Drivetrain Need your help...pulley install/oil leak?
Old Apr 2, 2008 | 05:15 PM
MCS06's Avatar
MCS06
Would appreciate your expertise as my 2006 MCS with 14,500 miles is going to the dealer next week due to an oil leak. I had a 15% pulley installed by an excellent independent BMW mechanic back in February.
I want to be prepared with info in the event the dealer tells me it is not covered under warranty (or that the pulley is the cause).
So...is it possible a pulley install could lead to an oil leak? On the garage floor, it is a very small spot somewhat in the middle, but closer to the driver's side. Got on the ground to look underneath, but to no avail.
I'd be grateful for any and all input. NAM is and has been a great place to learn. Thanks everyone.
Old Apr 2, 2008 | 05:27 PM
xsmini's Avatar
xsmini
Off the top of my head I cannot see how a pulley instal could cause an oil leak. There have been oil pan gaskets that will leak (mine included), and should be covered under warranty.
Sorry not much help.......
Nik
chadtoolio's Avatar
chadtoolio
Only way I see a problem is if the oil is coming from the supercharger in the front....
Old Apr 7, 2008 | 08:44 AM
MCS06's Avatar
MCS06
Found out it was the crankshaft seal. Is it possible the smaller pulley giving more boost, heat generating, could have added stress to the seal causing it to leak? I'm a newbie car enthusiast attempting to understand the mechanics of things.
Thanks.
Old Apr 9, 2008 | 06:54 AM
Grassroots Garage's Avatar
Grassroots Garage
The pulley did not cause the leak. The front crank seal is prone to leaking, but it's still still odd for such a new car. It should be covered by warranty as there is really no corrolation between it and the pulley install.
--Dan
Old Apr 10, 2008 | 03:24 AM
MCS06's Avatar
MCS06
--Dan
I appreciate the info. Thank you. Brought it to the shop earlier this week and it was covered under warranty. No more leaks (for now)!
ian260
Mar 29, 2017 06:08 AM
Cruzer214
Oct 11, 2015 07:45 AM
Oct 1, 2015 12:13 PM
JAB 67
Sep 29, 2015 01:34 PM
donniedarko
Sep 29, 2015 01:16 PM
