Drivetrain Does anyone own an Alta oil catch can?
Old Sep 5, 2003 | 07:20 AM
MSFITOY's Avatar
MSFITOY
If so, I would very much like to know how it operates (interior design) so that I can replicate one. Anyone else interested?
Old Sep 5, 2003 | 08:18 AM
cdconsor's Avatar
cdconsor
Pretty sure Randy uses one and I was planning on it so I'm interested.
Chuck
_________________
woo-hoo!!! finally have a production number!! Motoring by December!
Old Sep 5, 2003 | 08:29 AM
gmack's Avatar
gmack
Sounds like a good idea to me, I was planning on putting it on x-mas list. I'm curious what happens if you forget to empty it ?
Old Sep 5, 2003 | 09:39 AM
grizzy727's Avatar
grizzy727
It should take a while to fill up, cause afterall it is your engine oil.
Its a fine mist of oil if anything that will be sucked back into the intake then combusted again. So if it fills up that means you are losing oil which isn't good.
This is my specualtion, but I did do this on my Acura GSR and no problems for 4 years. Not quite a catch can, but a mini KN air filter on crankcase nip
Mike
Old Sep 5, 2003 | 07:26 PM
BlueMCS's Avatar
BlueMCS
Over the side with it. Its not a British car if it doesn't leak something!
Old Sep 6, 2003 | 07:17 AM
MSFITOY's Avatar
MSFITOY
Can't believe it....no one owns one. When I inquired about getting a red one Alta told me they are back ordered. Who's using this....please stand up
_________________
Old Sep 6, 2003 | 07:47 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
I do have one, and I just sold my last red one, but I'll check on supply for the stcok order on Monday.
It doesn't fill up quickly at all, as you are removing crankcase vent oil from the supercharger/intercooler loop. As someone said above, it's a fine mist of oil, not an oil line.
I think it is a good idea for longevity of the supercharger and it does help performance slightly because of the oil removed from the intercooler loop which displaces additional airflow.
It is not a wonder piece, but it is well built and functions as advertised. It costs about $120. If you haven't done the intake or a swaybar I would really suggest you do those mods before you spend monet on a catch can.
Hope that helps!
Randy
Old Sep 6, 2003 | 01:30 PM
ceberlik's Avatar
ceberlik
!!!BEWARE!!! :evil:
I attempted to install the catch can over last weekend and IT DID NOT FIT!
I contacted Alta and they said that it does not fit some 2003 models. They moved the grounding bolt too close to the motor mount so it wont fit. Adam, at Alta, told me that there are some other locations it can be mounted and their tech department is developing a hardware kit to relocate it to a different place in the engine bay that they will send to catch can buyers with these specific cars. The tech dept. was supposed to send me an email, but never did. Adam mentioned that depending on if the 2003+ models have ASC or DSC makes a difference in fitment, or new location, but that is all the info I have. What a pain.
If you are concerned about fitment of these kits on your car, before ordering, I suggest you give Adam or Alta's tech department a call first to make sure you won't have to find out the hard way that it won't fit.
(Side note: I don't even want my catch can anymore. It is a black kit with black hoses and black catch can. If Alta won't take it back I will sell it at retail with free shipping to whoever doesn't want to wait on a backorder list forever like I did with my intake. PM me if interested.)
_________________
ssssshhhh . . . don't wake the JCW sleeper!
Old Sep 7, 2003 | 07:18 AM
MSFITOY's Avatar
MSFITOY
Hi Randy. Can you explain how this unit works internally. I thought if it were simple enough, I'd make my own.
Old Sep 7, 2003 | 08:33 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Silver, give me a call. It is very easy and I'm sure you could make one. I'll talk you through it.
Randy
720-841-1002
Old Sep 8, 2003 | 11:55 AM
MSFITOY's Avatar
MSFITOY
>>Randy
>>720-841-1002
Hi Randy,
Your mail box is full Can you PM me so I can give you my number? I've tried PM and emailing you to set a time for the pully party in Detroit but got no response. Thanks much.
_________________
Old Sep 8, 2003 | 01:19 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Here's a much less expensive alternative:
http://store.summitracing.com/produc...169&p=1560
Old Sep 8, 2003 | 03:04 PM
MSFITOY's Avatar
MSFITOY
Thanks for tip
Is just me or my timing? I just can't seem to get a hold of Randy by email, PM, or phone :???:
Old Sep 8, 2003 | 04:56 PM
cdconsor's Avatar
cdconsor
Andy,
are you using one of these? How did you mount it? I assume that it is not MINI specific.
CHuck
Old Sep 8, 2003 | 05:00 PM
MSFITOY's Avatar
MSFITOY
Andy, did you do the "dog's bollocks" your self? Or does Helix offer the decal in silver like yours?
Old Nov 13, 2003 | 11:59 AM
Bisch's Avatar
Bisch
So, has anyone installed this Summit tank? Did you use a return line, or terminate at the tank?
Old Nov 13, 2003 | 12:27 PM
andy@ross-tech.com
cdconsor wrote:
Andy,
CHuck
I'm not using one myself, it is a generic piece. A friend uses one on his Auto-X VW Rabbit with great success. He had an oiling problem in his engine that filled the can with oil at one event! Better a full can than oil on the track.
Helix slapped it on my car without my knowledge.
It looks like you could take off the filter on top, and in its place run a line back to the stock inlet location just upstream from the throttle body.
_________________
1/4 Mile Database
Old Nov 13, 2003 | 02:56 PM
Bisch's Avatar
Bisch
Do you have to recirculate, or could it terminate without detrimental effects? Benefits either way?
Old Nov 13, 2003 | 03:18 PM
andy@ross-tech.com
That's a good question. Auto manufacturers tend to recirculate to reduce emissions and to keep the engine compartment clean. There are no touching, moving parts in the supercharger that see intake air, so the oil definitely isn't needed there. Engines seem to work just fine without having a mist of crankcase oil sprayed into their throttle bodies or intake manifolds. I can't think of any downside to external venting other than emissions and potential messiness.
Old Nov 13, 2003 | 04:55 PM
MiniPilo's Avatar
MiniPilo
I have the alta on my car. HEre is some info. For certain cars, IT DOES NOT FIT. I know this as my car was one of the cars that it does not fit on. But... Here is what does work... and Alta, If you want, you can call me about this. I made a small bracket, and put an extra bolt in, and it fit with not much hassle. The piece can be made for about 2 dollars.
The catch can does in fact catch, More that I though. For people looking to get others, Be careful as the place it goes is very space limited. and a larger one may infact not fit.
Dan
Pilo Racing
Old Nov 14, 2003 | 07:13 AM
andy@ross-tech.com
What kept the Alta can from fitting in your car?
Old Nov 14, 2003 | 08:01 AM
Bisch's Avatar
Bisch
I saw one at the Boston pulley party. I was very surprised to see it more than 1/2 full of sludge! :smile:
Old Nov 14, 2003 | 08:57 AM
MiniPilo's Avatar
MiniPilo
MINI moved the Grounding bolt back about 1.5" from where it needs to be. It should be about 1.5"-2" behind the hood latch on the passenger side of the car. Mine was about 3" back.
Dan
Pilo Racing
Old Nov 14, 2003 | 09:21 AM
andy@ross-tech.com
If I install a catch can, this may be a good place to put it (next to the ABS controller in the passenger side cowl):
Old Nov 14, 2003 | 09:24 AM
macncheese's Avatar
macncheese
I dont think its legal to not recirculate it. The catchcan doesnt "catch" everything because some of it is just blowby gas and there's nothing to trap vapor in the catchcan. All this pollution will come out the breather and into the atmosphere.
Cheese
