Drivetrain PCV Tube Removal (w/ pics)
I thought I would share what I did last weekend. I added a Catch Can and Boost port last year to help reduce the carbon build up on the valves. I only use the boost port to block off the PCV tube.
I was working on the car recently and cracked the PCV tube by accident. I did a temp fix by wrapping it in tape until I could find a better solution. I didn't want to buy a new tube as I wasn't using it, so I stumbled across this cap that works perfectly.
I purchased qty 2 from ECS Tuning. It's a VW part, but when I called the local dealer it was a special order and their price was much higher.
PN: 274329, $9.90/ea. Total order was ~$30 after shipping.
http://www.ecstuning.com/Search/ES274329/ES274329/
Here is what I started with. You can see the boost port as well as the tape a little further down the tube.
I removed the airbox which gave me enough room to remove the stock tube. It was easiest to snake it out the bottom under the intake manifold.
Then it was just snapping the caps on the connections.
Here is the bottom connection under the intake manifold.
The Top Connection.
I was never a fan of the boost port just because I was only using it as a plug and not for it's intended purpose.
Just an idea for those out there wanting to add only an Oil Catch Can and looking for a way to block off the PCV tube. The only tools I used was a flat screwdrive and torx bit to remove the airbox. Really easy.
If anyone is interested I'm selling my BSH dual boost port (http://www.waymotorworks.com/bsh-boost-tap-r56.html). PM me with a reasonable offer.
The Top Connection.
I just feel like on the long run I think there is going to be problems. I am replacing my valve cover next weekend and I will he able to see if there is any issues.
I'm still not understanding the reasons for adding the hose back in, even with an OCC.
The new mini's have the revised valve cover which doesnt have the rear PCV tube. I cant think of any technical reason why the removal of the hose connection would do any long term damage. The cover still has the connection feeding the turbo, which the catch can should capture most of the residue as well as relieve any pressure related issue.
I'm not saying its a bad idea, just would like to see some technical explanation.
The reason I am thinking of running another can is because I think that I am just blocking it off and it building up behind the block off because I am not seeing any more out put on the other side but, I am seeing an increase in oil consumption. It is most likely from blow by but, hell it just might be from the fact that I have a leaky valve cover or my oil turbo line might be crapping the bed. I will find out when I pull the valve cover off next weekend.
The VW part no is 036131510.
So whats the verdict?
I don't really care what the new technical update is I am still driving a 2007 with the N14 so I still have to worry about it.
Second question: Nope, but I do remember they did say "Are you sure they're the right part, they're just caps"
I did think of ordering from ECS, but shipping for just caps were too much since I didn't need anything else to go with it.
Sent from my iPad using NAMotoring
First question: Yes I did.
Kimolaoha
07-05-2023 01:04 PM
09R56
11-16-2022 10:49 AM
Drivetrain Help on MAF Sensor Clip - Cannot Remove
Motown
04-20-2018 09:31 AM
ltjpunk7
09-06-2015 07:32 AM
