Drivetrain Opinions on manual transmission fluid
Old Feb 13, 2008 | 06:07 PM
spdfreak's Avatar
spdfreak
I'm getting close to pulling the pin on an LSD/clutch flywheel swap, and I'm looking for people from colder climates (Northern USA or Canada) to chime in on what manual transmission fluid they've found works for them.
Old Feb 13, 2008 | 06:28 PM
second to none's Avatar
second to none
I would go with OEM fluids. Theres no need for anything more.
Old Feb 13, 2008 | 06:39 PM
hemiheaded18's Avatar
hemiheaded18
Now granted, I have an R50 with the Midlands, but I used Redline's stuff. I forget if it was 80W90 or 75W80. I think it was the 75-W80. I live in PA and we've had a fairly cold winter at some points and I have no complaints on it. Bet on it being way cheaper than OEM fluid.
Old Feb 13, 2008 | 09:28 PM
UKSUV's Avatar
UKSUV
Dude...you should have ran the Redline MTL instead of their gear oil (unless you have an auto then I dont know). That stuff goes in my 3-series diff...
Old Feb 13, 2008 | 09:34 PM
red_line's Avatar
red_line
+1 for Redline MTL
Old Feb 13, 2008 | 09:54 PM
tazio's Avatar
tazio
+2
Old Feb 13, 2008 | 09:59 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Im still waiting for 40k to change my fluid with redline MTL. Im sitting at 39,200 or so. I want my intervals to be even.
Old Feb 14, 2008 | 04:44 AM
mbcoops's Avatar
mbcoops
+3 MTL
mb
Old Feb 14, 2008 | 07:00 AM
MirthScout's Avatar
MirthScout
What is the MINI recomended change interval?
Is Redline MTL good for use with a LSD?
Old Feb 14, 2008 | 08:50 AM
Fei's Avatar
Fei
Redline MTL.
I think there is a different version of Redline MTL to use with LSD, MTL-90 maybe?
Old Feb 14, 2008 | 11:32 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
To MINI the transmission fluid is lifetime meaning they say you never have to change it.
Old Feb 14, 2008 | 11:50 AM
the platform's Avatar
the platform
Thats the line I encountered.I find this hard to accept.
After seeing so much about changed tranny fluid extending the life of a tranny,how does this jive(jibe).
Where's Dr.Obnoxious?He'll know.
I have an MCSa,sitting just shy of 20,000.
I want to be pro active,not drinkin dealer coolaid.
Old Feb 14, 2008 | 12:09 PM
Mini_Crazy's Avatar
Mini_Crazy
MTL for both Std. & LSD
Redline tech support says that MTL is the right stuff for both the LSD & non-LSD Mini transaxles. (MT90 is a higher viscosity ~90wt transmission fluid.)
Redline MTL provides slightly smoother shifts than the factory fluid. (Synchros seemingly do their job with less force required.) You get a "silkier" shift in my 2005 MCS w/LSD
Old Feb 14, 2008 | 01:04 PM
MirthScout's Avatar
MirthScout
Thanks. My 06 MCS is at 42K miles now. I'll probably drain and refill soon.
Old Feb 14, 2008 | 01:46 PM
UKSUV's Avatar
UKSUV
Thats funny...because the Redline tech said for the LSD you should use MT-90.. I dont know then. It has everything to do with the synchros..
Old Feb 15, 2008 | 07:16 AM
sranderle's Avatar
sranderle
Anyone use Amsoil fluid for a 2005 manual transmission?
Old Feb 15, 2008 | 01:11 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
I don't follow what the factory says for a lot of things. This is one of them. The plan for me is a transmission flush every 30k miles or so (which would be about once a year). I have one of the Redline fluids in right now (not sure if it's MTL or MT90) and that's what I plan on sticking with.
Old Feb 15, 2008 | 07:31 PM
hemiheaded18
I did use the MTL and I could have sworn it was 75-80 or something like that on the bottles. I asked on here and everyone said MTL. I wouldn't use gear oil if no one said to.
Old Feb 15, 2008 | 08:07 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Redline MTL. Works great and smooth shifting on the coldest of mornings here in New Jersey.
Rich
Old Feb 16, 2008 | 01:21 AM
UKSUV's Avatar
UKSUV
If it had 75-80 or something like that...You have the gear oil and not MTL...
Old Feb 16, 2008 | 08:43 AM
DME's Avatar
DME
+1 for Redline MTL
Changed my 32K mile factory fluid and the shifts were a bit better.
Thankfully the factory fluid still looked good.
Dave
Old Feb 16, 2008 | 03:08 PM
marco621's Avatar
marco621
How many quarts of Redline MTL would someone need when changed their trans fluid?
Old Feb 16, 2008 | 04:58 PM
Grassroots Garage's Avatar
Grassroots Garage
get 3 qts. Make sure the car is level when you fill it. Removing the p/s pump fan will allow better access to the fill plug. It will take about 2-1/2 qts.
MTL is the proper fluid for all 5 and 6 speed MINI manuals, especially in colder climates, and it is a GL-4 and is both 5w-30 and 70w-80. (don't ask me how, engine oils and gear oil viscosities are rated differently). MT-90 will work ok in very hot climates.
---Someone asked about the fluid in an MCSa auto trans, the aftermarket information suppliers (Mitchell, alldata) do not have info on this oil yet. I'm hoping to pick some brains at the dealer soon, but I guarantee it is not a generic atf, probably Esso LT71141 (Pentosin ATF-1) or similar. I have been looking with no luck so far, so the best bet, if you plan a service, is to get it from the dealer until the specs become clear.
CVT trans in the Cooper use Esso EZL-799, you can ONLY get this from the dealer, and anything else WILL damage the trans (thats not just a dealer scare tactic)
--Dan
Old Feb 16, 2008 | 05:19 PM
hemiheaded18
You want to try to prove me wrong again?
Old Feb 16, 2008 | 06:04 PM
Johan's Avatar
Johan
AMSOIL Synthetic Manual Synchromesh
Transmission Fluid
I run AMSOIL in everything I own for the last 10 years.
