Drivetrain My Car At Riss Racing For Product Development
Old Jun 17, 2009 | 11:31 AM
  #126
aboss2566's Avatar
aboss2566
I just bought my S r55 and I will be buying from you.... Your feedback and comments are the type I like....
Keep us up to date with all update and product avalibilty...
Old Jun 17, 2009 | 11:58 AM
  #127
Riss Racing's Avatar
Riss Racing
Thats awesome to hear! Thank you! We do our best to keep you guys in the loop as much as possible.
Old Jun 17, 2009 | 05:04 PM
  #128
Bigjoeski08's Avatar
Bigjoeski08
I just want to know how Riss Racing is banging products out left and right so fast it amazes me. Keep up the good work and the o2 sim is going to be a huge seller for you guys.
Old Jun 17, 2009 | 06:13 PM
  #129
Riss Racing
Thank you! When we do something we go 100% or not at all
This SIM is giving me grey hair! We go it working. However we have to recalculate OEM numbers again then recheck the math. Then hook it up again after we trigger a CEL on catless. If it clears and the readings stay were we need them its good to go!
Old Jun 17, 2009 | 06:42 PM
  #130
Powashiftin's Avatar
Powashiftin
So with your o2 sim, we could run a cat-less downpipe? How much are you anticipating the sim to cost?
Old Jun 18, 2009 | 04:11 AM
  #131
countryboyshane's Avatar
countryboyshane
Riss,
How does one go about installing this O2 hack? Can you shed some light on this handy item? Will I have to resurrect my solder gun from the depths of my tool cabinet?
Thanks!
Old Jun 18, 2009 | 08:09 AM
  #132
chakraj's Avatar
chakraj
I spoke to Riss and they said you send them a o2 sensor and they modify it. The only downside is the o2 sensor is $215. When I spoke to Riss they wherent sure how much they where going to price their work but around $100 they said. Or you can use your existing o2 but you still have to send it to them.
Old Jun 18, 2009 | 08:29 AM
  #133
countryboyshane
...uh... not very cool
What exactly are they doing to the sensor? Aren't they just adding some simple electronic components to the wiring? I would think any person handy with soldering could do something like that.
Old Jun 18, 2009 | 08:37 AM
  #134
chakraj's Avatar
chakraj
Why dont we let them fill in the blanks. I dont want to give wrong info, I was just trying to be helpful and give what info I have. I think its more than just solder a wire, I believe they are adding some electronic components to it also. Who knows what voodoo they do?
I herd they sacrifice a chicken over every o2 sensor and the gods help remove the cel, but there is a slight chance I am wrong.
Old Jun 18, 2009 | 09:36 AM
  #135
countryboyshane
Yes you are right. We are all very excited to hear how these new RR parts are going to perform. Can't wait for the dyno results!
Old Jun 18, 2009 | 10:12 AM
  #136
n1tr0's Avatar
n1tr0
I personally thought the flex section would be enough to handle the stress. However, you make a great point. If it cracked a hanger weld it may have to much stress that would require a hanger. So I'd have to agree with you on this one. (However if you look at the weld closely. You will notice there wasn't any penitration. This is a layover weld, and isn't very strong. On the rest of the welds on their downpipe there is solid fusing. So this could have just been a minor error on their part)
I was one of the first to purchase the Alta turbo-back, unfortunately, their cat is a cheap POS & they refuse to fix or re-engineer it, so like many people it was removed (at least for those of us who purchased before they put up their disclaimer). As it stands, there isn't a lot of long term data w/ the aftermarket downpipes to see if the brace is needed, but the factory felt it important enough to use two brackets to the block, Alta's being only on one side might have caused it to twist & crack, or it might have just been a shoddy weld. Regardless, I think it's great to see you including a bracket for our piece of mind and equally encouraging to see a high end shop that doesn't let ego get in the way of product development I think you'll find most Mini owners aren't 'cheap', but rather 'savvy' shoppers and more than a few of us have already been burned by Alta.
Old Jun 18, 2009 | 10:20 AM
  #137
rasputinj's Avatar
rasputinj
Does you catted downpipe through any CELs like Altas? Also do you think I would have to take off the catted version to pass smog in CA. If I just replaced the downpipe on my stock R55, would there still be a performance gain, until I can find a exhaust system I like?
Old Jun 18, 2009 | 10:26 AM
  #138
n1tr0's Avatar
n1tr0
you should see a performance gain w/ a highflow cat/downpipe and the stock exhaust will probably gain some volume as well.
Old Jun 18, 2009 | 11:42 AM
  #139
Riss Racing
Hey guys,
Just wanted to clear some things up with the SIM. You will have 3 options.
1) You can purchase the SIM from us and install it to your 02 Sensor yourself. This is not hard to do, and will be the cheapest option.
2) You can send your sensor to us and for a small fee on top of the SIM we will install it for you.
3) You can buy the SIM with a brand new 02 Sensor we purchase from BMW MINI directly. The sensor to purchase from the dealer is $215. (This is going to be pricey doing it this way. However 1 you get a brand new sensor with the SIM built in you can simply take off and on with your downpipes + have your OEM one handy. If a sensor goes out later etc...2 its simple and ready to go out of the box)
4) We are also working on package deals with our downpipes + the SIM to save you guys some money.
With all that said....Personally I would go with option 1 since it's 10 minutes putting the thing on, and will come with a full picture DIY. If you guys need a video DIY we can make that too. If you need phone support we can provide that too. We have not yet set the price of our SIM since we are still not done with testing. The good news is we do have it working! We just need to fine tune it a little more.
Old Jun 18, 2009 | 11:59 AM
  #140
Riss Racing
When your first with a product it is hard to get it 100% the first time. We had the same issues with the N54 downpipes. However, it's your responsibility to the community/your customers to take their feedback, and make it right. That is why we re designed the downpipes 3 times on the BMWs. (This does cost a lot of money/time after you have already built your JIGs and done production runs. You have to go back and do it all over again) This is the reason most companies don't like making changes. But if your not willing to do this your products won't stay on top, and people will lose faith in your product line.
Now we are at an advantage in this situation because we can avoid any mistakes that were already made. By adding the brace we did not think it was needed. However you guys felt it was, and I'm glad we did it after seeing the downpipe on for a while. I believe we made the right choice. KUDOS to you guys! There is no room for EGO. We all have the same goal. We know how to make the products, and you guys know these cars. Working together we will make the best products, and everybody wins
Old Jun 18, 2009 | 12:06 PM
  #141
Riss Racing
Our catted downpipe so far has not thrown a CEL. For me to tell you 100% that it will not would be a lie. Since we have not had the opportunity to test it on several cars etc. I can tell you we will have a CEL fix (being worked on) just in case it does. On our N54 catted downpipes we have had maybe 1 out of 100 downpipes that go out get a CEL. It's a trade off of preformance, and not throwing a CEL at all. We use High Flow metallic substraight cats. These are expensive, and have a low CEL count for maximum preformance.
As for if you will pass smog in CA. Once again the only way for me to answer this honestly would be for me to take the car down an smog check it. I can tell you that our catted downpipes on the N54 did pass smog with OEM exhaust still on. Thank you!
Old Jun 18, 2009 | 12:19 PM
  #142
fronjoni's Avatar
fronjoni
im really interested in this.
Old Jun 18, 2009 | 12:33 PM
  #143
Riss Racing
+1
You will not see as big if a gain as catless. However you will get a decent gain.
On a side note. All of this testing on the SIM with the DP being catless. The car rips! I am able to see OEM & drive it to get our readings. Then put the catless on right after to get the other readings. It feels amazing!
Old Jun 18, 2009 | 12:41 PM
  #144
countryboyshane
How exactly do you install the O2 hack? Any soldering required LOL!
Old Jun 18, 2009 | 01:31 PM
  #145
Riss Racing
Simple as splice a wire. And solder it in! Everything is set up for easy install. Comes with the unit in a box the wires pre cut. The ground has insulation etc...I will show you guys the DIY before its ready too go. We have to be a little careful so somebody doesn't take our hard work and apply it.
Old Jun 18, 2009 | 02:14 PM
  #146
countryboyshane
Awesome. All those solder pools from 8th grade electronics are gonna pay off!! Just kidding!
Old Jun 18, 2009 | 03:01 PM
  #147
Powashiftin
The Riss Racing catless downpipe is kind of expensive, no? Exhaust Depot and the Ragazzon are both cheaper. The Riss Racing looks much nice though!
So this o2 sim is going to be available tomorrow?
Old Jun 18, 2009 | 04:54 PM
  #148
Riss Racing
Sorry if its a little expensive for you. We will be running a group buy on the products for this forum so you can get them at an attractive price. We are waiting to finish our SIM so we can package them together. Since at the end of the day the downpipe is useless without it. When you have a CEL on your car if its anything similar too the N54 downpipes you are losing power. Thank you!
The SIM will be available as soon as we finish the testing. I don't want to rush it out, and something go wrong. We want to make sure its FLAWLESS before we post it for sale.
Old Jun 18, 2009 | 05:32 PM
  #149
jproz's Avatar
jproz
Yay! I'm in.
Old Jun 19, 2009 | 11:52 AM
  #150
Riss Racing
Hey guys take a look https://www.northamericanmotoring.co...ml#post2799914
