports and they still pop. I think that it is in the shock.
Old Apr 12, 2004 | 11:07 AM
kenchan's Avatar
kenchan
Do the KW's pop? Those are Koni's under stainless shell, correct?
Old Apr 14, 2004 | 01:30 AM
OasisT's Avatar
OasisT
OK, everything is perfect now. The Ball Joint was a bit loose, apparently he only torqued it to 60lbs which was causing the popping initially. Today, the poppingturned into an occasional more severe pop, with some bump steer. When I accelerated, the car would shift the steering to the right, when I let off, it would go back to the left. So, I dropped by the mechanic again and he immediately fixed the problem with a quick tightening of the ball joint on the drivers front side.
All is now good and well. I'll give a performance update on Sunday after the autocross event but she seems to be handling like a cheetah!!!
adrchn
Aug 13, 2019 02:11 AM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
squawSkiBum
Oct 2, 2015 09:21 AM
Emnotek
Aug 13, 2015 05:47 PM
