Catless Downpipe Options?
Hey guys I did a search and read through some threads but I was wondering if this was the only catless downpipe?
https://www.northamericanmotoring.co...pe-fitted.html Also I have a 09 JCW car ... will these downpipes still fit? What other options are out there??? |
you could use the exhaust depot one it cuts out both cats. but it throws all sorts of cels. the one you metioned above only throws one if that. i just ordered that one
The ragazzon is a direct fit to your stock exhaust. The exhaust depot dp has to be welded on. As far as throwing codes, there is no difference between the two because the secondary cat is after the second O2 sensor. I'm currently throwing code P0420 with the Ragazzon. I will be trying out the non-fouler method this weekend to see if it helps at all.
Tintman , how long do you have your Ragazzon for? how long did it take to throw a code? so far , im pushing it for a week with the fouler and everything is OK
Originally Posted by tintman718
(Post 2695243)
So there are two cats on the car?
Does the Ragazzon only remove the first one? Ideally I would want something that removes both and that you run a CEL fix on like this: http://rissracing.com/alpha/?page_id...3&product_id=7 |
what is the non fowler method
Originally Posted by AkFarina
(Post 2695264)
http://www.energeticforum.com/renewa...n-foulers.html :thumbsup: |
cat back exhausts remove the second cat, and downpipe removes the first
Originally Posted by MiniPOLACK
(Post 2695279)
Aaaah: Cat-Back ----> from the cat back, so it leaves the cat, hence cat back. |
how is the noise without the cats? highway drone etc?
Originally Posted by JAceMin
(Post 2695377)
Aaaah:
(Post 2695249)
Did you use two non-foulers? (one being drilled and one not?) That sounds great that you made it a week without a code. Honestly, if you made it that long, it's very unlikely it will in the future. |
I just used one non fouler on the bottom sensor ( after cat ) , that fouler has one hole on the bottom. i picked it up in pep boys. i think one package contains 2 pieces.
(Post 2695471)
3 Attachment(s)
no its not that. people want to put the non fouler on the first sensor ( pre-cat ) which is way thicker and it wont fit that hole. in a first place, you dont need the non fouler on that sensor .
Attachment 40592Attachment 40593Attachment 40594 |
