can't go to the Dyno with these mods, a problem?¿
Hi everyone,
i just bought all these mods to my r53:: 1.pulley 15% 2.JCW intake 3.Spark plugs 4.Alta Intercooler 5.A new Cam 6.Alta headers and 2.5 exhaust, around 1500$( are there better exhausts?) 7.JCW 380cc injectors How many HP will gain with these mods? and i have a problem that i can't go to the dyno because here nobody haven't,and i live in an Island, is that a problem if i buy all that mods and not reflash the ECU? thanks |
With those mods I would highly recommend you have the car tuned to get optimal results.
yes i also would like to go to the dyno, bit here there aren't any, is why i ask if i would have good results with those mods without dyno
Originally Posted by itonano
(Post 2618635)
I think you need JCW map duo to JCW injectors. You can get it from the dealer :wink:
A dyno tune is best but I ran mine with simular mods and the JCW flash for awhile, it ran pretty good too.:thumbsup: The JCW flash will compensate for the larger injectors.
what is a JCW map duo? where can i get that online?, must be online because i can't get from the dealer as there aren't here
No dealer there?:sad: ..... You can't get the JCW map anywhere else...:no: Might have to look at one of those canned tunes.....
no dealer here in the island:(, what a damn...there are dealers in the other 2 island near here but not in mine..well i just bought a CD software to reflash my ECU, that would be fine i think with all that mods
Good luck and let us know how it goes! What Island are you on?
thank you, i hope i do, will reflash my ECU with the software and my laptop but without dyno because i can't, but that's good also.
Im from Spain, and live in Menorca island, near Palma and Ibiza, search in google hehe, bye |
BTW have you got any idea about Unichip?
This is supposed to be better in terms of tuning than running a unichip.
Good luck with the tune. http://www.haltech.com/index.php?opt...d=24&Itemid=21 |
i saw the unichip and how to install in youtube, i think better the tune
Check out the one above i posted, this is along the lines of what you want to do, it works with your laptop and you can fine tune the ecu to work with your mods, closer to a tune than the unichip piggyback for sure.
If a tune isn't available to you.... this will probably get you the closest results.. |
I just said Unichip because there isn't another solution. No JCW flash no tuner :sad:
ok thanks midnitecoop, but the page dpoesn't work, i will buy a software here to work with my laptop, is similar
Make sure you know what your getting into with the Unichip, I know many people have had problems with it, Im not saying not to get it, search nam for some information
links fixed sorry about that.
From what I've read this is more fine tunable than a unichip. |
yes, im gonna do a tune, not a unichip
| All times are GMT -7. The time now is 06:46 AM. |
