Drivetrain New Alta ECU What happened to it?
Old Sep 22, 2009 | 06:37 AM
  #126
PRIMINISTAR's Avatar
PRIMINISTAR
As far as im aware as long as the boost pressure on a stock S is 17-18psi it should be fine baring in mind though there are alot more things envolved in tuning than just boost which is why i think Alta mite not be what i was looking for.
I got my JCW turbo from MINISPARESUK i got a good deal on it and he also offered to buy my old one back from me for £200 which is a result. As for warranty it would be void but i must say that the turbo's are identicle looking and doubt BMW would randomly take the turbo off and inspect it to the extent they would find out for no reason, but you can never be too careful with warranty.
Old Sep 22, 2009 | 08:00 AM
  #127
ALTA_Jarid's Avatar
ALTA_Jarid
Originally Posted by PRIMINISTAR
Complete Nuts. The JCW Turbo is way different. It has much much stronger internals and more compressor fins so the turbo has to work way less to produce higher boost pressures thus not maxing it out like the standard one. I know a few people with remaps running over 17-18psi and both within a few thousand miles are experiencing problems with the bearings and wastegates on otherwise stock cars.
Sooo youre saying the turbo internals are made of adamantium? How does the internals get stronger? Both the JCW turbo and the OE turbo have journal bearings. As far as we can see (I havent counted the fins yet) the only difference is the compressor wheel/housing.
Old Sep 22, 2009 | 08:03 AM
  #128
Stig One's Avatar
Stig One
Jarid
Will the JCW tune see more boost or just ignition timing and fuel adjustments ?
Old Sep 22, 2009 | 08:08 AM
  #129
ALTA_Jarid's Avatar
ALTA_Jarid
I talked to Jeff a bit more today (that guy is a wealth of knowledge) about the numbers I quoted. From what I understood the peak boost would be around 20 and taper off to 16ish. As with the JCW turbo/tune the car peaks to 19 and tapers. I am sure Jan and the other tuner dudes see the same thing. As for "tuner A makes 30hp and tuner B makes 27.5 hp and yet tuner C makes 20hp, a dyno graph has an infinite amount of points to record information at. The horsepower I quoted was peak HP. Our tuning can produce 30hp at lower RPM with a great gain in torque as well. I dont want to get into too many specifics without proof, such as a dyno graph. Just know that we are working on our tune to be a great increase in power/performance for your MINI!
Old Sep 22, 2009 | 08:12 AM
  #130
Stig One's Avatar
Stig One
Can you answer my question ?
Old Sep 22, 2009 | 08:33 AM
  #131
ALTA_Jarid's Avatar
ALTA_Jarid
I was in the middle of typing a response Stig, it takes more than four minutes to type a response sometimes. The short answer is probably all three.
Old Sep 22, 2009 | 08:51 AM
  #132
Stig One's Avatar
Stig One
will alta offer a water/meth injection map for cooper s and jcw cars ?
Old Sep 22, 2009 | 08:52 AM
  #133
ALTA_Jarid's Avatar
ALTA_Jarid
We will only supply maps if you a stubby antenna...since these add 15hp. (Meth/water injection is a bit trickier to tune but I am sure we will work on this as well)
Old Sep 22, 2009 | 08:55 AM
  #134
Stig One's Avatar
Stig One
Craven sent me a free stubby antenna, will that lower my hp with the alta tune ?
So for meth a custom tune would be better ?
Old Sep 22, 2009 | 08:57 AM
  #135
ALTA_Jarid's Avatar
ALTA_Jarid
I think it depends on the level of mods. I'm definitely not a pro when it cometh to the tunes. I will try and get ALTA2 to respond to this question sometime today!
Old Sep 22, 2009 | 10:13 AM
  #136
samroberto's Avatar
samroberto
About the JCW turbo ... Any noticeable difference ?
Old Sep 22, 2009 | 01:34 PM
  #137
PRIMINISTAR
I am having it fitted and tuned next tuesday so will let you know. As for the Snide remark from Jarid (Very professional by the way), The internals are stronger. Over here they have been looked at very closely and the main reason they are stronger is due to not having to work as hard to get a higher boost output. If you pushing 20psi on the standard turbo, be prepared for problems as we have over here a few times already. I certainly wont but any Alta parts now considering how rude and childish you are with your comebacks.
Old Sep 22, 2009 | 02:00 PM
  #138
ALTA_Jarid's Avatar
ALTA_Jarid
Sorry if you thought I was rude PRIMINISTAR. I made a joke about adamantium. I was simply asking you to back up your information on the turbo differences. There is soo much misinformation on the internet that it is sometimes hard to sift thru info to find the truths. I have an OE turbo and a JCW turbo side by side at my desk and for one thing there are exactly the same amount of fins on each compressor wheel. You are correct as the material might be different but I cannot find how or what it is. Again I apologize for typing rude.
Old Sep 22, 2009 | 04:11 PM
  #139
PRIMINISTAR
Fair do's, i except your apology. I think the material is different. Also i think there is another set of fins or they are bigger or something. P-Torque said something about them being only slightly different but you would notice if you knew what you were looking for. I haven't had a chance to have mine side by side yet but will report back if a find any visible differences.
Old Sep 22, 2009 | 07:59 PM
  #140
e30r56's Avatar
e30r56
It wouldn't surprise me if the housing and/or wheel diameters were what the differences were, so as to get the higher power at a slightly higher rpm with less heat than a stock S turbo.
Old Sep 22, 2009 | 08:41 PM
  #141
ThumperMCS's Avatar
ThumperMCS
The ~30/30 I quoted from RMW was peak horsepower as well. If you want to talk about gains at various points on the dyno plot....theres almost ~50hp gain @6300 ...and trust me you feel it.
All I'm saying is you guys have been hyping this tune up since forever ago, so I think people are hoping for a bit more out of it than what you mentioned. But we shall see.
Old Sep 23, 2009 | 09:37 PM
  #142
ColinMc's Avatar
ColinMc
A friend of mine is currently running an 07 R56 turbo on a custom dune buggy motor project of his...it's running 23 psi at full bore and has gone through two racing seasons no problems...
Not sure how he mounted it or what motor it's on...I just know he got it from a totalled 07 MCS.
Old Sep 23, 2009 | 10:02 PM
  #143
ThumperMCS's Avatar
ThumperMCS
Wow that sounds VERY interesting!
Feel free to give us more details and/or pictures of it
Old Sep 23, 2009 | 10:44 PM
  #144
Stig One's Avatar
Stig One
Jeff ,Adam or Jarid
Will the New Alta Programmer/reflash/plug in allow turbo and injecter upgrades ?
Old Sep 24, 2009 | 07:45 AM
  #145
ALTA_Jarid's Avatar
ALTA_Jarid
X 1,000,000,000
Old Sep 24, 2009 | 08:20 AM
  #146
dunphyj's Avatar
dunphyj
Jeff ,Adam or Jarid
Why do wonderful ages of twin scroll k04 turbos come toons when I hear that from stig XD
Old Sep 25, 2009 | 08:09 AM
  #147
ALTA_Jarid's Avatar
ALTA_Jarid
I'm lost. huh?
Old Sep 25, 2009 | 10:03 AM
  #148
dunphyj's Avatar
dunphyj
apologies, iPhone tends to type what it wants :P rewrite:
Why do wonderful images of twin-scroll K04 Turbos come to mind when i hear that from the stig (that being the question of whether Altas ECU tune will be able to support turbo upgrades XD)
better?
Old Oct 6, 2009 | 12:33 PM
  #149
Stig One's Avatar
Stig One
Any updates from the leftcoast ?
Old Oct 6, 2009 | 12:47 PM
  #150
ALTA_Jarid's Avatar
ALTA_Jarid
not yet..
