Drivetrain alta blow off valve
Old Jul 24, 2010 | 09:06 AM
  #51
Thirsty Fire's Avatar
Thirsty Fire
Originally Posted by MiniManiac74
The hose connects to the boost port. That connection creates the vacuum that causes the BOV to open.
just to clear things.
I don't have the port, I only have the BOV. I've removed the noise generator hose and placed the BOV instead and I'm not using the small hose . Am I doing it right?
I took the pic from post #2 added some comments
http://www.flickr.com/photos/26454867@N06/4824187034/
Old Jul 24, 2010 | 09:28 AM
  #52
MiniManiac74's Avatar
MiniManiac74
I looked at your picture. Yes, you need the boost port. The hose in question connects to that port (the thing). The port has inlet on the side. It is hard to see, but the hose is about 18in long and goes from the BOV to the port. Mine is just zip tied to the firewall.
Old Jul 24, 2010 | 09:37 AM
  #53
Thirsty Fire
I thought the port is needed for boost gauge only, isn't it?
Old Jul 24, 2010 | 09:43 AM
  #54
MiniManiac74
You have to call Alta but from what I understand is that the hose is a vacuum line which gets it vacuum from the boost port. This is what opens the BOV. Without it hooked-up, it won't work. Again, call the Alta guys and ask them for the 100% answer.
Old Jul 26, 2010 | 07:05 AM
  #55
ALTA_Jarid's Avatar
ALTA_Jarid
You are correct. You need the boost port adaptor to make the BOV work. Give me a call!
Old Jul 26, 2010 | 09:12 AM
  #56
Thirsty Fire
I got the port but the small plastic screw is broken and the problem is I live in Saudi Arabia, so I can't connect the hose to the port....
Old Jul 27, 2010 | 07:53 AM
  #57
ALTA_Jarid's Avatar
ALTA_Jarid
Without a vacuum source the BOV will not work. What plastic screw do you speak of? Can you source one at a local hardware store?
Old Jul 27, 2010 | 08:15 AM
  #58
Thirsty Fire
Yah thanks I think I can source one. I appreciate your help.
Old Apr 17, 2011 | 06:49 PM
  #59
evilstitch626's Avatar
evilstitch626
so based on this do i also need to purchase a alta block off plate for my HKS SSQV bov to work properly as well as buy the...boost port?
Old Apr 18, 2011 | 08:08 AM
  #60
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Thanks for the reply!
You can use the HKS BOV with the OEM Diverter valve in place, or you can bypass the OEM part.
You choose!
Old Apr 21, 2011 | 09:19 AM
  #61
evilstitch626
and id use the block off plate to by pass the oem part, correct or else the pressure, just goes to both the oem divereter valve and blow off valve but more to the diverter valve. right?
You choose!
Old Apr 12, 2012 | 12:12 PM
  #62
phillipcoopersgates's Avatar
phillipcoopersgates
You choose!
I'm assuming this would be the same for a Greddy BOV?
bahman
Nov 15, 2019 05:45 AM
Bennyboy
Dec 1, 2016 11:09 AM
LAcooper
Sep 22, 2015 10:03 PM
MasterShaftner
Sep 4, 2015 03:52 PM
