Drivetrain Project 1.8L Rotrex SC Stroker
Old Mar 8, 2011 | 09:44 PM
  #401
scoopieb's Avatar
scoopieb
Originally Posted by Longboard Mini
Did a re-wrap of the header.
[IMG][/IMG]
With all the different coatings you used on this project how come you didn't have the headers ceramic coated. Isn't it better than the wrap?
Old Mar 8, 2011 | 10:01 PM
  #402
scolburn79's Avatar
scolburn79
Originally Posted by newbs49
GARAGE QUEEN
No.......My cars a garage queen. July 2004 Mini Cooper S with..........Wait for it............32000km's on the clock, NOT MILES but KM's as we use the proper scale over here in Australia!!!!
Old Mar 8, 2011 | 10:28 PM
  #403
Longboard Mini's Avatar
Longboard Mini
Originally Posted by DICKS GARAGE R53
Sorry LB but, I think that I like the stock facelift halogens better. Just my opinion though, when has that mattered anyhow. As long as you are happy with it.
No problem . I always thought my stock 04 zenons just had way to much Crome. These are perfect. Check my gallery for the old look.
Since day one my build has been for me and me only. I pickd everythng other then my license plate (my kids ) and did it the way "I" like.
As it should be
Longboard.
Old Mar 9, 2011 | 03:14 PM
  #404
arek's Avatar
arek
Thanks for the picture.
I have the old 04 Xexons and want some of these (or something similar). I assume that you are happy with the actual light output at night.
Your car is the dog's dangleys, by they way.
Old Mar 10, 2011 | 09:00 PM
  #405
Longboard Mini
I had the same lights.
Old Mar 11, 2011 | 05:44 AM
  #406
chuntington101's Avatar
chuntington101
I heard that wrap is actually more effective!if you want the best then contact a company called ATP wrap. They do inconel heat sheilds that can take upto 3000*F temps!!!!
Chris.
Old Mar 11, 2011 | 08:41 AM
  #407
scoopieb's Avatar
scoopieb
Interesting because I've read that coatings dissipate the heat quicker. Although the coating I did goes to 2,000 deg. I can't imagine the headers get anywhere close to that. I guess it depends which salesman your talking to. I'd be interested in seeing some data on some temps with and without the wrap. I couldn't find any on the ATP website.
Old Mar 11, 2011 | 02:44 PM
  #408
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
That 2000 degree stuff is actually only 1500 degree continuous and can handle 2000 degrees in short spurts. I figured out why my 2000 degree lava rock crap decintigrated when I hooked up an exhaust gas temp gauge. My EGT's before any tuning would reach up to 1600 degrees continuous on the highway! Since the tuning started, and I droped the CAT off I might see 1400 in suprts at WOT under load. So I might try some wrap again.
Old Mar 11, 2011 | 09:54 PM
  #409
Longboard Mini
Hey Dicks.
TQ and weight are great I agree. But solid HP and TQ working together is somethng everyone should try
It's addicting
LB
Old Mar 11, 2011 | 10:07 PM
  #410
DICKS GARAGE R53
Agreed LB, but high HP is not a necessity in a car that can hold its momentum, it just adds to the thrill of it.
Old Mar 16, 2011 | 06:13 PM
  #411
Minian's Avatar
Minian
Here is a $hity iPhone pic in my garage...
Longboard
Looks nice, but I'll stick to my LED location and cost. ($30)
Old Mar 17, 2011 | 06:52 AM
  #412
chuntington101
I personall think a combineation would offer the best heat retention. Some good quality exhaust wrap and then some Inconel heat shields. Alternatively there are companies that can make you inconel headers!
Chris.
Old Mar 17, 2011 | 09:49 AM
  #413
JPMM's Avatar
JPMM
You got to have the right coating applied in the right thickness(thicker than normal) to retain the heat in the pipe. I have ceramic coating applied to my turbo bike's exhaust header and after a run you can put your hand on the pipe without getting burned. The wraps absorb moisture , and the stuff I had fell apart.
http://www.performancecoatings.com/index2.html
Old Mar 17, 2011 | 10:54 AM
  #414
scoopieb's Avatar
scoopieb
Performance Coatings is good stuff. They are right by where I live, and the owner has a mini. That's what my headers and heat shield are coated with.
Old Mar 17, 2011 | 04:31 PM
  #415
Longboard Mini
Question?
I've been wanting to loose some of the chrome on my car. I'm thinking of getting this grill and was wondering what you all think?
Grill2.jpg?t=1300404584
Old Mar 17, 2011 | 04:49 PM
  #416
DICKS GARAGE R53
SEXY! Any chance they have a lower bumper grille to match that mesh pattern?
Old Mar 17, 2011 | 07:34 PM
  #417
Longboard Mini
No just this. I have a Grillcraft lower mesh and think it will go good. My only worry is it turning yellow/green like a lot of other CF parts do.
LB
Old Mar 17, 2011 | 07:45 PM
  #418
DICKS GARAGE R53
If it yellows out you can always paint it.
Old Mar 17, 2011 | 10:41 PM
  #419
5zero4's Avatar
5zero4
Do you think those headlights would fit on a GP? (Jan's)
Old Mar 18, 2011 | 04:56 AM
  #420
DICKS GARAGE R53
Yes they would, the GP is still just a MINI.
Old Mar 18, 2011 | 08:40 PM
  #421
Slyp Dawg's Avatar
Slyp Dawg
and here I thought Sparky was decently fast... I've been in some quick stuff at the autoX and on the street, but this is just the definition of carefully orchestrated lunacy!
Old Mar 19, 2011 | 05:44 AM
  #422
stevecars60's Avatar
stevecars60
Question?
CF looks great but the areo pieces look good also, & they match the lower grill for less$$$. The mat black would complement your front end IMHO.... just a thought!
Old Mar 19, 2011 | 06:22 AM
  #423
DICKS GARAGE R53
Sorry for the off topic post LB, but STEVE YOUR ALIVE!!! Check it out, I'm making progress. https://www.northamericanmotoring.co...continued.html
The aero grilles are a good option, but the mesh design on theese looks cooler.
Old Mar 19, 2011 | 08:15 AM
  #424
5zero4's Avatar
5zero4
I think the CF ones look pretty ace! If you wanna lose some chrome let me know and I'll help you out. Did I give you my card? If not Jan has it.
Old Mar 19, 2011 | 09:09 AM
  #425
Revolution Mini Works's Avatar
I just told him that yesterday
Lol
