Drivetrain CLutch and Dealer problems
Old Apr 27, 2009 | 08:57 AM
RaT48's Avatar
RaT48
I have an 06 MCS about 32K on it. I don't drive very rough and I don't launch the car or burn the clutch, but recently I have been having some problems. When engaging or disengaging the clutch pedal I can feel that it is not going very smooth. When I try to start of from 1st gear the clutch sort of stops at some points causing the car to jerk. The pedal feels as if the spring is getting stuck and does not respond.I don't it's anything with the hydraulic pump or anything. Sometimes when starting from 1st gear the car makes a really loud weird noise. It's hard to describe its loud and it sounds like something is wrong. It's not a metal noise and it's very brief. This takes place between 1500 and 2000 RPM'S. I went to the dealer (Patrick MINI) and they told me all of this is perfectly normal because the car is getting older and did not find a reason to do anything about it. The car is still under warranty until July
Is this a common problem among 06 MCS? Has anyone ever had this and what is the solution to fixing it. Would this be covered under warranty?
Old Apr 27, 2009 | 09:07 AM
JAB 67's Avatar
JAB 67
At a minimum your throw-out bearing and guide sleeve probably need replaced. Dealer will fight you on this, because its a lot of labor. Stand firm.
Old Apr 27, 2009 | 09:11 AM
Thumper460's Avatar
Thumper460
Dealers... LOL!! I have an 06 MCS, the clutch pedal "felt" ruff and jerky when pushing it in!! Like the linkage was dry and binding ( NO Linkage.. hydraulic release bearing..) and made noise!! Took it to the dealer and was told... there was a notice on the noisy jerky clutch and they changed the entire assy out!! Flywheel/pressure plate and slave... all with the new and updated version!! I had 34K on it at the time!!
Now it is smooth as glass... engagement rocks!! Find another dealer!! cool??
Just me............................
Thumper
Old Apr 27, 2009 | 03:08 PM
Luys's Avatar
Luys
don't worry I have the same problems, stiffer clutch and loud sound. The sound is from the Flywheel. It is the time to change it. The same thread has discussed before if you want check this out https://www.northamericanmotoring.co...tch-sound.html
Old Apr 27, 2009 | 03:33 PM
ThumperMCS's Avatar
ThumperMCS
Master slave cylinder, throwout bearing, pressure plate....
Most likely 1 of the three or a combo of them. Very common issue with the 53's...most dealers will replace the entire clutch assembly when this occurs. Try another dealer if you can. And if not, it will eventually give out...then you can say "see, I told you so guys...fix it now thanks"
Old Apr 27, 2009 | 04:48 PM
RussellCory's Avatar
RussellCory
Get it done BEFORE the warranty runs out. I bought my car 2 days after the factory warranty ran out. The dealership would not budge on the rattling flywheel even though it was obviously a problem before I bought the car.
Old Apr 29, 2009 | 01:47 PM
RaT48's Avatar
RaT48
Made an appoitment to change the clutch to a different dealer. I did the test. I put the car in 5th and gave it a little gas slowly letting go of the clutch. The car did not stal or jerk it moved smoothly. :-(
Old Apr 29, 2009 | 08:46 PM
minimc's Avatar
minimc
Mine had similar problem. Dealer jokingly asked if I'd had a race clutch installed. Pulled trans & found bent 'finger' diaphragm springs. Replaced under warranty - no fuss.
Old May 9, 2009 | 06:02 PM
RussellCory
My dealer first accused me of installing a lightened flywheel and trying to rip them off THEN denied the warranty.
andrewjg1994
Jan 29, 2021 07:45 PM
eliseo1981
Jan 28, 2021 02:45 PM
Sep 17, 2015 09:27 AM
Zettinger
Aug 25, 2015 04:04 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
