Drivetrain NEW ALTA R56 Plug-n-Play ECU Q&A Thread
Old Jul 27, 2008 | 08:35 AM
  #576
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Originally Posted by Bigjoeski08
I just hit 1000 miles with the Unichip and my car is still running strong I just can't believe how stockish the car drives with all the extra power. Thanks Alta you are going to have all my business for every part you make.
blushes
Old Jul 27, 2008 | 09:04 AM
  #577
samroberto's Avatar
samroberto
AMEN.. haha they are particularly fun to deal with too aren't they ??
By the way, adam, PM SENT !!!
Old Jul 27, 2008 | 06:48 PM
  #578
ADAMSALTAMINI
GOT IT! Also replied back to you.
Chat tomorrow!
Old Aug 10, 2008 | 11:32 PM
  #579
ukaussi's Avatar
ukaussi
What is the max boost on the UNICHIP programming as the ALTA boost guage I just put in sometimes goes up to 21psi in 3rd ?
(this is not the ALTA programming on '1' but the Unichip on '0')
Old Aug 11, 2008 | 07:00 AM
  #580
ADAMSALTAMINI
One either map a flash to 21 psi is not uncommon and not reason for concern.
Thanks again!
Old Aug 12, 2008 | 12:30 PM
  #581
M!N!-ME's Avatar
M!N!-ME
Will this ecu work on a euro-spec r53?
Old Aug 12, 2008 | 12:43 PM
  #582
ukaussi's Avatar
ukaussi
No, R56 only as it is a completely different engine
Old Aug 12, 2008 | 09:47 PM
  #583
ADAMSALTAMINI
You got to it before I did!
We do have versions for the R53 Euro or otherwise.
Thank you!
Old Sep 11, 2008 | 09:03 AM
  #584
mini cooper's Avatar
mini cooper
I have a 2008 and i have had the unichip for almost 2months, i just recently had to take my car to the dealer because of a warning light that had come on, it was a engine outline that was shaded in yellow and a message came up "reduced power" removed the unichip and dealer said that it was a mass air flow sensor or a boost problem.
Old Sep 11, 2008 | 09:13 AM
  #585
ADAMSALTAMINI
Thanks for the post. I am confused. Did the UniChip come off, and the dealer then noted a problem with the MAF sensor and Boost? Or they said the UniChip caused the other problem?
Just curious. Regardless, let us know how we or UniChip can help you!
Chat soon!
Old Sep 11, 2008 | 09:24 AM
  #586
Dead Ringer's Avatar
Dead Ringer
this has happened to me 3x now. I thought it was a overheating issue, I had removed the grill behind the hood-scoop and figured that the airflow was causing the issue. Due to my wife causing a wreck in one of our cars, I have not driven the mini much the past two weeks (driving the rental car). But I am turn the rental back in today, and will be driving the mini more often so I will see if I keep getting this warning light, and the engine cutting power. It all started after I had the unichip installed, I didnt have any issues for two weeks though. The past 2x I had the warning light was after I removed that scoop grill, but last week I put it back in, will see if it makes a difference.
Old Sep 11, 2008 | 09:25 AM
  #587
Dead Ringer
I think he meant he got the warning light, he then took the chip off and took the car to the dealer...
Old Sep 11, 2008 | 09:30 AM
  #588
ADAMSALTAMINI
IT IS NOT THE GRILLE!!! You can cut a 4' hole in the hood, and it wouldn't affect anything.
The harness is BAD, lets get you in touch with UniChip ASAP to get you a new one! Sorry you had to deal with that at all!
Old Sep 11, 2008 | 09:41 AM
  #589
Dead Ringer
really, crap man that means I will need to take it back to Dynocomp and pay for them to install this new harness??? That will probably cost me an additional $45-100 depending on how long it takes them. They had issues with getting the old one in, what will it involve in replacing it? Is it like a whole new install?
Old Sep 11, 2008 | 09:45 AM
  #590
mini cooper
sorry i didnt finish my post. I had the engine light come on and then removed the unichip, took the car to the dealer and dealer could not find an issue.
My question is did the unichip cause the problem after nearly 2 months of use? The light has not come back on since, but i have not put the unichip back on. Is the unichip safe to use?
Old Sep 11, 2008 | 09:49 AM
  #591
ADAMSALTAMINI
It can be done at home in about 2 minutes. I believe you only have to replace the plugs, not the harness. UniChip will be happy to help with everything. UniChip is now handling ALL warranty claims directly. Lets get on the phone today and get things going for you.
Chat then! Thank you and I apologize on UniChip's behalf for the inconvenience!
Old Sep 11, 2008 | 09:52 AM
  #592
ADAMSALTAMINI
Without having UniChip testing it, I wouldn't put it back on the car. Contact our tech dept, or UniChip directly 503-640-7465 Ask for Jack Friedman or jack@unichip.us
Old Sep 11, 2008 | 10:01 AM
  #593
Dead Ringer
Lets get on the phone today and get things going for you.Chat then! Thank you and I apologize on UniChip's behalf for the inconvenience!
alright, well I just tried to call you, and was told you weren't there. I was instructed to call Unichip to handle it, called them and had to leave a voicemail with some tech guy. Any idea how long it will be before I can get this taken care of?
Old Sep 11, 2008 | 10:48 AM
  #594
mini cooper
thanks for the help......
Old Sep 12, 2008 | 11:23 AM
  #595
ADAMSALTAMINI
SORRY! Hectic day yesterday of multi-tasking! If you don't get proper reply from UniCHip let us know and we will do our best to help further!
Old Oct 3, 2008 | 10:50 AM
  #596
scott48's Avatar
scott48
So right now I'm waiting for my chip to come back from ALTA cause I'm getting it flashed for a 100 octane map.....I'm pretty curious to see how much more power she'll make..........anyone else try it with 100oct?
Old Oct 3, 2008 | 11:26 AM
  #597
fernflex's Avatar
fernflex
What whp and tq you got the last time?
  #598
ukaussi's Avatar
ukaussi
I am SO missing my Unichip right now. You really get used to that extra power/torque especially higher up the rev range. Different car to drive and I dont have many mods.
Should be interesting to see what the new flash is like as the old ALTA flash was not working properly on my car
Old Oct 3, 2008 | 11:29 AM
  #599
ACooperS's Avatar
ACooperS
Nope, but have been driving on map 1 (94 octane, sea level) since April. Keep us posted Scott.
Old Oct 3, 2008 | 10:12 PM
  #600
scott48's Avatar
scott48
It's arriving on tuesday, so I'll let you guys know then....hopefully with really good news.
