Drivetrain Do I need bigger injectors after ECU upgrade
Old Oct 15, 2007 | 12:18 PM
nikoamok's Avatar
nikoamok
I just baugt a standart mini is a 2006 cooper S and bought following on Ebay today. Does anyone know if i need bigger injectors?? And how big are the standard?
Alta V2 intake for a 6 speed AMP-INT-200V2
Alta V2 intake box top plate AMP-INT-250
Alta Spark plug ASM-SPK-001
Alta exhaust 3" AMP-EXT-105
Alta V2 pulley15% and a19% for later use
Alta Crank pulley +2%
Alta V2 intercooler AMP-ENG-400V2
silicone cup holders AMP-ENG-303
4 branch header Moving the cat
custom ECU opgrade made on dyne by HR Motorsport in Denmark
H&R suspension hight adjust
Bought a cylinder head that ime gonna modify with ultrik pistons (dont know if i need new springs anyone?)
and ime looking for a lsd slip differential! Dont know wish one is the best... heard that helix´s is good??? Ime getting my car the 23 this month and i cant waith...:impatient
Old Oct 15, 2007 | 12:45 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Yes, probably 380's, but if you want the most out of it then go with 440's and a custom tune. With the cylinder head that you are moddifing, you will want the most out of it.
Oh and run the 15% the supercharger gets too hot.
Old Oct 15, 2007 | 12:49 PM
Fisher's Avatar
Fisher
I do not think if that silicone cup holders AMP-ENG-303 is the reason for a bigger injectors.
People often make me laugh.
And no you do not need it. Or even better, chek the A/F and you will see if you need them or not.
Bye
Old Oct 15, 2007 | 01:02 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
^Good point, check the AFR's.
Old Oct 15, 2007 | 01:23 PM
nikoamok's Avatar
nikoamok
just kopi paste it from an email... didnt think about it!
Does the charger overheating with 21% boost increase??
Does anyone make modifeid intake manifold? just bougt an 64mm Throttle
Old Oct 15, 2007 | 01:25 PM
nikoamok's Avatar
nikoamok
sorry guys ime european what is A/F or AFR
Old Oct 15, 2007 | 01:33 PM
MiniMacPR's Avatar
MiniMacPR
Air to fuel ratio.
My advice: get aquainted with an experienced MINI tuner/tech and follow advice and direction. If you keep on buying stuff without any plan, you are probably just wasting your money. Looks like you have plenty to spend, so do it WISELY...
Old Oct 15, 2007 | 01:52 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
64mm TB is HUGE! 62's have been said for "race only" in the past, but hey if you are going all out then, why not? But seriously, make a plan and talk to some good mini-specific techs. Otherwise yes, you will waste money!
Old Oct 15, 2007 | 01:56 PM
nikoamok's Avatar
nikoamok
Well asked my ECU tuner http://www.rh-motorsport.dk and he is going to provide me with 440cc injectors i just hope ime covered when i get the big valve head on... Thats why i ask you guys... Hoped that someone had some experiance to shear... slipp diff is covered 10 from helix... hope that chinese stuff works..
Old Oct 15, 2007 | 02:29 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
If it is an OBX LSD PM Longboard he has one and is putting out quite a bit o' power(Rotrex tester-or Project X-300 on here).
Old Oct 15, 2007 | 02:30 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
You'll need the 440's with the big valve head and 64mmTB. Hope your tune works out well.
Old Oct 15, 2007 | 02:33 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Ok, so I just checked out your link, but I really cannot make much sense of what is going on since even the English version is confusing. But, what software does he tune with? Dimsport? GIAC?
Old Oct 15, 2007 | 02:35 PM
nikoamok's Avatar
nikoamok
thanks i will post pics and movie when ime on the dyno.. does the supercharger overheat over 19%???
Old Oct 15, 2007 | 03:07 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Yes, there is a BIG debate on whether it does or not. I have a 19%, it is great to get the extra boost, but IT DOES GET HOT!. I mean lately I have been testing to see what happens. I literaly iced my intercooler, inlet and exit horns, valve cover, and intake manifold for about 20 minutes(and this is after the car has set for at least an hour). Then, once everything was very cold to the touch, I made a ~5 minute run in an Industrial part of town came back and Dam^ if it was not scorching. I mean I could not touch my whole hand to the horns(inlet to IC was burning me, and the outlet was just bearable). I only reached speeds of ~70-75mph!
Now, what do you chose? I would be switching to a 15%, but I am planning a full turbo conversion.
Old Oct 15, 2007 | 03:08 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
+ the heat soak from my above post means BIG loss in power, BIG loss!
Old Oct 15, 2007 | 03:29 PM
nikoamok's Avatar
nikoamok
hmm that dont sound nice at all that means ime only gonna run 17%... hmm jcw have modified the supercarger but i dont know how... maybe they portet it..I know that helps on heat! how old is your car.. i know eaton have made modifikation on charger after 7/2004. teflon coated swirls? Maybe i should cancel and pay overprise for their turbo header from the twin kit an go with a gt2871rs light trim that would be an easy 300 bhp... dit like that eaton sound... Man you got me thinking... just bougt a schrick cam from a german guy who races the mini series here in europe...
Old Oct 15, 2007 | 03:48 PM
Fisher's Avatar
Fisher
Do you believe he will have more than 270HP?
I do not think so.
Old Oct 15, 2007 | 03:51 PM
Fisher's Avatar
Fisher
Go to the water to air system of cooling inlet air and there won't be any problems with heat.
Old Oct 15, 2007 | 03:55 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Fisher- No, but he is going pretty crazy.
nikoamok- You really need to stop buying everything before you get this "plan". If you are going full turbo, then you will have to sell anything supercharge specific(intercooler pulley etc...), but there is another option.
You could do a "twin-charge". Which is keeping the stock supercharger(with a bigger pulley to run it slower) and adding a turbo to that. PM Tuls. He has all the info on twin and full turbos that you could ever want.
But, seriously get a plan and stick to it.
And hey, the 440's would even work with the twin charge if you keep it conservative unlike Tuls(PM him and you will figure everything out).
Old Oct 15, 2007 | 03:57 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Also, a full turbo build done "right" will cost you $8,000+ easily.
A twin charge will cost you $4,000+.
Old Oct 16, 2007 | 01:58 AM
nikoamok's Avatar
nikoamok
Ive got almost al parts laying arund for a turbo conversion
i have a gt2871rs done only 1000 miles 2 bar boost a big intercooler from halsted front mounted... Only hard ting is the header and manifold thats the hard parts. ecu is not a problem...
molala
Oct 2, 2015 01:53 PM
Sep 3, 2015 10:29 AM
Manny_cooper
Sep 3, 2015 05:48 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
