Drivetrain New ACT clutch + flywheel = master/slave cylinder failure
Old Jul 23, 2009 | 09:27 AM
firenewt's Avatar
firenewt
I had an ACT clutch/flywheel installed recently. According to my mechanic, failure of the clutch master/slave cylinder after installing an upgraded clutch is pretty common. He knows other MCS owners that have replaced the slave cylinder 5 or 6 times. I'm wondering age has anything to do with it - my MCS is a 2002.
Since the failures are related to increased hydraulic pressure, is there an after market replacement available? I'm going to have an oem slave cylinder installed but need to determine if a more robust part is out there - perhaps adapting something to the mini.
Anybody have any advice?
thanks,
Kevin
Old Jul 23, 2009 | 05:37 PM
Nazrin's Avatar
Nazrin
- subscribed - as im looking to get the ACT clutch/flywheel in the near future..
Old Jul 24, 2009 | 12:16 PM
AZMCS's Avatar
AZMCS
I have replaced my slave after both clutch swaps in my turbo'd setup. I have had one other failure, but the clamping force is pretty high on the CM's I have in there now....I too have heard of multiple failures with the OEM clutch and it is just a poor design overall. No aftermarket solutions out there that I can think of...but a high quality billet/CNC'd piece will some heavier seals would be dope....
Old Jul 25, 2009 | 10:28 AM
Mini-Morgan's Avatar
Mini-Morgan
How has it failed?? no longer strong enough to disengage the clutch?
Old Jul 26, 2009 | 07:14 AM
firenewt's Avatar
firenewt
Yes, the clutch no longer fully disengages. This causes a lot of wear on the synchros. Given what appears to be an inherent problem with the oem slave cylinder, a new slave should be installed when upgrading to a higher clamping force clutch. The new oem slave will most likely fail, but it will work for a while. My dad and I are looking at what it will take to produce a slave using billet aluminum. PM me if you want to be kept up to date on the possiblity of a new slave.
Kevin
Old Jul 26, 2009 | 07:21 AM
Dr Obnxs's Avatar
Dr Obnxs
I've got the ACT system
and I didn't have a slave failure. But it's not one of the best parts out there, that's for sure (the slave that is). Failures are pretty common.
Matt
Old Jul 26, 2009 | 08:47 AM
firenewt's Avatar
firenewt
I'm pretty sure the age of the slave cylinder - 2002 original part - had a lot to due with the almost immediate failure.
Kevin
Old Jul 26, 2009 | 09:12 AM
Nazrin's Avatar
Nazrin
Matt
How do you rate the ACT kit? im planning to get it soon.
Old Jul 26, 2009 | 09:19 AM
SlowGSX98's Avatar
SlowGSX98
I had a new slave cylinder put on when I had my CM setup installed less then 7k miles ago and I'm pretty sure its already going bad unless its my clutch going bad already...
Old Jul 26, 2009 | 10:04 AM
firenewt's Avatar
firenewt
Haven't been able to put many miles on the kit, but My general impression is very positive. No clutch chatter and firm "right now" engagement. I like it.
Kevin
Quixotic1
Sep 11, 2015 11:15 AM
Sc00terbum
Sep 11, 2015 09:07 AM
Manny_cooper
Sep 4, 2015 08:28 AM
wildwestrider
Sep 4, 2015 06:25 AM
Sep 3, 2015 02:06 PM
