Drivetrain Brisk racing plugs in stock '10 turbo
Old May 24, 2011 | 04:20 PM
MiniPHan's Avatar
MiniPHan
I have 52K on the original engine with no mods, til now.
I boughtBrisk racing plugs and gapped as close to 0.020 as I could -(the very end of my gapping tool). Recommended gap by Brisk is 0.018-0.020"; when I finished and went on a test run the engine sputtered at 4500-5000 and then the check engine light came on briefly. Should I double-check my gap and get it closer to 0.018: or is there something else I'm missing. The trouble light went out after a second run and the engine seemed to be a bit smoother - especially when it got over 5K; but it still sputters on hard acceleration - suggestions ?
Old May 24, 2011 | 05:04 PM
czar's Avatar
czar
Reduce the gap to 0.40mm (0.016 thou)
Old May 24, 2011 | 06:59 PM
jcauseyfd's Avatar
jcauseyfd
I'm having a similar issue after installing some Brisk plugs. I've got mine gapped as close to .018 as I could get. Since installation, I've noticed a little bit of wandering at idle (e.g. at a stop light). During MOTD, I noticed I was getting like a skip or sputter under heavy acceleration loads.
When I have time I plan to put the old plugs back in to see if that will help me verify whether it is the new plugs or something else. Might have to try reducing the gap some more.
On the plus side, I feel like the plugs have given some extra pep to the MINI and I am definitely getting better gas mileage.
Old May 24, 2011 | 08:02 PM
MiniPHan's Avatar
MiniPHan
hey czar
Thanks for the quick reply; I'll definetely close the gap --THANKS!
Old May 24, 2011 | 08:04 PM
MiniPHan's Avatar
MiniPHan
Thanks jcausefd!
I'm pretty sure that it's the plugs because that was the only change. Even with the hesitation & sputter the Mini does seem quicker.
Motor On!
Old May 25, 2011 | 06:36 AM
countryboyshane's Avatar
countryboyshane
Why bother changing them to another brand? The OEM NGK's work perfectly well.
Old May 25, 2011 | 08:24 AM
Boosted_Mini's Avatar
Boosted_Mini
Brisk plugs are silver
NGKs are iridium
Silver has higher thermal and electric conductivity.
Old May 25, 2011 | 09:42 AM
jcauseyfd's Avatar
jcauseyfd
Same reason I drive a MINI - wanted something different.
Old May 25, 2011 | 10:54 AM
killerfox's Avatar
killerfox
I installed the brisk plugs about a year and half ago before I had Jan tune my car and he found that the plugs didn't seat/seal well and I was getting some blow by. I put the stock plugs in and have had no issues. I would stay with the stock plugs.
Old May 25, 2011 | 05:59 PM
countryboyshane
Exactly!
Old May 25, 2011 | 06:01 PM
Raymazing's Avatar
Raymazing
thermal conductivity and electrical conductivity is higher... what about melting point? silver is 1763.474 F whereas iridium is 4370.0 °F. The silver will break down and be burnt off long before iridium.
Old May 30, 2011 | 05:40 PM
jcauseyfd's Avatar
jcauseyfd
Just a follow-up. I finally got around to swapping back in the old plugs. That did eliminate the stutter I was experiencing, so looks like my problem was definitely the plugs.
I tried to gap the Brisks down to as close to .016 as I could get and I've re-installed them. Rather difficult as the difference between say .016 and .018 is so small. Will give this a try and see what kind of results I get.
Old May 31, 2011 | 05:57 PM
MiniPHan's Avatar
MiniPHan
So I closed the gap as suggested to the .016 ( close tolerances ) and the sputter & hesitation went away. Is it better performance-wise? I dunno; I DO know that I didn't pay as much for these as what Mini wanted for OEM replacements.
09R56
Nov 16, 2022 10:49 AM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
W0TM8
Dec 19, 2019 07:50 AM
tr3y003
Oct 22, 2015 10:48 AM
rckrzy1
Aug 11, 2015 06:06 PM
