Drivetrain New Alta ECU What happened to it?
Old Aug 19, 2009 | 10:39 PM
  #76
ALTA2's Avatar
ALTA2
Manufacturer
Originally Posted by n1tr0
Any of the shops with the Dimsport Genius 2 can give you a tune. Call around.
Yes, but...........
Originally Posted by PRIMINISTAR
True. Iv already had a few tunes but they have all been crap or too dangerous for the car by pushing over 18Psi boost so had each one taken off within days of getting them. Whats happened to tuners now, they are all crap.
Not bagging on the Dimsport tool at all, but it comes down to the tuner and the tools they have to tune the ECU. The Dimsport tool is a great key to unlock the door, but you really have to know what you are doing once there.
It 17-18Psi, and its not as easy as that with bad tuners. Due to the overboost functions its not so easy to tune the R56. And with a bad tuner doing the work you run into the fact the remove the Boost limiter so even if they only request 17-18Psi you can get anything up to 24Psi due to the turbo spooling aggressively, or you get some gears pushing good boost and others being completely flat. Thats why im waiting onAlta or RMW as they are Mini bases so its gotta work properly.
This is partially why things are taking longer than normal. The maps available in the Dimsport tool are not enough for a real tune in my opinion. There litterally hundereds of maps in an ECU and with the maps exposed with the Dimsport tools (about 5) its no wonder why some tuners are able to tune the ECU consistently. One boost map doens't cut it.
Well RMW's been travelling the country doing tunes all summer on the R56 and his reputation is impeccable. I am curious about the Alta tunes, but keep in mind how much boost and how lean their previous tunes were with the Unichip.
Alta also hasn't been able to produce anything that's really lived up to the hype yet, downpipes that throw CEL's, intakes that foul the MAF, inlet tubes that collapse, boost hoses & intercoolers that just don't fit...
Sure some of it's due to poor quality control, but a lot of it's just poor engineering and the only updates to their product line come in the form of price cuts and additional fine print/disclaimers.
Yup, we have done nothing ECU wise that lives up to the hype. But things will change and you will see why it took so long.
Regarding the other items, give me a break, you really have no idea. I am not going into the downpipe CEL issues, or the other things you mentioned. You can start a thread and we can answer them there. With all those things you have mentioned, we have hundereds of satisfied customers with those mentioend products and plenty of customers that we have taken care of if they got a part that was trimmed to bad or what not. I am done here. There was no need to toss that in there.
Originally Posted by Revolution Mini Works
Adam:
If you have the top of the line Dimsport you have the full eprom so all of the maps are there. RPM everything is there. You just have to build the maps. These are the things we are doing. Not many people know this can be done with Dimsport, that's why they are bagging on it. As for the ability to put it to stock or add new maps we have a flash tool that is finished.
Just wanted to clear up your misconceptions on Dimsport....... I hear these complaints from other tuners who don't understand how the Dimsport really works
I fully understand how it works, i fully understand there are many maps in the Eprom, but unless you have spent a year doing nothing but decoding it, i know that you are not able to tune all the maps. I am not saying you dont know how to tune cars at all, but i do know that you battle with consistent boost(in all gears), and being able to make the same power on both old and new R56's. The new R56's don't get as much boost or power. We found this with the Unichip long ago. This has to do with the ECU mapping for the Wastegate Duty cycle maps. Because some of the tunes on the new cars are lower than the old i know that you are not exploring too far past the basic maps they unlock. But that is not a cut on you at all, Its just an observation.
Overall being able to tune fuel (which you can), tune full throttle timing (which can), being able to adjust the boost target map for some gears( which you can) you can make a very fun car, and great seat of pants difference.
Looking at what people are saying about your tunes, if these customers didn't have a boost gauge, and got thier car after you tuned it, i too would super stoked! The increase we can get from the Dimsport tool are very good, but still leave alot to be desired.
Don't think that i am trying to say you can't tune a car, because in the Mini world you have more time tuning Minis that anyone, including us.
like the small tweak to the sheet metal on the CAI ? name one real issue you've fixed in an R56 product change. I've been to your shop, fixing the rest of your products shouldn't take any time at all. If/When you get your product & CS issues taken care of, I'll STFU. I'd love to be able to recommend a local manufacturer.
Fine, the intake, while YOU think that there were all these issues, we have only had 4 ever, out of hundereds, that failed at the spot weld. Guess what, we replaced them. If you are refering to the back of the box where we changed it, we did this to make installation easier. Our original designed worked great on our car as well and many many others. We found that something changed, the motors on some cars moved more and some hit the sound generator, so we fixed it with a plug to ditch the sound generator. Then moved to changing the box to clear the sound generator altogether. What is wrong with that?? Is this not making something better to work on more peoples cars?? The silicone hoses was a nightmare for us as we made it, it worked, then got trimmed incorrectly and really fouled up that the hoses fit. This has also been corrected. I am not going into the downpipe issue, as this will be addressed in an other thread. I am done with answering to your constant pokes, and over exaggerated opinions about how we do business.
If you want to boast about you products without any discourse, start your own thread in the Vendor Announcements section. Since your tune is still entirely speculative, your previous/other products are relevant since they establish the quality of you work.
Umm, we are answering customer questions proposed on this thread, we didn't start it. Your right we are talking about something that doesn't exist. But we have to keep people interested in what we are doing. If we mentioned nothing ever until it was ready, that looses customers that other wise may have waited for our part. Also not mentioning anything, gives customers that we are doing nothing about it, and also gives customers the idea we are doing nothing new in the Mini world.
We have this fine balance of letting customers know something is coming, but doing it just early enough that when customers are getting restless, BAM we come out with it. But on this product, its taken so long that it didn't really work out the way we wanted.
What i can say is that when our product is out, it will be what customers want and it will be what tuners wants. We do feel this will bring a whole new level of tuning, and tuners to the Mini world. Because the "tuning" aspect of these cars have pretty much compared to other cars, out there, we feel this aspect is really untapped. The Euro tuning world is full of all these secrets about how a car is tuned, and how the ECU's work, and all that. But we are going to change the way people think of ECU tuning.
Old Aug 21, 2009 | 10:38 AM
  #77
hotcornernoprob's Avatar
hotcornernoprob
i just ordered the CAI and I for one can't wait for this tune!!
Old Aug 21, 2009 | 06:00 PM
  #78
dunphyj's Avatar
dunphyj
i can't wait either! i have all bolt-ons u make for my engine except the BOV and Intake (i have helix 13's bov and DDMWorks Race Intake instead just for personal choice) but i am not even touching my car's power until this tune you guys have coming is here... i don't think i'd need anything more than what that tune will give me...
Old Aug 21, 2009 | 10:31 PM
  #79
scott48's Avatar
scott48
jeff!!!....interested in the upcoming info
Old Aug 21, 2009 | 10:56 PM
  #80
PoktRokt's Avatar
PoktRokt
Has there been any results/testing yet as to what sort of torque and HP we might expect from this tune? Throw us a bone!
Old Aug 22, 2009 | 12:08 AM
  #81
LimonR56's Avatar
LimonR56
good info Jeff... tks..
Old Aug 22, 2009 | 01:00 AM
  #82
chakraj's Avatar
chakraj
Yes Jeff it has been months since we have heard from you. Good info.
Old Aug 22, 2009 | 08:10 AM
  #83
Minitauro's Avatar
Minitauro
Thanks for the update
Old Aug 22, 2009 | 04:11 PM
  #84
richi0207's Avatar
richi0207
Also waiting for a tune after being happy with your unichip for 25k+ miles.
Old Aug 27, 2009 | 11:55 AM
  #85
hotcornernoprob
any update? i'm eager to get this tune!!!
Old Aug 27, 2009 | 12:19 PM
  #86
ALTA_Jarid's Avatar
ALTA_Jarid
TRUST ME as soon as we have an update it will show up on the board! Nada just yet...
Old Aug 27, 2009 | 02:34 PM
  #87
jaytech's Avatar
jaytech
Very good write up Jeff. By going through the code is the way to do it, not just finding maps visually by 2D and 3D patterns using an emulator. By going through code you can see when each boost map is being used by what condition flags it sets in RAM to use that particular boost map. Using the emulator is good way to test what you have found going through the code more quickly. Very good work Jeff and I am sure you guys product will change the way of Euro ECU tuning.
Old Aug 27, 2009 | 09:32 PM
  #88
ThumperMCS's Avatar
ThumperMCS
So where's your product?
Old Sep 17, 2009 | 01:47 PM
  #89
willsblackmini08's Avatar
willsblackmini08
Any up dates?
Old Sep 17, 2009 | 02:40 PM
  #90
drewstermalloy's Avatar
drewstermalloy
Has there ever been any talk of an ECU upgrade for the MC?
Old Sep 17, 2009 | 07:30 PM
  #91
MotorMouth's Avatar
MotorMouth
I'm sure Jan could tune it and get some more power out of it - just not as big a jump as with a turbo car.
Old Sep 18, 2009 | 10:16 AM
  #92
drewstermalloy
Where can I find him?
Old Sep 18, 2009 | 10:51 AM
  #93
ALTA2's Avatar
ALTA2
Manufacturer
Well they say no new is good news, right??
NOT in this case, which is a bummer. We do not have any new news at the moment. I really wish i could say more, but there is progression for sure.
To recap, we have tuned cars, but the basic mapping just doesn't cut it. Which is part of why its taking so long. As we have said before, WHEN its out, it will be the ECU tool to have!
Old Sep 18, 2009 | 10:54 AM
  #94
Stig One's Avatar
Stig One
Christmas? next summer ?
Old Sep 18, 2009 | 11:46 AM
  #95
spinned's Avatar
spinned
Jeff, I only live a few miles from you guys so if you are interested in final testing of your ECU on my JCW (other than your shop car) let me know.
Cheers
Old Sep 18, 2009 | 11:47 AM
  #96
PRIMINISTAR's Avatar
PRIMINISTAR
Next Christmas or Next Summer more like.
Old Sep 18, 2009 | 12:58 PM
  #97
ALTA_Jarid's Avatar
ALTA_Jarid
Thanks negative Nancy! I seriously seriously doubt it will be next summer/Xmas
Old Sep 18, 2009 | 01:24 PM
  #98
drewstermalloy
Cheers
Holy crap that's a good looking car.
Old Sep 18, 2009 | 02:05 PM
  #99
Stig One's Avatar
Stig One
before next summer ?
Old Sep 18, 2009 | 02:16 PM
  #100
ALTA_Jarid's Avatar
ALTA_Jarid
We sure hope so!! If we had our way it would be done now!
