Drivetrain Friends, Romans, Countrymen! Lend me your ears!
Old Jul 1, 2003 | 07:23 AM
Mjolnir's Avatar
Mjolnir
That Subject should get your attention... :smile:
What to do!?
Would you do the H-Sport springs and Control arms + Brakes
OR
The EVOTech upgrade?
I can do one or the other right now. I'm leaning toward the springs becasue the cost of the EVOTech upgrade will likely go down in the next few months (while I save my pennies)
Thoughts?
-Jim
Old Jul 1, 2003 | 08:05 AM
itsthesize's Avatar
itsthesize
I have the springs and control arms, and I love it, don't have big brakes yet. But My opinion is to do the first mods, wait a while for the ECU stuff.
Peter
Old Jul 1, 2003 | 08:10 AM
Darksky's Avatar
Darksky
I agree. The springs for now. The ECU mod will probably become more reasonable in time.
Old Jul 1, 2003 | 08:13 AM
MGCMAN's Avatar
MGCMAN
Springs and control arms first!
Old Jul 1, 2003 | 08:17 AM
Grinder's Avatar
Grinder
The hardware seems like a better bet. Software's always changing and being improved, while it seems like a good set of springs don't get "improved" upon too often. That being said, what do control arms do again?
Old Jul 1, 2003 | 08:23 AM
Mjolnir's Avatar
Mjolnir
REALLY.
Wow. They're THAT good, eh?
Just as a side note, upgrades are free forever on the EVOTech flash...
-Jim
dandp's Avatar
dandp
What brake upgrades are you looking to do? I would tend to agree on waiting for further ECU development...I suspect alot of stuff is going to pop up for the MCS before long in that arena.
Old Jul 1, 2003 | 08:24 AM
Mjolnir's Avatar
Mjolnir
I'm mainly just looking to improve braking a bit and get rid of that CURSED BLACK DUST! :evil:
-Jim
Old Jul 1, 2003 | 08:29 AM
MGCMAN's Avatar
MGCMAN
The H-Sport springs will increase negative camber (making the wheels/tires squat with the tops in and the bottom/contact patch splayed outward) This causes increased wear on the inner tread and decreased contact with the road. The control arms will bring camber back in an adjustable manner to a more stock setting. They are the best of both worlds, as you can adjust for maximum performance for the track, or maximum longevity for the street.
Old Jul 1, 2003 | 08:47 AM
TwOMINIs's Avatar
TwOMINIs
So just the H-sport springs alone with increase negative camber and with then you need the control arms to bring it back into a more neutral position?
His, Chile RED all over, Madness intake, MINI-Motorsport Airbox Mod, Magnaflow Exhaust, BMP spark plug wires, RDR rear sway bar and Helix P/D 15% reduction pulley.
Hers, EB UJ on top and BONE stock.
Old Jul 1, 2003 | 09:04 AM
Sleepless's Avatar
Sleepless
You don't "need" the control arms if you like the -2 degrees of negative camber. If you prefer to be closer to stock, then, yes, you need the control arms so that the camber can be adjusted; without them, the camber is not adjustable.
Old Jul 2, 2003 | 07:01 AM
Mjolnir's Avatar
Mjolnir
Wow, not one vote for the ECU Upgrade... interesting. :smile:
Old Jul 2, 2003 | 08:42 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I would suggest the H-sport springs, adjustable rear swaybar, and brake pads (maybe EBC green)
Even without the adjustable control arms (two or four), a good specialty alignment shop will be able to make some adjustments to get the MINI back to factory specs. If you add the adjustable lower rear control arms then it makes it that much easier. After installing the springs alone the negative camber will be about -2.4 degrees in the rear. Stock setting is about -1 to -1.5 degrees.
second choice is the pulley and throttlebody before the EVOtech ECU upgrade for the MCS.
If for the MC then I would get lighter wheels before the ECU upgrade.
RIchard Nguyen
Sep 14, 2016 11:43 AM
bradstyle
Oct 1, 2015 11:15 AM
jennster
Sep 28, 2015 06:19 PM
gnhovis
Sep 28, 2015 04:07 AM
Mini Hooper
Sep 17, 2015 01:58 PM
