Help Needed.. Repairing, Painting cracks in front apron
Hello,
I am repairing some cracks in my front Aero Kit apron after hitting a large cat at 65mph.:mad: I have JB Welded the cracks together at the back of the apron. In the front I've filled in the cracks with putty and sanded everything down. So far so good. Last night I taped off a few square inch area and primed it with flexible primer. Then I spray painted over the primer with matching chili red. It took about 5 coats to cover the primer. Here's the hard part. After removing the newspaper and tape, I have paint lines where the repaired area is built up with 6 coats of primer/paint and the surrounding area is still the perfectly good clearcoat. My question is how do I blend the repaired area into the surrounding area as far as leveling it out before applying my clearcoat? If I sand down the edges that will create scratches that I'll have to paint over, which would overspray onto the good existing clearcoat. I could see this project moving out and out and out until I have to repaint the entire bumper! Help! Steve |
Feathering the paint rather than spraying up tight to the mask would have been best.
As long as your final sanding is with an appropriate grit (like 2000 or some rubbing compound) the new clear will fill any scratches in your old clear. Just feather it as you overlap into the old clear and you should be ok. |
TooTall,
Final sanding of the basecoat? It took 5 layers to cover the primer, so it built up thick against the tape. Should I mask it further away from the damage I guess? I just didn't want a bunch of overspray where I didn't need it. |
Originally Posted by PerkMini
TooTall,
TooTall,
Should I mask it further away from the damage I guess? |
if i may repeat... never paint up to the masking. this is the first mistake
i made when repairing a dime sized scratch in my old wrx. broad coating is best... and the trick is more in the sanding/polishing rather than painting imho. i ended up doing the repair 5-6 times until i finally got it to where it was quite smooth for an amature. :) |
