Pitting on 17" S-Lites. Suggestions to Clean.
Old Apr 7, 2007 | 11:40 AM
MCDriver's Avatar
MCDriver
i have 17" stock S-Lites. the fronts are collecting lots of baked brake pad residue as well many "pitted" spots. what is the best way to clean this off?
Old Apr 8, 2007 | 05:51 AM
kenchan's Avatar
kenchan
those are tough to clean. you will have to take a polish on each pit and clean them out.
best you get them repaired. yes, that is a damaged wheel imho.
Old Apr 8, 2007 | 09:49 AM
hugh's Avatar
hugh
P21S Gel Special Performance Wheel Cleaner...works for me!
Not only the dust, but the calcified crap that collects in the crevices 'melts' away in minutes!
The pump spray kit is around $16.
Old Apr 8, 2007 | 11:51 AM
MCDriver's Avatar
MCDriver
i assume that the "pitted" spots are a result of hot particles from the brake pads fusing into the clear coat on the wheel.
anybody every tried detailing clay?
Old Apr 8, 2007 | 01:11 PM
kenchan's Avatar
kenchan
hard to tell.. i thought the paint was chipped.
Old Apr 13, 2007 | 12:54 PM
Benja0901's Avatar
Benja0901
I get this 'crap' in the nooks of the s-lites (the rounded corners of the triangles). Feels like grit, so I suspect rotor parts? the front ones are nasty, with just under 4k on the clock and I'm fairly **** about cleaning my wheels (every 150-200 or so until winter set in and you couldn't clean the wheels without the water freezing on them)
Will the P21 take care of this?
Cheers!
Old Apr 13, 2007 | 01:18 PM
rubyred3's Avatar
rubyred3
detail clay, works wonders. . .
its time consuming, but for the crap that won't come off any other way, its awesome
Old Apr 13, 2007 | 01:27 PM
Benja0901's Avatar
Benja0901
Who'da thunk. Will give this a shot. I don't mind the time commitment, I spent a good hour doing all 4 and getting them as best I could
Cheers!
mitchman's Avatar
mitchman
I've use this stuff for years. I've never had any problems with pitting. I'm guessing that you really don't have a pitting problem and that it's just baked on brake dust. I'm going to stick my neck out and stay that this stuff will take it off. Just spray it all over the wheel and use a plastic bristled brush to scrub the wheel real good. Then rinse it off. The key part is to rinse it off real good as it supposedly contains a small amount of acid and if you don't rinse it off real good, it could eat the surface or something. I was warned of this problem but I've never actually experienced it myself in 10 years of using it.
As an added plus, it also makes a great tire cleaner! You can buy it just about anywhere (Wal-Mart, AutoZone, etc....)
Old Apr 13, 2007 | 08:03 PM
MCDriver's Avatar
MCDriver
Benja, please give us a report on th detailing clay. i got a similar suggestion from an acquaintance.
navybsn
Oct 5, 2018 04:42 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
chowpott
Oct 19, 2015 08:37 AM
zdw2082
Oct 5, 2015 09:59 AM
point665
Sep 29, 2015 12:41 PM
