Drivetrain ***OFFICIAL SIGN-UP THREAD for FLASH TOOL***
Old Apr 10, 2010 | 07:40 AM
  #951
Dwight Walhood's Avatar
Dwight Walhood
Originally Posted by jrs66
Does the sound out the back change at all?
Mine sure did! Before tune, the 3" cat-bac would sorta growl when accelerating. Now it howls up to ~3K and really roars above that! On back off, it's just one big BAH-WAAAH with a great WHUMP from the BOV. I'm liking it a LOT!
As for the quicker turbo spool-up, I definitely agree. Before tune, I was seeing -10.1PSI boost at idle on a fully warmed engine. Now it's showing -8.8-9.0PSI. To me this indicates the turbo is already starting to spool, even at idle.
Old Apr 10, 2010 | 07:59 AM
  #952
Eds not-so-red MINI's Avatar
Eds not-so-red MINI
Installed the software from Jan's link on a Win XP-powered laptop with zero issues (never touched the stuff on the included thumb drive). Configured the tool, plugged it in, everything worked basically as outlined in the PDF. Took all of about two minutes to read from the ECU.
Downloaded fpf file is only 57K ... is that right?
Old Apr 10, 2010 | 08:06 AM
  #953
onefish2's Avatar
onefish2
My fpf file is 55.5k. So that seems about right.
Old Apr 10, 2010 | 08:07 AM
  #954
david in germany's Avatar
david in germany
Damn you US Postal... Why must you be so slow!!!!
Old Apr 10, 2010 | 08:08 AM
  #955
Eds not-so-red MINI
OK!!!!!!!!!!!!!
Old Apr 10, 2010 | 08:49 AM
  #956
MiniSD's Avatar
MiniSD
Originally Posted by thevelourfog
Just had my car dyno tuned at Jan's place. Jan spent quite a bit of time on my car, about 2 hours to be precise. He did a great job; seemed like my car has different programming than it should have, giving him some trouble.
My baseline dyno on the stock tune was 176.0 WHP and 217.2 lb/ft of TQ. After about 10-12 pulls Jan got it up to 204.9 WHP and 233.3 lb/ft TQ. He said the first pull was 209 HP when it was cold, so I'm VERY happy with 205 after so much heat gain.
My engine is totally stock with a JCW inlet pipe and JCW factory rear muffler only.
WOW lucky you!!! My car is really weird. I got my car dyno tuned at his place on 3/24/10.
Poor Jan spent hours on the Dyno. Mine has the lowest stock numbers that he ever seen. My baseline dyno was at 150.0.0 WHP and 182.3 lb/ft of TQ and it was pinging. It was running lean, but after he did his magic, it's at 189.7 WHP and 210.5 lb/ft of TQ.
After the tune, I seafoamed my engine and it feels a lot different now. I also installed an oil catch can too. It's running very strong and sound amazing. I need an exhaust system now. I'm very disapointed in my car, but I'm happy that Jan made it so much better now. It gained 51.7 WHP at 6000RPM
Thanks Jan Can't wait to get a copy of the stock and tuned files on my flasher.
Old Apr 10, 2010 | 09:11 AM
  #957
thevelourfog's Avatar
thevelourfog
I seafoamed my car a week before and the day of the dyno, it really does smooth everything out quite a bit! Scottab36 did a dyno pull after doing a couple seafoam treatments and had some gains, so I wouldn't be surprised if you've gained a few HP back. Maybe this is why he thought it was one of the stronger stock ones he's tuned.
Jan also said my car was running in 'closed loop' before getting it tuned. Not exactly sure what he meant.
Old Apr 10, 2010 | 09:19 AM
  #958
PoktRokt's Avatar
PoktRokt
SOFTWARE INSTALL QUESTION:
NEVERMIND - IT WORKED
Old Apr 10, 2010 | 09:45 AM
  #959
MiniSD's Avatar
MiniSD
I wish that I knew about seafoam before I took my car there.
Old Apr 10, 2010 | 09:51 AM
  #960
J_'09s's Avatar
J_'09s
I know right? I'm waiting on a new shock too. The Air Force is apart of the problem too.
Old Apr 10, 2010 | 10:03 AM
  #961
david in germany
If you weren't so far away, we could share shoulders...
Old Apr 10, 2010 | 11:06 AM
  #962
MG2542's Avatar
MG2542
Could be worse. You could have to wait several months for it.
Old Apr 10, 2010 | 12:17 PM
  #963
J_'09s's Avatar
J_'09s
Interesting you mention that. My car is about to be set on a voyage across the vast Atlantic Ocean. I'll be without my Mini for 6 to 8 weeks!
Old Apr 10, 2010 | 12:54 PM
  #964
MG2542's Avatar
MG2542
Old Apr 10, 2010 | 12:55 PM
  #965
MG2542's Avatar
MG2542
Going on month number 5 without my Mini Oh well. All the parts I'm buying now will give me a reason to have some quality time with her when I get back.
Old Apr 10, 2010 | 02:09 PM
  #966
ENGINE 58's Avatar
ENGINE 58
do we send the downloaded file to jans email at jbrueg@***.net ?
Old Apr 10, 2010 | 02:52 PM
  #967
ENGINE 58's Avatar
ENGINE 58
ok jan i sent the file. i hope i didnt screw it up and i hope you got it and i hope you let me know you got it as well. if you have time. i know your crazy busy buddy.
Old Apr 10, 2010 | 02:53 PM
  #968
Revolution Mini Works's Avatar
I'm working on a bunch of files today
again
Old Apr 10, 2010 | 02:54 PM
  #969
Got it Brandon
Old Apr 10, 2010 | 03:19 PM
  #970
ENGINE 58's Avatar
ENGINE 58
Awesome!!!!!!!!!!!! Yay. Alright ! Soon I will have a can of RMW whoopass! Wooohoooo! No rush I know your busy.
Old Apr 10, 2010 | 05:15 PM
  #971
Eds not-so-red MINI
How 'bout them RMW decals?????????
Old Apr 10, 2010 | 05:41 PM
  #972
ENGINE 58's Avatar
ENGINE 58
I put one on top of my airbox
Old Apr 10, 2010 | 08:17 PM
  #973
PoktRokt's Avatar
PoktRokt
Does anyone know how the sport button affects the new tune? SHould it be on or off?
Old Apr 10, 2010 | 08:43 PM
  #974
Dwight Walhood
When Jan did my tune, he said I wouldn't need the Sport button anymore. That's certainly the case for throttle response, but forgot to ask about the steering feel change that button makes. Tried it on/off and don't really notice any difference. Anybody know for sure?
Old Apr 10, 2010 | 09:05 PM
  #975
ThumperMCS's Avatar
ThumperMCS
Throttle response after the tune is so instantaneous that Sport is unnecessary for "normal" driving, and in fact is just too sensitive for around town. Non-sport mode is like how sport mode used to be, and Sport mode is like hyper-Sport mode!
The changes in steering feel between Sport and non-Sport are unaffected by the tune and still operate as it did prior to the tune.
