Drivetrain The WOT Box - Adds 2-step Launch Control and No-lift shifting!
Old Oct 14, 2008 | 08:59 PM
batrugger's Avatar
batrugger
What do you guys think of this. It can be adapted to the MINI:
http://forums.vwvortex.com/zerothread?id=3979857
The WOT Box adds two major features to any car. They are No-lift shifting and 2-step launch control.
The No-Lift Shift feature makes no-lift shifting easy by cutting your engine's ignition for a very short period while you no-lift shift. No-lift shifting is keeping the gas down through the shifft. The ignition cut allows the synchros in your transmission to mesh easily, reducing the chance of missing a gear and damaging your transmission. Keeping your foot down through the shift also allows you to hold boost through the shift, thereby significantly improving your E.T.
The major benefits are:
  • Lower ETs
  • Reduced chance of missing a gear
  • More consistent, effortless shifts
  • Reduced wear on the transmission
  • Reduced chance of major transmission damage
The 2-Step Launch Control modulates the ignition by dropping power to individual ignition coils to hold the RPM you want to launch at. The turbo will spool up while you do this. You can use this feature for a more consistent and more powerful launch in boost!
Discuss
I don't know about the launch control, but the no lift shifting sounds intriguing.
Old Oct 14, 2008 | 09:12 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
This will be interesting...I have always thought that you had to have a stand alone management system to achieve this...but I am always learning...
Old Oct 14, 2008 | 09:27 PM
checkmate2006's Avatar
checkmate2006
Not really its more of an signal intercepting/manipulating gadget. Its along the same lines as say an AFC how it manipulates the present operations.
Old Oct 14, 2008 | 10:32 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Seems like it will cheapen the skills we develop as drivers. Making fast, accurate, clean shifts is something I've spent loads of time perfecting.
Old Oct 15, 2008 | 02:21 AM
MINI_chili's Avatar
MINI_chili
I have a friend who's crazy about the Mazdaspeed 3 and he says it's built to handle no-lift shifting stock. I can see how it's more of a plus for turbo applications. From what I could gather from that thread it looked like it was specifically for VWs and Audis. Just out of curiosity, were you saying this IS already applicable to the MINI or, bringing this up as a possibility that it may be compatible?
Old Oct 15, 2008 | 05:30 AM
PGT's Avatar
PGT
Cobb Tuning offers this on their AccessPort for Subaru's. Since the throttle is drive-by-wire, it's tunable and controllable. What it comes down to is the talent of the guy hacking the code (i.e. you get what you pay for).
Old Oct 15, 2008 | 06:50 AM
chad1140's Avatar
chad1140
Most of our cars are still under warranty heck I shift all the time w/o lifting the gas. Our cars are after all drive by wire. I was especially relentless on my 2004 and no probs with that.
Old Oct 15, 2008 | 06:56 AM
batrugger's Avatar
batrugger
It could be adapted:
You need three main things for the WOT Box to work:
  • A throttle position sensor or accelerator pedal position sensor - Nearly all cars have this, so it is a given
  • Fuel injection or Coil on plug ignition - Again, 99.99% of cars....
  • A clutch "up" switch
The last one is where it can get tricky. Most cars that have cruise control will have this switch, but I have seen some with cruise that don't have it. The best way to tell for sure is to stick your head up under the dash and check. You are looking for a switch that is tripped with just a slight amount of clutch pedal travel. This is a different switch than the starter - clutch interlock switch. That switch is not good for us because it requires way too much pedal travel to actuate. We have found that most of the VWs and Audis have this switch, except the 98 and 99 A4 1.8T cars, for some reason.
Let me know what make / model / year car you have and I can check my wiring diagrams and confirm the wire colors for you as well.
Old Oct 15, 2008 | 04:17 PM
daegerter's Avatar
daegerter
true story! thats what all the new "not-so-rice" drivers who think theyre all that cause they can shift so well, when in reality their cars do it all for them
also, we have superchargers, the boost builds instantly with the rpms of them engine whereas with a turbo'd car you have to have air flowing through the engine to keep the turbo spooled (assisted by the blow off valve) and making boost
the launch control sounds pretty cool if it works though!
Old Oct 15, 2008 | 04:44 PM
ScottRiqui's Avatar
ScottRiqui
I see where you're coming from, but technology will continue to evolve, and you can't draw a line in the sand and say "any technology beyond *this point* cheapens the driving experience".
Thanks to synchromesh transmissions, we no longer have to double-clutch every single downshift. Likewise, anti-lock braking systems mean that "threshold braking" isn't as important a skill as it once was.
In these days of fuel injection and inexpensive exhaust gas analyzers, my skills at synchronizing carbs and reading a Gunson Colortune are pretty much obsolete, but that's the way it goes.
Remember, every time you talk about some new technological development "cheapening" your skills or the driving experience, there's some MGA driver snickering at your fancy-schmancy power steering, power brakes, and points-free electronic ignition.
Old Oct 15, 2008 | 06:20 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Duely noted, and I do want a car with no fancy systems like you mentioned, so I can learn more.
Old Oct 15, 2008 | 06:48 PM
chadtoolio's Avatar
chadtoolio
LOL, my boss said the other day that the new kid wouldn't even know what points were.....I said, that's a good thing, who wan'ts points?
Old Oct 15, 2008 | 06:59 PM
ScottRiqui's Avatar
ScottRiqui
True - while it's nice that just about any problem with points can be solved with a screwdriver, a spare condenser and a matchbook, the drawback is that eventually, you're going to *need* the screwdriver, matchbook and condenser, usually out in the middle of nowhere when you're already running late.
Likewise, I don't miss having to top off the oil in my carburetors and shock absorbers, or adjusting the carbs twice a year as the seasons change or if I go up into the mountains for a trip.
You know what they say about anyone driving an old British/Italian car - He's either a self-taught mechanic, or he's about to become one, possibly in the next five minutes.
Old Oct 15, 2008 | 08:26 PM
batrugger's Avatar
batrugger
No lift shifting is something that would outperform regular shifting and be pretty cool to have. Have any of you tried the VW/ AUDI DSG. I saw a comparison and basically there isn't a pro driver that can shift as fast and smoothly as it does. It has two clutches and actually rev matches for you. Technology at work.
Old Oct 15, 2008 | 08:47 PM
gnatster's Avatar
gnatster
May I present....
Technology is great, I'm all for it. But I also want to at times to be engaged more in the act of driving. Good thing there are so many used low tech cars out there.
Old Oct 15, 2008 | 08:57 PM
ScottRiqui's Avatar
ScottRiqui
Originally Posted by gnatster
May I present....
bah - Fuel injection, solid-state digital ignition, full-synchro transmission with overdrive, sealed shock absorbers, power brakes, dual airbags, and a $61,000 price tag. The wheels are even standard five-luggers, unless you pay $3000 extra for true center-mount knock-off wheels.
That's more for the people that like the "idea" and appearance of low-tech without actually having to deal with low-tech.
Old Oct 15, 2008 | 09:07 PM
gnatster's Avatar
gnatster
This better....
Doesn't even have door handles...but does have dual SU's
Ugh yeah, someplace this is a thread about a high tech product....
Old Oct 15, 2008 | 09:09 PM
ScottRiqui's Avatar
ScottRiqui
Much better - LOVE the Bugeye Sprites!
Old Oct 16, 2008 | 04:19 AM
norm03s's Avatar
norm03s
This better....
I've got a set of SU's in the garage for you that will fit that!
Old Oct 16, 2008 | 04:12 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
So could you run this just for the two step?
Old Oct 16, 2008 | 04:22 PM
batrugger's Avatar
batrugger
Yes you can
We sell the WOT Box in 3 versions:
  • No-Lift Shift ONLY $129
  • 2-STEP ONLY $129
  • No-Lift Shift AND 2-STEP $189
Old Oct 16, 2008 | 04:46 PM
littlehandegan
I wanna revz and shootz flames....
Old Oct 17, 2008 | 03:34 PM
broadwayline's Avatar
broadwayline
Has anyone emailed them to ask them if it would work?
Old Oct 17, 2008 | 03:52 PM
r52pimp's Avatar
r52pimp
The argument of new technology making basic skill obsolete doesn't hold water. It's like saying we shouldn't teach math and reading/writing because we have computers with calculators and spell checkers available to us.
Old Oct 17, 2008 | 03:57 PM
batrugger's Avatar
batrugger
I f you read the thread about it, they say it will work with any car that has:
If you email them they will give you specific instructions for your car.
