Drivetrain More power but keep the miles per gallon. Can it be done?
Old Apr 5, 2009 | 09:16 PM
  #26
Partsman's Avatar
Partsman
Legion_of_Doom
Originally Posted by Ryephile
...on PFI boosted setups like the R53 MCS we add fuel to add chemical quench to the combustion process, typcally by 1.0:1 [thus the targets for the R53 are typically 11.8:1 to 12.2:1 pre-cat]. Traditionally on n/a setups, 12.8:1 to 13.2:1 on 100% gasoline is peak torque, however that shifts to 12.3:1 to 12.8:1 on E10, and down around 8:1 [0.82-ish lambda] on E85. Why would you target a leaner than stoich AFR with E85?
Source
Regards,
Ryan
Well...they have cars running around on it, while no one else does. They must be doing something right.
Old Apr 5, 2009 | 09:18 PM
  #27
Revolution Mini Works's Avatar
Originally Posted by jaytech
I know I made my own. Ok back on topic .
your expert explanation sure didn't save Mike's or your reputation on this one
thanks for proving you don't understand how your equipment works....
Old Apr 5, 2009 | 09:20 PM
  #28
the point is : They don't understand how their wideband works
you may not understand this but Ryphile does
Old Apr 5, 2009 | 09:27 PM
  #29
jaytech's Avatar
jaytech
Ok smart guy, what's the pump current level at 0.76 lambda? How about at 2.50 lambda? How does the PWM heater circuit knows when the sensor is at operating temperature? What is the operating PWM Frequency for a Bosch LSU4 sensor or NTK sensor's heater? What's the conversion in converting gasoline AFR to Methanol AFR?
Always trying to start something.... geez!
Old Apr 5, 2009 | 10:29 PM
  #30
Longboard Mini's Avatar
Longboard Mini
BOOOOOOM
Source
Regards,
Ryan
You are a smart man Ryan . Great questions.
Looking forward to Mikes answer.
Longboard
Old Apr 5, 2009 | 10:36 PM
  #31
AZblackOUT's Avatar
AZblackOUT
Looking foward to RMW's answer
Old Apr 5, 2009 | 11:00 PM
  #32
M3NTAL's Avatar
M3NTAL
Looking forward to E85 in my tank
Old Apr 6, 2009 | 12:57 AM
  #33
DR FUH's Avatar
DR FUH
Originally Posted by Mike@Mynes
kapps, Mini's from the factory tends to run in the 10.5:1 AFR (mid to high 10's). On pump gas, we tune our cars to around 11.1-11.5 AFR depending on 91/93 octane. On E85, i'm at the 11.9-12.1 AFR.
Running in the 12.8:1 AFR is a little lean and should be avoided.
Just my 2 cents.
BOOOOOOM
Source
Regards,
Ryan
Longboard
Ryan, I'm sure you will understand my explanation, it's just unfortunate we spend more time filtering thru ignorant comments than educating the community. Experienced tuners like Jason and myself, understand the chemistry of combustion and stoichiometric amounts of air and fuel as it relates to Lambda. For gasoline, the stoich AFR value is 14.7:1 which is Lambda 1.0. Understanding how this concept relates clearly defines ones experience or lack of in proper engine tuning. Stoich AFR for E85 is approximately 9.8:1 and you have accurately mentioned that peak torque is produced around 0.82 Lambda. I'm sure you will agree that 0.82 Lambda is equivalent to 12.05 AFR for gasoline. Mike mentioned the MYNES MINI is tuned to 11.9-12.1 AFR running on E85. The wideband on their dyno is calibrated for gasoline AFR. Comparing the equivalent ratios and converting those values to Lambda results in 0.81-0.82 on E85, exactly the number you so stated. The reason their MINI makes horsepower and torque is because it is properly tuned.
Hope this helps clearify things....
Old Apr 6, 2009 | 07:42 AM
  #34
Glad to see at LEAST ONE PERSON OVER THERE KNOWS HOW TO READ A WIDEBAND CORRECTLY
I think I'm going to call you the "sweeper" as you always have to come in clean up the mess that Mike and Jay get into....
Old Apr 6, 2009 | 07:51 AM
  #35
searocko's Avatar
searocko
Originally Posted by dnsmnmsmini
Hi! I have an '05 MCS with the 6speed manual tranny. I would like to increase the HP and I am considering a pulley change. Can I get more power but keep the MPG that I am getting now (25-28mpg for mostly in-town driving)? Is a pulley swap the best way to start or is it better to start with changes to the air intake system or exhaust system? If anyone lives in Washington State and knows of a good shop to go to for this kind of work, I would really appreciate the info. Thanks!
Steering this back to the OP's original question...
I have an '05 MCS and my MPG prior to just the 15% pulley, was in the 25-27 range mostly city driving. With all the mods in my sig, I'm averaging the same although I've dropped to 10mpg when I run at Pacific Raceways. Long highway drives, I get around 30-31 mpg.
The pulley is your best bang for the buck. If you look at cost/performance gain, an intake or exhaust will not give you good returns. I am running the stock airbox and paper filter along with the OEM catback. The addition of the RMW header really woke up the car. I'd spend my money there next. Then a custom ECU tune will really make your car fly!
As far as shops in the Seattle area, I've heard good things about Zahntech in Redmond, Speedware Motorsports in Redmond and have had good experience with Group 2 Motorsports in Ballard. You can also post on psmini.org for other recommendations.
Good luck!
Old Apr 6, 2009 | 10:07 AM
  #36
Wake|MCS's Avatar
Wake|MCS
Me too haha
Old Apr 6, 2009 | 02:20 PM
  #37
Ryephile's Avatar
Ryephile
Thanks Hubie, I had a feeling this was the case. My concern was AFR is an absolute ratio [like making an adult beverage, 1 part fuel and 9 parts air], not a relativism like he was presenting it as [as a conversion of measured Lambda]. Perhaps it would've been better to offer the actual Lambda measurement instead of making himself look bad by quoting the wrong representative AFR.
I think the vendor bashing needs to quiet down. Perhaps some of them can offer way to help the original post....and remember E85 is not a good solution for maintaining fuel economy while increasing power.
Regards,
Ryan
Old Apr 6, 2009 | 06:24 PM
  #38
Nazrin's Avatar
Nazrin
still want teh E85 conversion!!! lucky Brunei still pumps it in abundance..cheap too...
Old Apr 6, 2009 | 06:55 PM
  #39
Ryephile's Avatar
Ryephile
10% power gain for 40% loss in economy, hardly makes sense to these pragmatic eyes.
Old Apr 7, 2009 | 01:16 PM
  #40
Mike@Mynes's Avatar
Mike@Mynes
Lastest tank of E85: 234 miles (all city driving)
mods: 06 MCS - Cam; 15%; MegaMynes Header; Invidia exhaust; Bosch 550cc OE Injectors; Mynes custom tune (248whp/198wtqe on E85)
Old Apr 7, 2009 | 02:02 PM
  #41
JIMINNI's Avatar
JIMINNI
See below.
Seems normal to me. Thats pretty much what I get "all city driving".
Old Apr 7, 2009 | 03:03 PM
  #42
kapps's Avatar
kapps
Just my 2 cents.
Eh, sorry, I'm thinking NA motors. They're all going to be a little different but peak power will be in the 12-13:1 range on pump gas. With the MINI being force fed, it needs to be a little lower.
Still, an 'economy tune' is going to be done at part throttle. I can almost guarantee that we're running at or over 1 lambda when cruising. With low combustion pressures, high advance and A/F ratio can be used to boost economy.
Old Apr 7, 2009 | 05:25 PM
  #43
astrochex's Avatar
astrochex
And at least in California, E85 is 13.3% cheaper than regular gas ($1.97/gal. vs $2.28/gal) so for premium the price would be roughly $2.48/gal for a difference of 20.6% which does not offset the loss in economy. Perhaps there is an E85 sweet spot for more or the same power with improved fuel economy.
Old Apr 8, 2009 | 08:18 AM
  #44
Bigshot's Avatar
Bigshot
No way would I live with that kind of mileage. Even after a tune. 215 hp with 350 mile tanks are fine by me.
Old Apr 8, 2009 | 08:40 AM
  #45
Wake|MCS's Avatar
Wake|MCS
350 mile tanks!? The only way I see that kind of mileage is if I do mainly highway which never happens. I get about 250-270 miles on average depending on my driving, but it's mainly city driving and the very little bit of highway driving is in traffic anyways, so it still sucks. When I'm lucky and there isn't traffic on the highway and I drive with gas mileage in mind I get about 300 miles (again with mainly city driving).
For me, I know I have to fill up about once a week. As long as I can control my right foot enough to make a tank of E85 last me that full week it's fine by me.
Old Apr 8, 2009 | 08:41 AM
  #46
Mike@Mynes's Avatar
Mike@Mynes
your car gets 350 miles per tank in the City? for you.
Old Apr 8, 2009 | 08:42 AM
  #47
Bigshot's Avatar
Bigshot
sorry.....that is my highway mileage......
I get about 300 with city driving.
Old Apr 8, 2009 | 08:47 AM
  #48
Wake|MCS's Avatar
Wake|MCS
That's about a 22% difference from Mike's car on E85, E85 is about 20% cheaper than 93 Octane and provides about 10% more power. Worth it to these pragmatic eyes.
Old Apr 8, 2009 | 11:29 AM
  #49
Ryephile's Avatar
Ryephile
You guys comparing your "miles per tank" is absurd. I could say I'm getting 121 miles per tank but it wouldn't mention at all that I only filled up with 3.9 gallons of gas. Bring the data or it doesn't exist. Oh, my percentages from above are based on the chemical difference between E10 and E85 and their respective stoich differences, not just picking that out of thin air.
If you're looking for outright power, E85 WILL gain power If you want to also keep fuel economy, you'd be fooling yourself to think E85 is a good solution.
Old Apr 8, 2009 | 11:35 AM
  #50
Mike@Mynes's Avatar
Mike@Mynes
City driving on E85: 18.1MPG (this is achieved by dividing the miles on my Trip meter by the # of gallons before the pump clicks off on its own).
