Drivetrain Picture please of helix ss installed.
Old Feb 10, 2004 | 11:24 PM
bleecker's Avatar
bleecker
I would really like to see a picture of the helix ss installed in a mcs.I want to do it ; but i am not sure if we loose the boot cover.I would like to keep it if possible.Thanks for the help.
Old Feb 10, 2004 | 11:33 PM
DaKineMINI's Avatar
DaKineMINI
When you say "boot cover" you mean the tan plastic dust cover right? If so, it is removed because the SS extends downward past the cover. I had the Helix SS installed by Erik when he came to Hawaii for our pulley party. Do you still need photos? If no one posts, I can take photos tomorrow and post for you.
Old Feb 11, 2004 | 12:23 AM
bleecker's Avatar
bleecker
Thankyou for your response.Yes iwould really apppreciate a photo. thanks again,bleecker..
Old Feb 11, 2004 | 03:23 AM
aokdoug's Avatar
aokdoug
is ther a helix s/s how-to? i can't find one.
also other post have said that sheild isn't a
big factor unless you drive on real crappy roads
doug
Old Feb 11, 2004 | 04:21 AM
OzMini's Avatar
OzMini
I have just had the Helix short shifter installed. The shifting action is not only shorter but more sure. Before I would occasionally put the car into reverse instead of first but this is now nearly impossible to mistake. I like it a lot
The speed shop that did the install (they were doing the pulley for me too) confirmed that the area underneath is extremely well protected already with the long heat shield.
Cheers
Old Feb 11, 2004 | 11:59 AM
SynergyONE's Avatar
SynergyONE
I did the Rogue short shifter which is very similar to the Helix. Straightforward install, as I installed the Milltek cat back at the same time so I already had the exhaust removed for access. The heat shield appears to offer sufficient protection.
Dave
Old Feb 11, 2004 | 12:59 PM
DaKineMINI's Avatar
DaKineMINI
bleecker,
I forgot about the heatshield! I just jacked-up the car and crawled under to take some shots for you but you can't see the area of concern because the heatshield that OzMini and SynergyONE refers to completely covers it. Sorry but I don't want to take-on removing the exhaust portion and heat shield for the photo.
Dirk
Old Feb 12, 2004 | 12:42 AM
bleecker's Avatar
bleecker
Dirk-Thanks for your efforts.I do appreciate it.I will give Eric a call and ask him about the details on the install.Mini people are class acts.-bleecker
Old Feb 12, 2004 | 09:06 AM
vdubdoug's Avatar
vdubdoug
Here are some pictures for yah:
With out the shifter installed:
With the short shifter installed:
Old Feb 17, 2004 | 11:44 PM
jmoser's Avatar
jmoser
Doug, thanks a ton for the pics--just what I've been looking for, before I dig in.
thanks again Jenni
Old Feb 18, 2004 | 05:05 AM
d2mini's Avatar
d2mini
Awesome pics!
Thanks :smile:
Old Feb 18, 2004 | 11:09 PM
Coopertino's Avatar
Coopertino
I have this installed and it works great. The complaints I have are:
1. 6th is a bit sticky now but may just need to work in a bit
2. Since the cover plate will no longer fit I have extra road noise.
Other than that the throw is great.
Maybe the cover can be modified a bit , a small hole is better than a huge hole.
_________________
Willis
Filmy
15
Jun 6, 2023 06:27 AM
Grizld700
Sep 15, 2015 05:34 AM
OutMotoring
Sep 8, 2015 06:27 AM
bbak11010
Sep 7, 2015 08:08 PM
bbak11010
Sep 7, 2015 08:03 PM
