Drivetrain power fades off after 5500 rpm
Old Oct 18, 2007 | 04:49 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
My mini is just starting to get broken in, 3000 miles on it now
one thing that's irritating is the power fades off after about 5500 rpm, it's noticeable how much the pull drops
is this exhaust/air restricting flow at those rpm's? I've not really seen posts on this issue
I thought it could be the overboost stopping at that rpm, not sure, do any of the aftermarket chips coming out, control overboost better?
Old Oct 18, 2007 | 05:21 PM
MotorMouth's Avatar
MotorMouth
That is quite normal. It shows up in every stock dyno run that's been posted.
ECU mods can change that. (JCW ECU does)
Old Oct 18, 2007 | 05:49 PM
r56mini's Avatar
r56mini
The torque curve was designed to do that. More torque at the bottom where we drive at most of the time. Japanese cars have more torque at the top and no torque at the bottom. MINI's 1.6L is just not big enough to have strong pull from 1500rpm to 6700rpm, I guess.
Old Oct 18, 2007 | 06:16 PM
ALTA_JOHNL's Avatar
ALTA_JOHNL
the falling off of torque at the higher rpms is a combination of things but the largest contributor is the factory ECU lowering boost. the factory engine tune is one to make the car feel torquey in normal driving.
things are coming soon to address this issue. but there will be a limit to what the stock turbo can do at those higher rpms.
back to the dyno!
Old Oct 18, 2007 | 07:15 PM
r56mini's Avatar
r56mini
How much effect, in your opinion, will increasing boost have on the longevity of the engine?
Old Oct 18, 2007 | 07:28 PM
a96bimmerm3's Avatar
a96bimmerm3
judging from the vw world very little. I have friends with modded 90k+ mile GTIs running 20psi on a k03 with no issues. Just let it warm up and cool down, and change the oil once in a while.
Old Oct 19, 2007 | 08:51 AM
ALTA_JOHNL's Avatar
ALTA_JOHNL
In most cases it will have no measurable effects on engine life. Keep in mind this is based on a GOOD tune and a well maintained engine and its related systems.
Old Oct 19, 2007 | 09:03 AM
msh441's Avatar
msh441
Yes it does!
More hp up top....
...more torque down low...
...and my favorite part: the chasm of a dip in power around 3000 RPM all but disappears! It rocks.
Old Oct 19, 2007 | 09:16 AM
MotorMouth's Avatar
MotorMouth
Originally Posted by msh441
Yes it does!
More hp up top....
I ready to see a plot for the more down low! Seems like all the other mods we've seen so far sacrifice some low end torque to improve the top end.
Old Oct 19, 2007 | 01:31 PM
01CBR929's Avatar
01CBR929
That's normal, don't worry about it.
Old Oct 21, 2007 | 04:44 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
John is right. By forcing the wastegate to remain closed down low, and controlling the boost roll off up above in the RPM band, the HP and TRQ can be gained in both sections of the RPM as well as not sacrifice engine and turbo durability. Keep in mind this is all relative to a proper tune. Do the combo wrong and instead of the safe not opening, the bottom end of your motor will!
Colt45Magnus
Aug 27, 2024 05:03 AM
Sep 4, 2015 11:43 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 11:15 AM
