Drivetrain If you haven’t had an RMW update lately, you may want to look into it. : )
Old May 13, 2011 | 07:20 PM
  #201
etalj's Avatar
etalj
Originally Posted by turtle343
i was at work so i couldn't check the email. the problem was me not loading the file properly . now i have it loaded all i can say is anyone with out a RMW tune needs one!the power gain is amazing. driving the car feels like you are in a lower gear than you selected e.g. 3rd feels like 2nd. the low and midrange torque just throws you back and then it pulls hard all the way to 7000RPM. that's not even in sport mode once i pressed sport it was even crazier. mid range pull was just insane. there is no need to downshift on the highway to overtake, in 6th gear going 80kmph just floor it and it just pulls! i love it and i just can't stop driving now. i am so glad i got this tune and it was the best mod i have done to any car. it also got rid of my increased emissions CEL which is great.
i cant recommend it highly enough
Told ya!
Old May 14, 2011 | 11:12 AM
  #202
Bigprfed22's Avatar
Bigprfed22
Just got my dyno done... man the remote tune was spot on regarding afr's! Jan was able to get another 5lbs ft out if it and make the throttle more linear. A good amount of runs were done but it was almost straight on from the remote tune.
Dynojet Research dyno(humbled me )
Spinning those hugh rollers netted out a whoping 203whp and 227ftlbs!! These numbers are low per the dyno, those who know, know where to make the comparison.
Similar modded and some modded w dp's netted around 180-190whp and 210 trq on this dyno so were above the curve by a lot!
Jan,
Finally good to meet you in person and had a good time talking the techno jargain with ya Time to shape this place up and get things moving!
Videos to come. youtube search "machv" for similar dynos... for exp. my mini netted the amount of wtq from a 2004 m3 stock... we're movin!
http://www.youtube.com/watch?v=KL8gON5pmXw for reference on the same dyno 2006 s2k.
http://www.youtube.com/user/MachVDan#p/u/74/LyzKSbjgVDs similar modded +dp mcs
Old May 14, 2011 | 03:37 PM
  #203
FUBSZ's Avatar
FUBSZ
From reading all your posts , I really want a tune now :D , how can i get the tune ? please tell me . I have an Access port.
Old May 14, 2011 | 03:56 PM
  #204
Bigprfed22's Avatar
Bigprfed22
Contact Jan from RMW. With the access port you can data log and he should be able to give you a remote tune. The Alta "stage" packages just dont compare in my opinion and i have experienced both. Its the best money you will spend power wise
Old May 14, 2011 | 05:57 PM
  #205
akng's Avatar
akng
Does it make a difference whether I buy the AccessPort from Alta or Jan? Would it be best to buy it from Alta then have Jan tune it? That way I can get service from both sides if anything happens even if Jan is too busy, am I correct? Please advise. Thanks!
Old May 14, 2011 | 07:00 PM
  #206
FUBSZ's Avatar
FUBSZ
i PM'd RMW on the forums but i still havent gotten i reply yet .
just to make sure is RMW jan ?
Old May 14, 2011 | 07:15 PM
  #207
MotorMouth's Avatar
MotorMouth
yep.
Old May 15, 2011 | 01:38 AM
  #208
Nimrandir's Avatar
Nimrandir
Is there any tune for european countryman S ?? i want something i can put & remove to not avoid the warranty
Old May 15, 2011 | 02:31 AM
  #209
etalj's Avatar
etalj
Jan,
this is a good omen for me, i spent $400 on a data logging tool
Old May 15, 2011 | 06:50 AM
  #210
Bigprfed22's Avatar
Bigprfed22
afr's were almost dead on first run... and he tried a lot . a total of 9 pulls. Good stuff. now just gotta get a aquamist kit and a dp Good stuff when you reference the other numbers from that specific dyno because that is all that is relative to my numbers.
Old May 15, 2011 | 02:05 PM
  #211
Bigprfed22's Avatar
Bigprfed22
Old May 15, 2011 | 05:34 PM
  #212
etalj's Avatar
etalj
Do you reckon that my datalogging tool is as accurate as a tailpipe sniffer (which is what I'm assuming you used on the dyno)?
Btw as soon as I sort out the tune, my next mods will be water/meth and dp too
Old May 15, 2011 | 07:26 PM
  #213
ThumperMCS's Avatar
ThumperMCS
It's probably more accurate than a sniffer.
It reads it directly from the wideband...
Old May 15, 2011 | 09:29 PM
  #214
Bigprfed22's Avatar
Bigprfed22
+1 we didnt use a sniffer as the sensors on the r56 are quite capable of precise readings. No sniffer was used.
Old May 16, 2011 | 06:10 AM
  #215
etalj's Avatar
etalj
sweet. I've just got to sort out whatever the problem is with the engine, and I'll get some serious datalogging done.
Old May 23, 2011 | 03:05 PM
  #216
n1tr0's Avatar
n1tr0
I guess Jan's trying to centralize all our banter and requests. I just got an invite to the RMW Forums
(pm me if you need a referral so you can sign up)
Old May 23, 2011 | 03:22 PM
  #217
Davidoyo's Avatar
Davidoyo
I hope I get an invite
Old May 23, 2011 | 03:27 PM
  #218
joshknot's Avatar
joshknot
Yeah, come on- I want in!
Old May 23, 2011 | 03:34 PM
  #219
Revolution Mini Works's Avatar
I sent out a bunch but my contact list is enormous
To refer a member to this board, direct them to http://revolutionmotorworks.com/foru...ter&referrer=2
go ahead and pass it around
Old May 23, 2011 | 03:41 PM
  #220
silhouette88's Avatar
silhouette88
Hurrah!
Old May 23, 2011 | 04:46 PM
  #221
FUBSZ's Avatar
FUBSZ
i tried registering 3 times keeps saying cant open file :S
Old May 23, 2011 | 04:50 PM
  #222
web guy changed something and now we have some teething issues
try again now and if it doesn't work,
email me at revolutionmini@live.com
Old May 23, 2011 | 04:53 PM
  #223
n1tr0's Avatar
n1tr0
are you using a mac or such ? someone was posting the same problem on the PS Mini forum. Maybe try a different browser, I know Apple's safari is too cool for a lot of websites
Just checked, Opera/Opera Mini work ok.
Old May 23, 2011 | 05:20 PM
  #224
its working now..............sign up
Old May 23, 2011 | 05:37 PM
  #225
gothmdoc's Avatar
gothmdoc
Just tried registering for the first time, says "can't open file"
