Drivetrain Remus clamps, anyone know where to get these?
Old May 5, 2008 | 08:06 AM
davydo's Avatar
davydo
The clamps to the rear of the pic have rusted to nothing on my 04 MCS. Anyone know a suitable replacment? Thanks
Old May 5, 2008 | 08:52 AM
Bahamabart's Avatar
Bahamabart
Most boating stores carry Stainless steel clamps like those.
http://www.westmarine.com/webapp/wcs...key=SiteSearch
Old May 5, 2008 | 10:51 AM
davydo's Avatar
davydo
The clamp is not really just a t-clamp, it's a double saddle design, like this one:
This is a walker 82501 from a Peugot 106. I can't find it anywhere, and Remus USA told me to call Austria!
Old May 5, 2008 | 11:25 AM
Bahamabart's Avatar
Bahamabart
The SS clamps are superior.
Old May 5, 2008 | 12:12 PM
davydo's Avatar
davydo
Thanks, but they are for a different application, a slip fit... What the Remus has if you look toward the back of the pic above is a union of two flared joints with a round steel donut in between. The clamp squeezes the flares against the conical donut making a seal. A flat band will not squeeze everything together.
Old May 5, 2008 | 01:51 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
MCMASTERCARR.COM Try them!
Old May 5, 2008 | 02:26 PM
davydo's Avatar
davydo
Tried them thanks Adam :( The only thing I have found is a Walker repair kit, which has two clamps with a spring that you assemble that squeezes the joint together. They were $20/ea, I am going to try them tonight.
It also looks like a Bosal Audi 80/VW vanagon clamp may be the same, but I cannot find any dimensions.
Old May 5, 2008 | 02:59 PM
miniconcarne's Avatar
miniconcarne
Are they like this?
Link http://www.jegs.com/p/Stainless+Work...10002/-1/11527
Old May 5, 2008 | 04:19 PM
davydo's Avatar
davydo
No, but I am going to try a vband type like that next. I drove 40 miles today to get a set that didn't work out :(
I took some good measurements tonight, but it is the exact clamp in the photo above, the same as on the Peugot 106. Bah, what a pain!
Old May 5, 2008 | 04:23 PM
davydo's Avatar
davydo
I may also just cut off the joint and use one of these:
http://www.jegs.com/i/Dynomax/289/33230/10002/-1
Old May 5, 2008 | 09:37 PM
heyduard's Avatar
heyduard
Is that the correct part number? I did find a listing of Walker clamps at partsAmerica.com. Otherwise, you may have order from France.
Good to know that the clamps rust away. I haven't installed the Remus yet; I will try a high-temp coating on the clamps and upgrade the bolts.
Old May 6, 2008 | 06:31 AM
davydo's Avatar
davydo
I called Walker, they do not offer that part to us :( I did find that it looks identical to the Bosal Audi 80 / VW transporter exhaust clamp, I ordered two different sizes from parts authority for 5 & 14.00 respectively. This is a drag. Local muffler shop offered to for $250, chop my nice remus to bits and weld it together. Buzz.
If the two clamps don't fit, I am dropping the muffler, using an air hacksaw to remove the two flanges and using butt joint clamps. The problem is that these pipes seem nonstandard in size.
I emailed all remus addresses I could find. This is the "after sale" part that they aren't doing so well at. I do wish the PO of my car had selected Invidia or Millitek!
Old May 6, 2008 | 06:50 AM
Martin Brenneke's Avatar
Martin Brenneke
Look up a ford 8n or 9n parts page they have a clamp that looks exactly like that for the tailpipe muffler assembly. Just bought a new one for my tractor for about $6.00 plus shiping.
Old May 6, 2008 | 07:53 AM
heyduard's Avatar
heyduard
You mean like this? I hope it's one size fits all.
Old May 6, 2008 | 08:11 AM
Martin Brenneke
Yes. IT WILL EXPAND and hopefully will handle the problem. Price is right even if you have to order one to see if it will work . Good Luck.
Old May 6, 2008 | 09:03 AM
davydo's Avatar
davydo
Yeah, I saw tractor supply had one like that too. I have a big ol' Kioti tractor for my dirt motoring
Thanks for posting, I will update the thread once I get the brackets.
Old May 6, 2008 | 06:34 PM
Trickle X's Avatar
Trickle X
Honestly....I would just weld them together & be done with it...take all of 5 mins.
Old May 8, 2008 | 05:13 PM
davydo's Avatar
davydo
I'm sure it would crack, these clamps allow a small amount of pivot. I found a Bosal exhaust clamp that looks right, bosal #254-930. Yes, it's $4.00!
http://www.amazon.com/Bosal-254-930-Clamp/dp/B000CF3GN6
I need to fit it but I think the case is closed.
Old May 19, 2008 | 09:17 AM
heyduard's Avatar
heyduard
How's the fitment? It seems Amazon, itself, carries the clamp at $17 a pop in case you need more. The amazon seller that's linked seems to have very limited stock - just one.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
OutMotoring
Mar 3, 2017 06:29 AM
gknorr
Dec 26, 2016 09:38 AM
gnhovis
Dec 14, 2015 05:31 PM
vetsvette
Oct 11, 2015 06:05 PM
